Cisco IOS supports these PIM modes, among others:
- PIM sparse mode: this is a “pull” model where we only forward multicast traffic when requested.
- PIM dense mode: this is a “push” model where we flood multicast traffic everywhere and then prune it when it’s not needed.
The third one is PIM sparse-dense mode where we can use sparse or dense mode for each multicast group. Why do you want to use this?
When you use PIM sparse mode, our multicast routers need to know where the RP (Rendezvous Point) is in the network and which groups they serve. There are two methods:
When you use PIM sparse mode and Auto RP, the group-to-RP mapping is sent to the multicast 224.0.1.40 address. This is a classic chicken and egg problem…how do we receive traffic from 224.0.1.40 when we don’t know where the RP is? There are two methods to solve this:
- Use the ip pim autorp listener command.
- Use PIM sparse-dense mode.
The ip pim autorp listener command floods auto RP 224.0.1.39 and 224.0.1.40 multicast groups on sparse mode interfaces, allowing all routers to receive the group-to-RP mapping information.
PIM sparse-dense mode also allows us to flood the auto RP 224.0.1.39 and 224.0.1.40 multicast groups but in addition, it also floods all multicast traffic that we don’t have an RP for.
In this lesson, I’ll show you how PIM sparse-dense mode forwards some traffic with sparse mode and other traffic with dense mode.
Here is the topology we will use:
R1, R2, and R3 are multicast routers and we use Auto RP on R1 for both the mapping agent and RP role. S1 is used to source some multicast traffic, H1 is our receiver.
R1
hostname R1
no ip domain lookup
ip cef
interface GigabitEthernet0/1
interface GigabitEthernet0/2
router ospf 1
router-id 1.1.1.1
network 1.1.1.1 0.0.0.0 area 0
R2
hostname R2
no ip domain lookup
ip cef
router ospf 1
router-id 2.2.2.2
R3
hostname R3
no ip domain lookup
ip cef
ip address 192.168.3.254 255.255.255.0
router ospf 1
router-id 3.3.3.3
network 192.168.3.0 0.0.0.255 area 0
S1
hostname S1
no ip routing
no ip cef
ip address 192.168.1.101 255.255.255.0
H1
hostname H1
no ip routing
no ip cef
ip address 192.168.3.101 255.255.255.0
ip default-gateway 192.168.3.254
First, we need to enable multicast routing globally on all routers:
R1, R2 & R3
(config)#ip multicast-routing
All interfaces that process multicast traffic need PIM sparse-dense mode enabled. Here’s R1:
R1(config-if)#ip pim sparse-dense-mode
R1(config)#interface Loopback 0
And R2:
R2(config-if)#ip pim sparse-dense-mode
Last but not least, R3:
R3(config)#interface GigabitEthernet 0/1
R3(config-if)#ip pim sparse-dense-mode
R3(config)#interface GigabitEthernet 0/2
We configure R1 so that it’s the Auto RP mapping agent and that it advertises itself as the RP:
R1(config)#ip pim send-rp-announce loopback 0 scope 5
R1(config)#ip pim send-rp-discovery loopback 0 scope 5
Everything is now in place. Let’s make sure we see PIM neighbors:
R2#show ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable, G - GenID Capable,
L - DR Load-balancing Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
192.168.12.1 GigabitEthernet0/1 00:27:17/00:01:33 v2 1 / S P G
192.168.23.3 GigabitEthernet0/2 00:26:00/00:01:23 v2 1 / DR S P G
Discovering the RP
Do all routers have group-to-RP mapping? Let’s find out:
R2#show ip pim rp mapping
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
RP 1.1.1.1 (?), v2v1
Info source: 1.1.1.1 (?), elected via Auto-RP
Uptime: 00:00:35, expires: 00:02:23
R3#show ip pim rp mapping
Uptime: 00:00:46, expires: 00:02:10
Both R2 and R3 have learned the group-to-RP mapping. How did they learn this? Let’s find out:
R1#show ip mroute 224.0.1.40
IP Multicast Routing Table
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector, p - PIM Joins on route,
x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
Timers: Uptime/Expires
(*, 224.0.1.40), 00:07:15/stopped, RP 0.0.0.0, flags: DCL
Outgoing interface list:
Loopback0, Forward/Sparse-Dense, 00:02:31/stopped
GigabitEthernet0/1, Forward/Sparse-Dense, 00:07:15/stopped
(1.1.1.1, 224.0.1.40), 00:01:36/00:02:22, flags: LT
Incoming interface: Loopback0, RPF nbr 0.0.0.0
GigabitEthernet0/1, Forward/Sparse-Dense, 00:01:36/stopped
The multicast 224.0.1.40 address is used to share group-to-RP mapping information and as you can see above, this is flooded using dense mode.
Here’s the output on R2:
R2#show ip mroute 224.0.1.40
(*, 224.0.1.40), 00:05:46/stopped, RP 0.0.0.0, flags: DCL
GigabitEthernet0/2, Forward/Sparse-Dense, 00:04:28/stopped
GigabitEthernet0/1, Forward/Sparse-Dense, 00:05:46/stopped
(1.1.1.1, 224.0.1.40), 00:02:03/00:02:56, flags: LT
Incoming interface: GigabitEthernet0/1, RPF nbr 192.168.12.1
GigabitEthernet0/2, Forward/Sparse-Dense, 00:02:03/stopped
Above we see that R2 has received traffic to 224.0.1.40 using dense mode. For R2, it doesn’t matter if we use sparse or dense mode since it is directly connected to R1. R1 is the mapping agent and sends its RP discovery messages to 224.0.1.40 out of all its PIM interfaces, so R2 would have received them anyway.
For R3, we do need dense mode since R2 has to flood the traffic it receives from R1 to R3. Here’s the output of R3:
R3#show ip mroute 224.0.1.40
(*, 224.0.1.40), 00:04:33/stopped, RP 0.0.0.0, flags: DCL
GigabitEthernet0/1, Forward/Sparse-Dense, 00:04:33/stopped
(1.1.1.1, 224.0.1.40), 00:02:08/00:02:51, flags: PLTX
Incoming interface: GigabitEthernet0/1, RPF nbr 192.168.23.2
Outgoing interface list: Null
R3 also has received traffic to 224.0.1.40. This is looking good.
Traffic with sparse mode
Let’s try to send some multicast traffic. Remember our group-to-RP mapping?
R3#show ip pim rp mapping | include Group
R1 is willing to be the RP for the entire 224.0.0.0/4 multicast range. This means that all groups, except the Auto-RP groups 224.0.1.39 and 224.0.1.40, are forwarded with PIM sparse mode. To test if this is true, I will let H1 join a multicast group:
Hi Rene.
Thank for great explain, How ever i still confuse. Can you explain what is RP mapping agent ? and why we need it ?
Thank
Sovandara
Hello Heng
In the first version of PIM-SM, all routers were required to be manually configured with the IP address of the RP. This does not scale well for a large complex network.
After this, Cisco implemented the Auto-RP feature which automates the distribution of group-to-RP mappings in a PIM network. To make Auto-RP work, there must be an RP mapping agent which receives the RP announcement messages from the RPs and arbitrates conflicts. The RP mapping agent then sends the consistent group to RP mappings to all other routers by dense mode flooding. This w
... Continue reading in our forumI have a very basic topology of router on a stick so two VLANS (10 and 20) can communicate. What type of multicasting (SPARSE / DENSE) should I configure on my router (C2900 V15.2) to enable a server in one VLAN (VLAN 10) to send multicast traffic to devices in its own VLAN and devices in the other VLAN (VLAN 20) - that is connected via Router on a stick (sub – interfaces)
Hello Jason
If your topology only consists of a single router with two VLANs, then DENSE mode would be preferable. Arguably, this is the simplest mechanism as it doesn’t require an RP (since you only have one router). In such a case, dense mode forwards multicast traffic on all interfaces until we are requested to stop forwarding. For more info on dense mode, take a look at the following:
https://networklessons.com/multicast/multicast-pim-dense-mode
Hello, is the
ip pim autorp listenercommand only needed in one adj PIM router or Do I needed it everywhere in order to get the RP?
