DMVPN Phase 1 Basic Configuration
In the first lesson about DMVPN I explained some of the basics of how multipoint GRE, NHRP and the different phases work. In this lesson, I’ll show you how to configure DMVPN phase 1. We will then use this configuration in some other examples where we try to run RIP, OSPF, EIGRP and BGP on top of it. Here’s the topology that we will use:
Hub, Spoke1 and Spoke2 connected through a cloud on 192.168.123.0/24, with a multipoint tunnel on 172.16.123.0/24
Above we have three routers, a hub and two spoke routers. The underlay network uses subnet 192.168.123.0/24 and the overlay network (our tunnel interfaces) will use 172.16.123.0/24.
In my example, I’m using a switch to connect the GigabitEthernet0/1 interfaces of the routers to each other. In a real network, these would be interfaces that connect to your ISP and would (probably) have a public IP address.
Let’s take a look at the configuration!
Hub
We will start with the hub configuration. Here’s what it looks like:
Hub(config)#interface Tunnel 0
Hub(config-if)#tunnel source Gigabit0/1
Let me explain the commands above:
  • tunnel mode: by default the tunnel mode will be point-to-point GRE, we require a multipoint interface on the hub.
  • tunnel source: the tunnel destinations will be dynamic but we still have to configure the source, our Gigabit0/1 interface.
  • ip nhrp authentication: we can authenticate our NHRP traffic, it’s optional but a good idea to enable. I’m using pre-shared key “DMVPN”.
  • ip nhrp map multicast dynamic:  this command tells the hub router where to forward multicast packets to. Since the IP addresses of the spoke routers are unknown, we use dynamic to automatically add their IP addresses to the multicast destination list when the spokes register themselves.
  • ip nhrp network-id: this command enables NHRP on the tunnel interface, so it is required even with a single DMVPN network. When you use multiple DMVPN networks, the network ID also differentiates between them. This value is only locally significant but for troubleshooting reasons it’s best to use the same value on all routers.
After a few seconds you will see the tunnel becoming active:
Hub#
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
We are now ready to configure some spoke routers…
Spokes
Let’s start with spoke1, here’s what the configuration looks like:
Spoke1(config)#interface tunnel 0
Spoke1(config-if)#tunnel source Gigabit0/1
Some of the commands are the same as on the hub, let me explain the commands that are different:
  • ip nhrp map: we use this on the spoke to create a static mapping for the hub’s tunnel address (172.16.123.1) and the hub’s NBMA address (192.168.123.1). This will be stored in the NHRP cache of the spoke router.
  • ip nhrp map multicast: here we specify which destinations should receive broadcast or multicast traffic through the tunnel interface. The confusing part is that you have to enter the NBMA address here. We need this command since routing protocols like RIP, EIGRP and OSPF require multicast.
  • ip nhrp nhs: this is where we specify the NHRP server, our hub router.
  • tunnel destination: we are using point-to-point GRE so we need to specify a destination for the tunnel, this will be the hub router.
After a few seconds you will see the tunnel interface:
Spoke1#
Our tunnel interfaces are up and running but we should check if our spoke has registered with the hub:
Hub#show dmvpn
	C - CTS Capable
Type:Hub, NHRP Peers:1,
     1 192.168.123.2      172.16.123.2    UP 00:03:36     D
This is looking good, when you use the show dmvpn command you can see the NHRP cache of our hub. It shows us that our spoke with tunnel address 172.16.123.2 has registered its NBMA address 192.168.123.2. Another command that gives us this information is show ip nhrp:
Hub#show ip nhrp
172.16.123.2/32 via 172.16.123.2
   Tunnel0 created 00:04:02, expire 01:55:57
   Type: dynamic, Flags: unique registered used nhop
   NBMA address: 192.168.123.2
Let’s take a closer look at the NHRP registration from the spoke to the hub, we’ll enable a debug for this:
Hub & Spoke1
#debug nhrp
NHRP protocol debugging is on
To see the registration, I shut both tunnel interfaces. Then activate the hub tunnel interface first and the spoke router a few seconds later. Here’s what you will see:
NHRP: Receive Registration Request via Tunnel0 vrf global(0x0), packet size: 105
NHRP: Tunnels gave us pak src: 192.168.123.2
NHRP: Could not find AVL node for vrf:global(0x0)
NHRP: Inserted node for vrf global(0x0)
NHRP: Initialized cache radix head for vrf global(0x0)
NHRP: Adding Tunnel Endpoints (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP:
NHRP: Peer capability:0
NHRP: NHRP subblock already exists for Tunnel Endpoints (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP: Cache already has a subblock node attached for Tunnel Endpoints (VPN: 172.16.123.2, NBMA: 192.168.123.2)
NHRP: Enqueued dynamic mapping to end of list
NHRP: Tu0: Creating dynamic multicast mapping  NBMA: 192.168.123.2
NHRP: Added dynamic multicast mapping for NBMA: 192.168.123.2
NHRP: Attempting to send packet through interface Tunnel0 via DEST  dst 172.16.123.2
NHRP: Send Registration Reply via Tunnel0 vrf global(0x0), packet size: 125
      src: 172.16.123.1, dst: 172.16.123.2
NHRP: Encapsulation succeeded.  Sending NHRP Control Packet  NBMA Address: 192.168.123.2
NHRP: 149 bytes out Tunnel0
NHRP: nhrp_subblock_check_for_map() - Map Already Exists
This produces a lot of debug information. You can see that the hub receives a NHRP registration from the spoke and that it adds a multicast entry. Here’s what it looks like on the spoke:
Spoke1#
NHRP: if_up: Tunnel0 proto 'NHRP_IPv4'
NHRP: Registration with Tunnels Decap Module succeeded
NHRP: Adding all static maps to cache
NHRP: Adding multicast map entry to multicast list 192.168.123.1
NHRP: No SNMP node found to add requestID
NHRP: Multicast enabled for dst 192.168.123.1
NHRP: NHS 172.16.123.1 Tunnel0 vrf 0 Cluster 0 Priority 0 Transitioned to 'E' from ' '
NHRP: Attempting to send packet through interface Tunnel0 via DEST  dst 172.16.123.1
NHRP: Send Registration Request via Tunnel0 vrf global(0x0), packet size: 105
      src: 172.16.123.2, dst: 172.16.123.1
NHRP: 129 bytes out Tunnel0
NHRP: Receive Registration Reply via Tunnel0 vrf global(0x0), packet size: 125
NHRP: NHS 172.16.123.1 Tunnel0 vrf 0 Cluster 0 Priority 0 Transitioned to 'RE' from 'E'
NHRP: NHS-UP: 172.16.123.1
Above we can see that the spoke adds an entry in its local NHRP cache and tries to send the NHRP registration message, it succeeds and receives the NHRP registration reply from the hub. Here’s what these packets look like in wireshark:
  • Full Access to 448 lessons.
Tags: , ,
  1. Avatar for norman norman says:
    Hi !
    Now i am on this , i get this debug message
    Packet received via GigabitEthernet1/0, not configured for NHRPsrc 192.168.123.3 dst 192.168.123.1
    *Dec 20 16:38:12.083: NHRP: Pak out GigabitEthernet1/0 would leave logical NBMA network
    I have tried with giga int as source also..but the same. I was wodering if it is the platform i am using in GNS3
    Hmm I haven’t seen that message before but I think it’s probably a misconfiguration.
  3. Avatar for norman norman says:
    Hi !
    it works …but i cant use "sh dmvnp " ?
    change to Cisco IOS Software, 3600 Software (C3640-IK9O3S-M)
    try “show dmvpn” instead? :slight_smile:
  5. Avatar for csoler csoler says:
    Great article!!!
    Possible minor typo when giving further details about the spoke configuration:
    “ip nhrp map: we use this on the spoke to create a static mapping for the hub’s tunnel address (172.16.123.2) and the hub’s NBMA address (192.168.123.1). This will be stored in the NHRP cache of the spoke router.”
    I think the tunnel address should read “172.16.123.1”
    C
