OSPFv3 Authentication and Encryption
OSPFv3 doesn’t have an authentication field in its header like OSPFv2 does, instead it relies on IPsec to get the job done.
IPsec supports two encapsulation types. The first one is AH (Authentication Header) which as the name implies, authenticates the header. The other encapsulation type is ESP (Encapsulating Security Payload) which encrypts packets. We can use both for OSPFv3 so besides authentication, encryption is also a possibility.
In this lesson I’ll show you how to configure both options.
We will use the following topology for this:
OSPFv3 R1 R2 Area 0
We only need two routers for this demonstration. I will only use the link-local IPv6 addresses on these two routers. Let’s enable OSPFv3:
R1 & R2#
(config)#interface FastEthernet 0/0
(config-if)#ipv6 ospf 1 area 0
Now we can play with authentication…
IPsec Authentication
To get started we have to use the ipv6 ospf authentication command:
R1(config-if)#ipv6 ospf authentication ?
ipsec Use IPsec authentication
null Use no authentication
Since we want authentication, we’ll select ipsec:
R1(config-if)#ipv6 ospf authentication ipsec ?
  spi  Set the SPI (Security Parameters Index)
First we have to choose a SPI. You can pick any number you like but it has to match on both routers. Let’s pick the lowest available number (256):
R1(config-if)#ipv6 ospf authentication ipsec spi 256 ?
  md5   Use MD5 authentication
  sha1  Use SHA-1 authentication
Now we can choose what authentication we would like, MD5 or SHA1. SHA1 is more secure so let’s select that:
R1(config-if)#ipv6 ospf authentication ipsec spi 256 sha1 ?
  0           The key is not encrypted (plain text)
  7           The key is encrypted
  Hex-string  SHA-1 key (40 chars)
Now we have to type in a key string ourselves. Normally IPsec uses IKE (Internet Key Exchange) for the security association between two devices. However since we can have multiple OSPFv3 neighbors on a single segment we can’t use IKE and we’ll have to use a static key instead.
For this example I will use an online SHA1 generator to generate a key but for a production network you really should use a safer method to generate a key. Let’s enter that key:
R1(config-if)#ipv6 ospf authentication ipsec spi 256 sha1 A5DEC4DD155A695A8B983AACEAA5A97C6AECB6D1
As soon as you do this the OSPFv3 neighbor adjacency will drop so let’s copy and paste the same line on R2:
R2(config)#interface FastEthernet 0/0
R2(config-if)#ipv6 ospf authentication ipsec spi 256 sha1 A5DEC4DD155A695A8B983AACEAA5A97C6AECB6D1
That should do the job.
It’s also possible to configure authentication for the entire area. If you want this you’ll have to use the area 0 authentication command under the OSPFv3 process.
let’s verify our work:
R1#show ipv6 ospf interface FastEthernet 0/0 | include auth
  SHA-1 authentication SPI 256, secure socket UP (errors: 0)
R2#show ipv6 ospf interface FastEthernet 0/0 | include auth
If you look at the OSPF specific information on the interface then you can see that authentication has been enabled. Since we are using IPsec, you can also check the security associations:
R1#show crypto ipsec sa
interface: FastEthernet0/0
    Crypto map tag: (none), local addr ::
   IPsecv6 policy name: OSPFv3-1-256
   IPsecv6-created ACL name: FastEthernet0/0-ipsecv6-ACL
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (FE80::/10/89/0)
   remote ident (addr/mask/prot/port): (::/0/89/0)
   current_peer :: port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 50, #pkts encrypt: 50, #pkts digest: 50
    #pkts decaps: 31, #pkts decrypt: 31, #pkts verify: 31
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: ::,
     remote crypto endpt.: ::
     path mtu 1500, ipv6 mtu 1500, ipv6 mtu idb FastEthernet0/0
     current outbound spi: 0x100(256)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
      spi: 0x100(256)
        transform: ah-sha-hmac ,
        in use settings ={Transport, }
        conn id: 2001, flow_id: NETGX:1, sibling_flags 80000001, crypto map: (none)
        no sa timing
        replay detection support: N
        Status: ACTIVE
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
      spi: 0x100(256)
        conn id: 2002, flow_id: NETGX:2, sibling_flags 80000001, crypto map: (none)
        no sa timing
        Status: ACTIVE
     outbound pcp sas:
Above you can see our SPI number and that we are using SHA authentication. There’s one more useful command:
R1#show crypto ipsec policy
Crypto IPsec client security policy data
Policy name:      OSPFv3-1-256
Policy refcount:  1
Inbound  AH SPI:  256 (0x100)
Outbound AH SPI:  256 (0x100)
Inbound  AH Key:  A5DEC4DD155A695A8B983AACEAA5A97C6AECB6D1
Outbound AH Key:  A5DEC4DD155A695A8B983AACEAA5A97C6AECB6D1
Transform set:    ah-sha-hmac
This gives us a nice overview with our authentication method, SPI and keys. If you are interested, here’s a wireshark capture of our authenticated OSPFv3 packets:
Frame 5: 100 bytes on wire (800 bits), 100 bytes captured (800 bits)
Raw packet data
Internet Protocol Version 6, Src: fe80::21d:a1ff:fe8b:36d0 (fe80::21d:a1ff:fe8b:36d0), Dst: ff02::5 (ff02::5)
    0110 .... = Version: 6
    .... 1110 0000 .... .... .... .... .... = Traffic class: 0x000000e0
    .... .... .... 0000 0000 0000 0000 0000 = Flowlabel: 0x00000000
    Payload length: 60
    Next Header: Authentication Header (51)
    Hop limit: 1
    Source: fe80::21d:a1ff:fe8b:36d0 (fe80::21d:a1ff:fe8b:36d0)
    [Source SA MAC: Cisco_8b:36:d0 (00:1d:a1:8b:36:d0)]
    Destination: ff02::5 (ff02::5)
    [Source GeoIP: Unknown]
    [Destination GeoIP: Unknown]
    Next Header: OSPF IGP (0x59)
    Length: 24
    AH SPI: 0x00000100
    AH Sequence: 37
    AH ICV: ab40a9a153af39447418edcd
Open Shortest Path First
    OSPF Header
        Version: 3
        Message Type: Hello Packet (1)
        Packet Length: 36
        Source OSPF Router: 1.1.1.1 (1.1.1.1)
        Area ID: 0.0.0.0 (0.0.0.0) (Backbone)
        Checksum: 0x2212 [correct]
        Instance ID: IPV6 unicast AF (0)
        Reserved: 00
    OSPF Hello Packet
        Interface ID: 3
        Router Priority: 1
        Options: 0x000013 (R, E, V6)
        Hello Interval [sec]: 10
        Router Dead Interval [sec]: 40
        Designated Router: 0.0.0.0 (0.0.0.0)
        Backup Designated Router: 0.0.0.0 (0.0.0.0)
Above you can see the authentication header. If you want to take a look for yourself then you can find the capture file here.
R1
hostname R1
ipv6 unicast-routing
interface fastEthernet 0/0
 ipv6 enable
 ipv6 ospf 1 area 0
ipv6 router ospf 1
 router-id 1.1.1.1
R2
hostname R2
 ipv6 enable
 ipv6 ospf 1 area 0
ipv6 router ospf 1
 router-id 2.2.2.2
IPsec Encryption
Let’s take a look at the second method, using IPsec ESP to authenticate and encrypt OSPFv3 traffic. Let’s get rid of the current IPsec AH configuration:
R1 & R2#
(config-if)no ipv6 ospf authentication ipsec spi 256 sha1 A5DEC4DD155A695A8B983AACEAA5A97C6AECB6D1
Now we can enable ESP, there’s a different command we have to use:
🔥 2352 people registered in the last 30 days
  1. Rene, do you have IPSEC lesson?
  2. Is the “0” or “7” option relating to whether or not the running-config file saves the key as encrypted or clear text?
  3. Hello Chris
    Options 0 and 7 refer to whether or not the key that is sent between the routers during the authentication process is encrypted. In order to encrypt the key in the configuration file, use the system password-encryption command. This command encrypts authentication key passwords among others.
  4. Hi,
    does this means IPsec is the only way to authenticate in OSPFv3?
    I tried with the following and it worked:
    R2#interface Ethernet0/0
    no ip address
    ipv6 address 2001::2/64
    ospfv3 1 authentication key-chain CISCO
    ospfv3 1 ipv6 area 0
    R2#show ospfv3 ipv6
    OSPFv3 1 address-family ipv6
    Router ID 2.2.2.2
    Active Key-chains:
      Key chain CISCO: Send key 1, Algorithm HMAC-SHA-1, Number of interfaces 1
        Area BACKBONE(0)
    thanks
    Edit: This post gives the idea that OSPFv3 does not support any authentication beside IPsec, but after checking it does support t
20 more replies! Ask a question or join the discussion by visiting our Community Forum
