DMVPN Phase 3 EIGRP Routing
In the first DMVPN lesson we discussed the basics and the different phases. I also showed you how to configure DMVPN phase 1, phase 2 and phase 3. In this lesson we’ll take a look how we can configure EIGRP on a DMVPN phase 3 network.
Here’s the topology we will use:
Above we have a hub and two spoke routers. Each router has a loopback interface which we will advertise in EIGRP.
Tunnel interfaces
Below you will find the configuration of the tunnel interfaces. This is a basic DMVPN phase 3 setup:
Hub(config)#interface Tunnel0
Spoke1(config-if)#ip nhrp shortcut
Let’s do a quick test to make sure the hub has two NHRP registrations from the spoke routers:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:00:04     D
     1 192.168.123.3      172.16.123.3    UP 00:00:03     D
That’s looking good, let’s do a quick ping:
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/7/8 ms
Time to configure EIGRP…
EIGRP
First we advertise all tunnel interfaces and the loopback interfaces of the spoke routers in EIGRP:
Hub(config)#router eigrp 123
Hub(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config)#router eigrp 123
Spoke1(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config-router)#network 2.2.2.2 0.0.0.0
Spoke2(config)#router eigrp 123
Spoke2(config-router)#network 172.16.123.0 0.0.0.255
Spoke2(config-router)#network 3.3.3.3 0.0.0.0
The spoke routers don’t require specific entries thanks to NHRP traffic indication. I will advertise a default route on the hub router:
Hub(config)#interface tunnel 0
Hub(config-if)#ip summary-address eigrp 123 0.0.0.0 0.0.0.0
Let’s check the routing tables:
Hub#show ip route eigrp
D*    0.0.0.0/0 is a summary, 00:00:19, Null0
D        2.2.2.2 [90/27008000] via 172.16.123.2, 00:01:19, Tunnel0
D        3.3.3.3 [90/27008000] via 172.16.123.3, 00:00:19, Tunnel0
Spoke1#show ip route eigrp
D*    0.0.0.0/0 [90/28160000] via 172.16.123.1, 00:00:31, Tunnel0
Spoke2#show ip route eigrp
D*    0.0.0.0/0 [90/28160000] via 172.16.123.1, 00:00:43, Tunnel0
The hub has two specific entries, the spoke routers only have a default route. Let’s see if direct spoke-to-spoke communication is possible:
Tags: , ,
  1. Hello René.
    Great basic DMVPN lab but i have a request:
    A DMVPN lab with 2 ISP’s (Multihoming) and load balancing using EIGRP Add-Path Support. I have had a hard time understanding the concept of that.
  2. Hi Rene,
    If I want to migrate DMVPN phase 2 to phase 3 with EIGRP configured … what are the 3 changes that need to be done ??
  3. Hi Shashi,
    For a detailed answer you can take a look here:
    DMVPN Phase 3
    DMVPN Phase 3 EIGRP
    The short answer is this:
    Spoke(config)#interface Tunnel 0
    And you need to advertise a summary route on the hub towards your spoke routers that covers the networks behind your spoke routers.
  4. I’m using the IOS image you said you were but for some reason when i try show ip route nhrp it doesn’t recognize “nhrp”
    R2#sho ip route nhrp
    Translating "nhrp"
    Also my dmvpn table looks a bit different but still says two entries only displays one line for them
    R2#show dmvpn
    Legend: Attrb --> S - Static, D - Dynamic, I - Incompletea
    Tunnel0, Type:Spoke, NHRP Peers:2,
     # Ent
18 more replies! Ask a question or join the discussion by visiting our Community Forum
