Cisco Wireless AP Modes
Many Cisco APs can operate in autonomous or lightweight mode; this depends on the image that you run.
An AP that serves wireless clients is in local mode. Besides local mode, there are other AP modes. In this lesson, we’ll take a look at each AP mode.
AP Modes
Local
Local mode is the default mode; it offers a BSS on a specific channel. When the AP doesn’t transmit wireless client frame, it’s still doing something behind the scenes. The AP scans other channels to:
  • Measure noise
  • Measure interference
  • Discover rogue devices
  • Check for matches against IDS events
Monitor
An AP in monitor mode doesn’t transmit at all. It’s a dedicated sensor that:
  • Checks Intrusion Detection System (IDS) events
  • Detects rogue APs
  • Determines the position of wireless stations
Because the AP is only in monitor mode, it won’t broadcast an SSID so clients are unable to connect to the AP.
FlexConnect
It’s possible to connect a local mode AP at a remote branch to the HQ’s WLC. This works, but it’s not a good idea. First of all, the AP encapsulates all wireless client data through the CAPWAP tunnel over the WAN link. Secondly, when the WAN link is down, your wireless network at the branch site is offline too.
FlexConnect is an AP mode for situations like the one above. The AP can locally switch traffic between a VLAN and SSID when the CAPWAP tunnel to the WLC is down.
Sniffer
An AP in sniffer mode dedicates its time to receive 802.11 wireless frames. The AP becomes a remote wireless sniffer; you can connect to it from your PC with an application like Wildpackets Omnipeek or Wireshark. This can be useful if you want to troubleshoot a problem and you can’t be on-site. When an AP is in sniffer mode, it won’t broadcast an SSID so clients can’t connect to the AP.
Rogue Detector
Rogue detector mode makes the AP detect rogue devices full-time. The AP checks for MAC addresses it sees in the air and on the wired network. Depending on what WLC version you use, this AP mode might not exist.
Bridge/Mesh
The AP becomes a dedicated point-to-point or point-to-multipoint bridge. Two APs in bridge mode can connect two remote sites. Multiple APs can also form an indoor or outdoor mesh. You can’t connect to the bridge with clients.
Flex plus Bridge
The AP can operate in either FlexConnect or Bridge/Mesh mode. This AP mode combines the two; it allows APs in mesh mode to use FlexConnect capabilities.
🔥 2433 people registered in the last 30 days
  1. Hi Rene,
    In monitor mode the AP detect the rough APs, also in rogue detector mode it’s detect rough devices, so can you give more detail about the different between two mode in detector matter, in other word what you mean by rough devices so I can see the different ? do you mean that it’s check for mac address that pre-defined somewhere and give us a notification about it ? I want the full picture of this so I can visualize the use cases of this rogue detector mode.
  2. Hello Hussein
    First of all it’s important to understand what the term rogue refers to. It doesn’t only refer to access points, but also to clients that have erroneously connected to those access points. There are two things that can be done to contain both the rogue AP and the rogue clients that have connected to them. The first has to do with the rogue clients, while the second has to do with the rogue AP itself.
    1. When a rogue client is detected, the legitimate access points can send a de-authentication packet to these clients that will disassociate them
  3. Thanks Laz, it’s very useful summary of this cisco doc.
  4. Hello,
    I am interested in the difference between Sniffer Mode and SE-Connect Mode. Both seem to have wireless sniffing properties.
  5. Hello Cool
    Sniffer mode is used to capture Layer 2 wireless frames and send them to a packet analyzer program such as Wireshark. In this mode, the AP will actively receive frames, and process them, and send them to the configured packet analyzer. There they can be saved into .pcap files (for Wireshark) for examination at a later time.
    SE-Connect mode is different, in that it is used to perform spectrum analysis. The AP will “listen” to the RF band in the air and record the frequencies and wavelengths it “hears”. This is useful in discovering all of the sour
25 more replies! Ask a question or join the discussion by visiting our Community Forum
