VLAN Configuration on Cisco IOS Switch
In this lesson, I will show you how to configure VLANs on Cisco Catalyst Switches and how to assign interfaces to certain VLANs. Let’s start with a simple network topology:
H1 and H2 connected to switch SW1 (model 2950) on Fa0/1 and Fa0/2, subnet 192.168.1.0/24
Let’s start with a simple example. H1 and H2 are connected to SW1.
First, we will look at the default VLAN configuration on SW1:
SW1#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/22
                                                Fa0/23, Fa0/24, Gi0/1, Gi0/2
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Interesting…VLAN 1 is the default VLAN and you can see that all active interfaces are assigned to VLAN 1.
In the default VTP server mode, VLANs are not saved in the running-config or startup-config but in a separate file called vlan.dat on your flash memory. (In VTP transparent mode, they are also saved in the running-config.) The switchport access vlan commands on your interfaces are saved in the running-config as usual. If you want to delete the VLANs, you should delete this file by typing delete flash:vlan.dat. I configured an IP address on H1 and H2 so they are in the same subnet.
Let’s see if H1 and H2 can reach each other:
Even with the default switch configuration, H1 can reach H2. Let’s see if I can create a new VLAN for H1 and H2:
SW1(config)#vlan 50
SW1(config-vlan)#name Computers
SW1(config-vlan)#exit
This is how you create a new VLAN. If you want, you can give it a name, but this is optional. I’m calling my VLAN “Computers.”
SW1#show vlan
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15,
50   Computers                        active
VLAN 50 was created on SW1, and you can see that it’s active. However, no ports are currently in VLAN 50. Let’s see if we can change this…
SW1(config)#interface fa0/1
SW1(config-if)#switchport access vlan 50
SW1(config)#interface fa0/2
First, I will configure the switchport in access mode with the switchport mode access command. By using the switchport access vlan command, we can move our interfaces to another VLAN.
SW1#show vlan
1    default                          active    Fa0/3, Fa0/4
                                                Fa0/9, Fa0/10,, Fa0/12
                                                Fa0/23, Fa0/24, Gi0/2
50   Computers                        active    Fa0/1, Fa0/2
Excellent! Both computers are now in VLAN 50. Let’s verify our configuration by checking if they can ping each other:
Our computers can reach each other within VLAN 50. Besides pinging each other, we can also use another show command to verify our configuration:
SW1#show interfaces fa0/1 switchport
Switchport: Enabled
Negotiation of Trunking: Off
Access Mode VLAN: 50 (Computers)
SW1#show interfaces fa0/2 switchport
Switchport: Enabled
By using the show interfaces switchport command, we can see that the operational mode is “static access,” which means it’s in access mode. We can also verify that the interface is assigned to VLAN 50.
Want to take a look for yourself? Here you will find the final configuration of the switch.
Tags: ,
    tnx
  2. Avatar for jamal06 jamal06 says:
    thanks! easy to understand well explained
  3. Avatar for prince20020 prince20020 says:
    Thanks..
  4. Avatar for rajmannar rajmannar says:
    Very neatly explained. Thanks.
  5. Avatar for maruti.gangumolu maruti.gangumolu says:
    Hi Rene, I installed cisco packet tracer and execute vlan lab and everything looks good so far. What is GNS3vault and is it downloadable for free?
    Maruti.
72 more replies! Ask a question or join the discussion by visiting our Community Forum
