How to Configure BGP Weight Attribute
Weight is a Cisco proprietary BGP attribute that can be used to select a certain path. Here’s what you need to know about weight:
  • Weight is the first BGP attribute in the list.
  • Cisco proprietary so you won’t find it on other vendor routers.
  • Weight is not exchanged between BGP routers.
  • Weight is only local on the router.
  • The path with the highest weight is preferred.
Let me give you an example of BGP weight:
BGP Weight Prefer Path
R1 in AS 1 can reach AS 3 through AS 2 or AS 4. If we want to ensure AS 2 is always used as the best path, you can change the weight. In my example, the weight for the path to AS 2 is set to 500 and higher than the weight of 400 for AS 4. Let’s see what this looks like on real Cisco routers. This is the topology that I will use:
Bgp Weight Attribute Lab Topology
Above, we have a simple scenario with two autonomous systems. R2 and R3 both have network 2.2.2.0/24 configured on their loopback0 interface, and I’ll advertise that in BGP.
R1(config)#router bgp 1
R1(config-router)#bgp router-id 1.1.1.1
R1(config-router)#neighbor 192.168.13.3 remote-as 2
R2(config)#router bgp 2
R2(config-router)#bgp router-id 2.2.2.2
R2(config-router)#neighbor 192.168.12.1 remote-as 1
R2(config-router)#neighbor 192.168.23.3 remote-as 2
R2(config-router)#network 2.2.2.0 mask 255.255.255.0
R3(config)#router bgp 2
R3(config-router)#bgp router-id 3.3.3.3
R3(config-router)#neighbor 192.168.13.1 remote-as 1
R3(config-router)#neighbor 192.168.23.2 remote-as 2
R3(config-router)#network 2.2.2.0 mask 255.255.255.0
Above you’ll find the configuration for BGP. I configured the manual router ID for a reason. R2 and R3 have the same IP address on the loopback interface, which means they would get the same router ID, and they would be unable to form a BGP neighbor adjacency. Let’s take a detailed look at R1:
R1#show ip bgp
BGP table version is 2, local router ID is 192.168.13.1
              r RIB-failure, S Stale
*> 2.2.2.0/24       192.168.12.2             0             0 2 i
*                   192.168.13.3             0             0 2 i
Router R1 decided to use 192.168.12.2 as the next hop. All the BGP attributes are the same, so it came down to the router ID to select a winner.
The default weight for a prefix that the router originates is 32768. You can verify this by taking a look at prefix 2.2.2.0/24 in the BGP table on R2 or R3.
Now let’s change this behavior using the weight attribute…
R1(config-router)#neighbor 192.168.13.3 weight 500
You can configure weight per neighbor using the weight command. All prefixes from this neighbor will have a weight of 500.
🔥 2384 people registered in the last 30 days
  1. In AS 2 you have named but nowwhere you have configured jim…you have configured JACK …in the second Diagram consisting of 3 routers you have named them James , jim , john…should i assume jim as Jack?..Excellent explanation by the way …
  2. Rene,
    Great lesson however, I have questions if we have two ISPs and we would like to route traffic out through ISP-1. It means we need to set up a higher weight on the ISP-1 peering with us and setup a lower weight on the second ISP-2?
    How can we make sure traffic goes out ISP-1 and comes back in using ISP-2?
    Hamood
  3. Hi Hamood,
    That’s right, you can use weight to select the path but this is only for the local router. If you want to influence your entire AS then you’ll have to use local preference:
    https://networklessons.com/bgp/how-to-configure-bgp-local-preference-attribute
    To influence how traffic enters our AS we have a couple of methods, the first one is MED:
    https://networklessons.com/bgp/how-to-configure-bgp-med-attribute
    This is only useful when you are multihomed to a single ISP. These two methods will help if you are multihomed to different ISPs:
    https://networkl
  4. Hi Renee,
    Great lesson but I would like to make one suggestion. I find it easier to follow when you name routers R1, R2, R3 instead of using name like Jack, Jon, James etc. I find names harder to keep straight in my head. Just my opinion.
    Thanks for all the cool Lessons.
105 more replies! Ask a question or join the discussion by visiting our Community Forum
