BGP Multipath load sharing iBGP and eBGP
Unlike most routing protocols, BGP only selects a single best path for each prefix. It doesn’t do ECMP (Equal Cost Multi-Path Routing) by default, but it is possible to enable this.
For BGP to use the second path, the following attributes have to match:
Also, the next hop address for each path must be different. This comes into play when you are multihomed to the same router.
In this lesson, I’ll show you how to configure eBGP and iBGP to use more than one path.
We’ll start with two eBGP scenarios.
eBGP
When it comes to eBGP, there are two options:
  • Multiple paths to the same AS.
  • Multiple paths to different ASes.
Same AS
Let’s look at a scenario where we have two paths to the same AS. Here’s the topology:
R1 in AS 1 connected to R2 and R3 in AS 23
R1 is in AS 1  and connected to R2/R3 in AS23. R1 will have paths to get to 192.168.23.0/24.
R1
hostname R1
ip cef
interface GigabitEthernet0/1
interface GigabitEthernet0/2
router bgp 1
 neighbor 192.168.12.2 remote-as 23
 neighbor 192.168.13.3 remote-as 23
R2
hostname R2
ip cef
router bgp 23
 network 192.168.23.0 mask 255.255.255.0
 neighbor 192.168.23.3 remote-as 23
R3
hostname R3
ip cef
router bgp 23
 neighbor 192.168.13.1 remote-as 1
 neighbor 192.168.23.2 remote-as 23
Here’s the BGP table of R1:
R1#show ip bgp
BGP table version is 2, local router ID is 192.168.13.1
              t secondary path,
 *    192.168.23.0     192.168.13.3                           0 23 i
 *>                    192.168.12.2             0             0 23 i
R1 has two equal paths but decided to install the path to R2. We can enable load balancing with the maximum-paths command:
R1(config)#router bgp 1
R1(config-router)#maximum-paths 2
Let’s take another look at the BGP table:
R1#show ip bgp
BGP table version is 3, local router ID is 192.168.13.1
              t secondary path,
 *m   192.168.23.0     192.168.13.3                           0 23 i
Now we have two entries. Note the “m” that stands for multipath. Both paths are installed in the routing table:
R1#show ip route bgp
B     192.168.23.0/24 [20/0] via 192.168.13.3, 00:13:02
                      [20/0] via 192.168.12.2, 00:13:02
That’s looking good.
Different AS
Let’s look at another eBGP scenario. This time, we have multiple AS numbers:
R1 in AS 1 reaches 4.4.4.4/32 on R4 in AS 4 through R2 in AS 2 or R3 in AS 3
R1 can go through AS 3 or AS 2 to get to 4.4.4.4/32 in AS 4.
R1
hostname R1
ip cef
router bgp 1
 neighbor 192.168.13.3 remote-as 3
R2
hostname R2
ip cef
router bgp 2
 neighbor 192.168.24.4 remote-as 4
R3
hostname R3
ip cef
router bgp 3
 neighbor 192.168.34.4 remote-as 4
R4
hostname R4
ip cef
router bgp 4
 network 4.4.4.4 mask 255.255.255.255
 neighbor 192.168.24.2 remote-as 2
 neighbor 192.168.34.3 remote-as 3
R1#show ip bgp
              t secondary path,
 *    4.4.4.4/32       192.168.13.3                           0 3 4 i
 *>                    192.168.12.2                           0 2 4 i
R1 has installed R2 as its next hop address. Let’s see if we can change that:
This command alone, however, doesn’t help:
R1#show ip bgp
*Mar 21 11:10:13.118: %SYS-5-CONFIG_I: Configured from console by console
              t secondary path,
The problem here is that we have two different AS numbers, AS 2 and AS 3. We can tell BGP to “relax” its requirement of having the same AS path numbers and AS path length to only checking the AS path length. This can be done with the following hidden command:
  • Full Access to 448 lessons.
  1. Avatar for pavanc.08 pavanc.08 says:
    still multipath is not enabling. below is the config.
    R1#show run | section bgp
    router bgp 1
    maximum-paths 2
    no auto-summary
    BGP Table:
    R1#show ip bgp
    r RIB-failure, S Stale
    Hi Pavan,
    That is interesting. What IOS version do you have? The version you see is the version number of the BGP table, not BGP itself.
  3. Avatar for Zaman.rubd Zaman.rubd says:
    Some confusion please clarify the below sentence:
    We can tell BGP to “relax” its requirement of having the same AS path numbers and AS path length to only checking the AS path length and "AS Path (both AS number and AS path length)
    So, If only AS-PATH is identical/same length then we can do BGP load sharing right ?
    br//zaman
    Hi Zaman,
    By default, BGP doesn’t want to load balance over two paths if the AS number is not the same. However, when you add the bgp bestpath as-path multipath-relax command then we remove that requirement. The only thing that remains is that the AS path length has to be the same.
  5. Avatar for sims sims says:
    What will happen to return traffic from r2 or r3 to r1 in single AS case
    thanks
52 more replies! Ask a question or join the discussion by visiting our Community Forum
