DMVPN Phase 2 BGP Routing
The first DMVPN lesson explained the basics and I explained how to configure a basic DMVPN phase 2 network. I also created an example for BGP on DMVPN phase 1 networks.
In this lesson we’ll take a look how we can use BGP on DMVPN phase 2 networks. Here is the topology we will use:
One hub router and two spoke routers, each has a loopback interface which we will advertise in BGP.
Tunnel interfaces
Let’s start with the tunnel on the hub router:
Hub(config)#interface Tunnel0
Hub(config-if)#end
Here are the spoke routers:
Let’s make sure the spokes have registered with the hub:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:09:48     D
     1 192.168.123.3      172.16.123.3    UP 00:09:56     D
And that we can ping our spoke routers:
Hub#ping 172.16.123.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/7/11 ms
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/7/10 ms
Everything is working, time for BGP.
eBGP
We will start with external BGP. This will work but it has one disadvantage:
Spoke routers have to learn each others networks if we want direct spoke-to-spoke communication. This means we can’t use the same AS on all spoke routers since they would not accept prefixes that have the same AS number in the AS path.
We will need a different AS number for each spoke router, this means we can’t use dynamic neighbors so we’ll have to configure them manually.
Here’s what it looks like:
Hub(config)#router bgp 65001
Hub(config-router)#neighbor 172.16.123.2 remote-as 65002
Hub(config-router)#neighbor 172.16.123.3 remote-as 65003
Hub(config-router)#network 1.1.1.1 mask 255.255.255.255
Spoke1(config)#router bgp 65002
Spoke1(config-router)#neighbor 172.16.123.1 remote-as 65001
Spoke1(config-router)#network 2.2.2.2 mask 255.255.255.255
Spoke2(config)#router bgp 65003
Spoke2(config-router)#neighbor 172.16.123.1 remote-as 65001
Spoke2(config-router)#network 3.3.3.3 mask 255.255.255.255
Let’s see what we find in the routing tables:
Hub#show ip route bgp
B        2.2.2.2 [20/0] via 172.16.123.2, 00:01:00
B        3.3.3.3 [20/0] via 172.16.123.3, 00:01:00
Spoke1#show ip route bgp
B        1.1.1.1 [20/0] via 172.16.123.1, 00:01:04
B        3.3.3.3 [20/0] via 172.16.123.3, 00:00:34
Spoke2#show ip route bgp
B        1.1.1.1 [20/0] via 172.16.123.1, 00:01:08
B        2.2.2.2 [20/0] via 172.16.123.2, 00:01:08
We can find all prefixes in the routing tables. External BGP also preserves the next hop addresses which is a good thing for us. Let’s try a trace from spoke1 to spoke2:
Tracing the route to 3.3.3.3
  1 172.16.123.3 7 msec 11 msec *
No problem, we can get from spoke1 to spoke2 directly.
If you want the same AS number on all spoke routers then you could use some “dirty” tricks like AS override, allow AS in or remove private AS.
Want to take a look for yourself? Here you will find the eBGP configuration of each device.
Hub
hostname Hub
interface Tunnel0
 no ip redirects
interface GigabitEthernet0/1
 ip address 192.168.123.1 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
router bgp 65001
 bgp log-neighbor-changes
Spoke1
hostname Spoke1
interface Tunnel0
 no ip redirects
 ip address 192.168.123.2 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
router bgp 65002
Spoke2
hostname Spoke2
interface Tunnel0
 no ip redirects
 ip address 192.168.123.3 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
router bgp 65003
iBGP
Let’s try something else now, we’ll go for internal BGP. The advantage of iBGP is that we can use dynamic peers. We need to make sure that prefixes from one spoke router will be advertised to another spoke router. To accomplish this, we’ll configure the hub router as a route reflector:
🔥 2384 people registered in the last 30 days
Tags: , ,
  1. Nice article, Rene!
    I am sure you are gonna create another article about ““dirty” tricks like AS override, allow AS in or remove private AS.” since CCIE is all about details and details and more details.
  2. Am I correct in noting that for iBGP Route-Reflector in a DMVPN env the next hop attribute changes to the spokes but in a normal non dmvpn route reflector env the next hop attribute DOES NOT change.
  3. Michael,
    In both environments, the iBGP route-reflector should not change the next hop attribute, and the reason in both cases is the same. By having the RR change the next hop, the RR would necessarily be putting itself in the data plane. In most cases, it is preferable to have the RR act only in the control plane so the most efficient path can be taken.
    The tricky part about BGP in a DMVPN environment is accounting for knowledge of the next hops by all BGP clients. As you know, in BGP, if an advertised route has an inaccessible next hop, BGP will not insta
  4. Great article
    quick question concerning the ebgp configuration, i can see that in the routing table the next hop is not passing through the hub. however i can see that the AS path still mention the hub …even if the next hop is not the hub.
    is it the normal behavior ?
12 more replies! Ask a question or join the discussion by visiting our Community Forum
