Trunking on Cisco IOS Switch
A trunk carries traffic from multiple VLANs between switches using 802.1Q or ISL encapsulation. Without trunks, you’d need a separate physical link for each VLAN, which is impractical in most networks.
In this lesson, we configure a trunk between two Cisco Catalyst switches using 802.1Q encapsulation. We’ll create a VLAN, assign access ports, configure the trunk, and explore the different switchport modes (trunk, access, dynamic auto, and dynamic desirable).
Key Takeaways
  • Trunks carry multiple VLANs over a single link using 802.1Q (industry standard) or ISL (Cisco proprietary)
  • Use switchport trunk encapsulation dot1q before switchport mode trunk on switches that support both ISL and 802.1Q
  • The show interfaces trunk command displays trunk status, encapsulation type, native VLAN, and allowed VLANs
  • Dynamic auto prefers access mode but becomes a trunk if the other side is set to trunk or dynamic desirable
  • Dynamic desirable actively negotiates to form a trunk
  • Always use switchport mode trunk explicitly in production. Avoid dynamic modes for security and predictability
  • Mismatched switchport modes (access on one side, trunk on the other) generate spanning-tree errors
Prerequisites
Before diving into this trunk configuration, you should have a basic understanding of:
Let me show you the topology that we’ll use:
H1 (192.168.1.1 /24) on SW1 Fa0/1, SW1 and SW2 linked on Fa0/14, H2 (192.168.1.2 /24) on SW2 Fa0/2
Above, you see a topology with a computer connected to each switch. We’ll put the computers in the same VLAN and create a trunk between the two switches.
Let’s start by creating a VLAN:
SW1(config)#vlan 50
SW1(config-vlan)#name Computers
SW1(config-vlan)#exit
SW2(config)#vlan 50
SW2(config-vlan)#name Computers
SW2(config-vlan)#exit
And let’s put the interfaces connected to the computers in the correct VLAN:
SW1(config)#interface fa0/1
SW1(config-if)#switchport access vlan 50
SW2(config)#interface fa0/2
SW2(config-if)#switchport access vlan 50
The next step is to create a trunk between the two switches. Technically the interfaces between the two switches can also be in access mode right now because I only have a single VLAN.
SW1(config)#interface fa0/14
SW1(config-if)#switchport mode trunk
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
SW2(config)#interface fa0/14
SW2(config-if)#switchport mode trunk
I try to change the interface to trunk mode with the switchport mode trunk command. Depending on the switch model, you might see the same error as me. If we want to change the interface to trunk mode, we need to change the trunk encapsulation type. Let’s see what options we have:
SW1(config-if)#switchport trunk encapsulation ?
  dot1q      Interface uses only 802.1q trunking encapsulation when trunking
  isl        Interface uses only ISL trunking encapsulation when trunking
  negotiate  Device will negotiate trunking encapsulation with peer on interface
This is where you can choose between 802.1Q or ISL encapsulation. By default, our switch will negotiate about the trunk encapsulation type.
SW1(config-if)#switchport trunk encapsulation dot1q
SW2(config-if)#switchport trunk encapsulation dot1q
Let’s change it to 802.1Q by using the switchport trunk encapsulation command.
SW1#show interfaces fa0/14 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Administrative Trunking Encapsulation: dot1q
SW2#show interfaces fa0/14 switchport
Switchport: Enabled
As you can see the trunk encapsulation is now 802.1Q.
Now I can successfully change the switchport mode to trunk.
Switchport: Enabled Administrative Mode: trunk Operational Mode: trunk
Operational Trunking Encapsulation: dot1q
We can confirm we have a trunk because the operational mode is “trunk” and the operational trunking encapsulation is “dot1q”.
Let’s try if H1 and H2 can reach each other:
Excellent! H1 and H2 can reach each other! Does this mean we are
done? Not quite yet…there is more I want to show to you:
SW2#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/5
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/15, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/1, Gi0/2
50   Computers                        active    Fa0/2
First of all, if we use the show vlan command, we don’t see the Fa0/14 interface. This is completely normal because the show vlan command only shows interfaces in access mode and no trunk interfaces.
SW2#show interface fa0/14 trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa0/14      on               802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/14      1-4094
Port        Vlans allowed and active in management domain
Fa0/14      1,50
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/14      50
The show interface trunk command is useful. You can see if an interface is in trunk mode, which trunk encapsulation protocol it uses (802.1Q or ISL), and what the native VLAN is. We can also see that VLANs 1 to 4094 are allowed on this trunk.
We can also see that only VLAN 1 (native VLAN) and VLAN 50 are currently active. Last but not least, you can see which VLANs are in the forwarding state for spanning tree.
I want to show you one more thing about access and trunk interfaces:
SW2#show interface fa0/2 switchport
Switchport: Enabled
An interface can be in access mode or in trunk mode. The interface above is connected to H2, and you can see that the operational mode is “static access,” which means it’s in access mode.
Switchport: Enabled
This is our trunk interface which is connected to SW1. You can see the operational mode is trunk mode.
SW2(config-if)#switchport mode ?
  access        Set trunking mode to ACCESS unconditionally
  dot1q-tunnel  set trunking mode to TUNNEL unconditionally
  dynamic       Set trunking mode to dynamically negotiate access or trunk
  private-vlan  Set private-vlan mode
  trunk         Set trunking mode to TRUNK unconditionally
If I go to the interface configuration to change the switchport mode, you can see I have more options than access or trunk mode. There is also a dynamic method. Don’t worry about the other options for now.
SW2(config-if)#switchport mode dynamic ?
  auto       Set trunking mode dynamic negotiation parameter to AUTO
  desirable  Set trunking mode dynamic negotiation parameter to DESIRABLE
We can choose between dynamic auto and dynamic desirable. Our switch will automatically determine if the interface should become access or trunk port. So what’s the difference between dynamic auto and dynamic desirable? Let’s find out!
SW1 and SW2 connected on Fa0/14
I’m going to play with the switchport mode on SW1 and SW2, and we’ll see the result.
SW1(config-if)#switchport mode dynamic auto
SW2(config-if)#switchport mode dynamic auto
First, I’ll change both interfaces to dynamic auto.
SW1(config-if)#do show interface f0/14 switchport
Switchport: Enabled
SW2(config-if)#do show interface f0/14 switchport
Switchport: Enabled
Our administrative mode is dynamic auto, and as a result, we now have an access port.
SW1(config-if)#switchport mode dynamic desirable
SW2(config-if)#switchport mode dynamic desirable
Switchport: Enabled
Administrative Mode: dynamic desirable
Switchport: Enabled
Once we change both interfaces to dynamic desirable, we end up with a trunk link. What do you think will happen if we mix the switchport types? Maybe dynamic auto on one side and dynamic desirable on the other side? Let’s find out!
SW1#show interfaces f0/14 switchport
Switchport: Enabled
Switchport: Enabled
It seems our switch has a strong desire to become a trunk. Let’s see what happens with other combinations!
Switchport: Enabled
Switchport: Enabled
Dynamic auto will prefer to become an access port, but if the other interface has been configured as a trunk we will end up with a trunk.
SW2(config-if)#switchport mode access
Switchport: Enabled
Switchport: Enabled
Configuring one side as dynamic auto and the other as access will result in an access port.
Switchport: Enabled
Switchport: Enabled
Dynamic desirable and trunk mode offers us a working trunk.
What do you think will happen if I set one interface in access mode and the other one as trunk? Doesn’t sound like a good idea but let’s push our luck:
Switchport: Enabled
Switchport: Enabled
SW1#
%SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/14 VLAN1.
%SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/14 on VLAN0001. Inconsistent port type.
%SPANTREE-2-UNBLOCK_CONSIST_PORT: Unblocking FastEthernet0/14 on VLAN0001. Port consistency restored.
As soon as I change the switchport mode, I see these spanning tree error messages on SW1. Spanning tree is a protocol that runs on switches that prevent loops in our network.
Tags: ,
    You have a very unique way of explaining, Clear and direct to the point. I am very grateful.
    I really appreciate your efforts :slight_smile:
    Hi ,
    Im following you LAB but i would like to know how to change the Operational Mode
    status .
    Every times i would like to change it , it doesn’t work .
    #sh int Fa0/21 switchport
    Switchport: Enabled
    Operational Mode: down <—
    Negotiation of Trunking: Off
    Access Mode VLAN: 50 (TesteIMO(NOTOUCH))
    Voice VLAN: none
    Thanks for your help .
  4. Avatar for nbharathi27 nbharathi27 says:
    Can u check whether u made it no shut?
  5. Avatar for rajmannar rajmannar says:
    Please clarify how to interpret the table you listed in the page below with different modes
104 more replies! Ask a question or join the discussion by visiting our Community Forum
