DMVPN Phase 1 RIP Routing
In the first DMVPN lesson I explained some of its basics, in the second lesson I explained how to create a basic DMVPN phase 1 configuration. In this lesson, we’ll take a look how RIP behaves on DMVPN phase 1.
Here’s the topology we will use:
DMVPN Example Topology loopbacks
Above we have two spoke routers and one hub, our underlay network uses 192.168.123.0/24 and the overlay network uses 172.16.123.0/24. Each router has a loopback interface with a network that we can advertise in RIP.
Tunnel Interfaces
Here is the configuration of the tunnel interfaces on the hub and spoke routers. I explained these commands in the DMVPN phase 1 basic configuration lesson so I’m not going to discuss them again:
Hub(config)#interface Tunnel0
Let’s do two quick checks, we want to make sure that both spokes are registered to the hub:
     1 192.168.123.2      172.16.123.2    UP 00:22:37     D
     1 192.168.123.3      172.16.123.3    UP 00:00:32     D
And we want to make sure that we can ping all tunnel IP addresses:
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
Now we can focus on the RIP configuration…
RIP
Let’s enable RIP on all routers:
Hub(config)#router rip
Hub(config-router)#version 2
Hub(config-router)#network 1.0.0.0
Hub(config-router)#network 172.16.0.0
Spoke1(config)#router rip
Spoke1(config-router)#network 172.16.0.0
Spoke2(config)#router rip
Spoke2(config-router)#network 3.0.0.0
Spoke2(config-router)#network 172.16.0.0
Now let’s see what we have…
Hub#show ip route rip
R        2.2.2.2 [120/1] via 172.16.123.2, 00:00:07, Tunnel0
R        3.3.3.3 [120/1] via 172.16.123.3, 00:00:06, Tunnel0
Our hub router has learned both networks on the loopback interfaces. Take a good look at the next hop IP addresses that we have here, these are the tunnel addresses. When the hub wants to reach these networks, it will have to check NHRP to find the NBMA addresses:
Hub#show dmvpn | begin Hub
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:29:29     D
     1 192.168.123.3      172.16.123.3    UP 00:07:24     D
When we want to reach 2.2.2.2/2 we will use 172.16.123.2 as the next hop. In our NHRP cache we see that we need to use NBMA address 192.168.123.2 to get there.
What about the spoke routers, did they learn anything?
Spoke1#show ip route rip
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:17, Tunnel0
Spoke2#show ip route rip
R        1.1.1.1 [120/1] via 172.16.123.1, 00:00:08, Tunnel0
Our spoke routers only have one entry, the network on the loopback interface of the hub router. What went wrong here?
🔥 2384 people registered in the last 30 days
Tags: , ,
  1. Hallo Rene how did u config the tunnel?because it got the ip address of 172.16.123.in your configuration u only did HUB and the 2 SPOKES
  2. Hi Rene,
    Would you kindly help explain, where is the router interface IP network in RIP and how does it fit in the dynamic routing protocol as we only advertised the lO0’s as well as the tunnel IP’s
    Thanks you,
    Safwan
  3. Hi Safwan,
    What exactly do you mean with “router interface IP network” ?
    By advertising the loopback interfaces and enabling RIP on the tunnel interfaces, we have everything we need for the routers to learn each others loopback networks.
  4. Hi Rene,
    I meant network 192.168.123.x
