EIGRP K Values Formula
EIGRP uses different K values to determine the best path to each destination:
  • K1
  • K2
  • K3
  • K4
  • K5
These K values are only numbers to scale numbers in the metric calculation. The formula we use for the metric calculation looks like this:
Metric = [K1*bandwidth + ((K2*bandwidth)/(256-load))+K3*delay]
If K5 is not equal to 0:
Metric = Metric*[K5/(reliability+K4)]
If you look at the formula, you can see that the bandwidth, load, delay, and reliability influence the metric. We can see what K values are enabled or disabled by default:
Router#show ip protocols
Routing Protocol is "eigrp 1"
  Default networks flagged in outgoing updates
  Default networks accepted from incoming updates
  EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
  EIGRP maximum hopcount 100
  EIGRP maximum metric variance 1
  Redistributing: eigrp 1
  EIGRP NSF-aware route hold timer is 240s
  Maximum path: 4
  Routing for Networks:
    1.1.1.0/24
    192.168.12.0
  Routing Information Sources:
    192.168.12.2          90      00:14:30
  Distance: internal 90 external 170
In this example where I used the show ip protocols command, you can see which K-values are enabled by default. Only K1 and K3 are enabled by default.
Let’s walk through the different metric components to see what they are:
Bandwidth:
Router#show interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is cc02.58a9.0000 (bia cc02.58a9.0000)
  Internet address is 192.168.12.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
If you use the show interface FastEthernet 0/0 command, you can see the interface information. The example above only shows part of the output. You can see the bandwidth is 100000 Kbit, which is a 100Mbit interface. We can change the bandwidth of an interface:
Router(config)#interface fa0/0
Router(config-if)#bandwidth ?
  <1-10000000>  Bandwidth in kilobits
  inherit       Specify that bandwidth is inherited
  receive       Specify receive-side bandwidth
Router(config-if)#bandwidth 500
Bandwidth is a static value that can be changed by using the bandwidth command. Keep in mind this doesn’t change the actual bandwidth of the interface! This command is ONLY used to influence routing protocols like EIGRP. It’s not like you can slow down electric signals through a wire…if you want to limit the traffic on an interface, you’ll need QoS (Quality of Service), which is a story for another day!
  MTU 1500 bytes, BW 500 Kbit, DLY 100 usec,
Here, you see the result of changing the bandwidth on the interface. Something to remember is that EIGRP will use the lowest bandwidth in the path from A to B (since this is the bottleneck).
Load:
The load will show you how busy the interface is based on the packet rate and the bandwidth on the interface. This value can change over time, so it’s a dynamic value.
Delay:
The delay reflects the time it will take for packets to cross the link and is a static value. Cisco IOS will have default delay values for the different types of interfaces. A FastEthernet interface has a default delay of 100 usec.
Router(config-if)#delay ?
  <1-16777215>  Throughput delay (tens of microseconds)
Router(config-if)#delay 50
If you use the delay command you can change this value to influence routing protocols like EIGRP. It doesn’t actually change the delay for this interface, but it is only used to influence routing protocols.
  MTU 1500 bytes, BW 500 Kbit, DLY 500 usec,
Above, you see the delay that I changed. EIGRP will accumulate all the delay values in the path from A to B.
Reliability:
Reliability at 255/255 is 100%. This means that you don’t have issues with the physical or data-link layer. If you are having issues, this value will decrease. Since this is something that can change, it’s a dynamic value.
MTU:
MTU, or Maximum Transmission Unit, is being exchanged between EIGRP neighbors but not used for the metric calculation.
By default, only K1 and K3 are enabled, and we don’t use K2, K4 or K5. This means that only bandwidth and delay are used in the formula.
Why not? Because load and reliability are dynamic values, and they can change over time. Load and reliability change all the time, so a metric based on them would be unstable. EIGRP only samples them when a link changes, so they would give an unpredictable, out-of-date picture rather than constant updates. We want routing protocols to be nice and quiet and only base their routing decisions on static values like bandwidth and delay. If you only use those two static values, our EIGRP routers don’t have to do any recalculation unless an interface goes down or a router crashes.
Since only K1 and K3 are enabled, we can simplify the EIGRP formula:
Metric = bandwidth (slowest link) + delay (sum of delays)
  • Bandwidth: [107 / minimum bandwidth in the path] * 256.
  • Delay: sum of delays in the path multiplied by 256 (in tens of microseconds).
So the formula looks like:
Metric = (107 / minimum bandwidth) * 256 + (sum of delays) * 256
The multiplication of 256 is done so that EIGRP is compatible with IGRP (the predecessor of EIGRP).
Let me show you an example so we can break down this formula:
  1. Avatar for ReneMolenaar ReneMolenaar says:
    this was a really good post! One statement that I personally dont liked:
    “ou don’t want your EIGRP routers calculating 24/7 and sending updates to each other just because the load or reliability of an interface has changed. We want routing protocols to be nice and quiet and only base their routing decisions on static values like bandwidth and delay.”
    I think everyone would love to have a routing protocol that dynamically adapts to the network state but the processing overhead for the routers in your network would be a nightmare.
    Thank you for this post.
    Marek
    AFAIK the formula when considered only BW and delay should be:
    Metric= [ (10^7/ Minimum BW) + (sum of delay/10) ] * 256
    Excellent explanation on the metric values used by EIGRP to determine “best” path (route) to take when trying to reach another non-local network. I always was curious how 'best" path was determine by EIGRP when deciding which way to send the packet when multiple paths exists, excellent. Of course this has no real bearing on “stub” networks I take.
    Thanks again for your concise explanations on Networking w/ Cisco
    Darren
    Hi Darren,
    You are welcome. If you want to take a closer look at this then I can recommend to boot up some routers and look at the EIGRP topology table. Spend some time looking at the successor and feasible successor routers and check why it installed certain things in the routing table.
    sorry i figured it out, myself, smaller metric is better, its all for influencing, i understand that now, thanks
45 more replies! Ask a question or join the discussion by visiting our Community Forum
