OSPF Reference Bandwidth
OSPF uses a simple formula to calculate the OSPF cost for an interface with this formula:
cost = reference bandwidth / interface bandwidth
The reference bandwidth is a value in Mbps that we can set ourselves. By default, this is 100Mbps on Cisco IOS routers. The interface bandwidth is something we can look up.
Let’s take a look at an example of how this works. I’ll use this router:
Router R1 with a FastEthernet interface Fa0/0 and a serial interface S0/0
The router above has two interfaces, a FastEthernet and a serial interface:
R1#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.1.1     YES manual up                    up
Serial0/0                  192.168.2.1     YES manual up                    up
Let’s enable OSPF on these interfaces:
R1(config)#router ospf 1
R1(config-router)#network 192.168.1.0 0.0.0.255 area 0
R1(config-router)#network 192.168.2.0 0.0.0.255 area 0
After enabling OSPF, we can check what the reference bandwidth is:
Router#show ip ospf | include Reference
 Reference bandwidth unit is 100 mbps
By default, this is 100 Mbps. Let’s see what cost values OSPF has calculated for our two interfaces:
Router#show interfaces FastEthernet 0/0 | include BW
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec
Router#show ip ospf interface FastEthernet 0/0 | include Cost
  Process ID 1, Router ID 192.168.1.1, Network Type BROADCAST, Cost: 1
The FastEthernet interface has a bandwidth of 100,000 kbps (100 Mbps), and the OSPF cost is 1. The formula to calculate the cost looks like this:
100.000 kbps reference bandwidth / 100.000 interface bandwidth = 1
What about the serial interface? Let’s find out:
R1#show interfaces Serial 0/0 | include BW
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
R1#show ip ospf interface Serial 0/0 | include Cost
  Process ID 1, Router ID 192.168.2.1, Network Type POINT_TO_POINT, Cost: 64
The serial interface has a bandwidth of 1.544 kbps (1.5 Mbps) and a cost of 64. It was calculated like this:
100,000 kbps reference bandwidth / 1,544 kbps interface bandwidth = 64.76
It was rounded down to 64.
The default reference bandwidth of 100 Mbps can cause issues if you use Gigabit or 10 Gigabit interfaces. The lowest possible cost value is one so with the default reference bandwidth, a FastEthernet, Gigabit, and 10 Gigabit interface would have an OSPF cost of 1.
If you use Gigabit interfaces (or 10 Gigabit), then it’s better to change the reference bandwidth. You can do it like this:
Router(config-router)#auto-cost reference-bandwidth ?
  <1-4294967>  The reference bandwidth in terms of Mbits per second
Use the auto-cost reference-bandwidth command and specify the value you want in Mbps. Let’s set it to 1000 Mbps:
Router(config-router)#auto-cost reference-bandwidth 1000
% OSPF: Reference bandwidth is changed.
        Please ensure reference bandwidth is consistent across all routers
Cisco IOS will warn you that you should do this on all OSPF routers. Let’s verify our work:
 Reference bandwidth unit is 1000 mbps
Our reference bandwidth is now 1000 Mbps. Let’s see what the cost of our FastEthernet is now:
  Process ID 1, Router ID 192.168.1.1, Network Type BROADCAST, Cost: 10
  Topology-MTID    Cost    Disabled    Shutdown      Topology Name
It now has a cost of 10 which means that a Gigabit interface would end up with a cost of 1.
Want to take a look for yourself? Here you will find the final configuration of R1.
  1. Avatar for navn1 navn1 says:
    well explained.
  2. Avatar for scott_leport scott_leport says:
    “It now has a cost of 1 which means that a Gigabit interface would end up with a cost of 1.”
    Did you mean 10? :wink:
    Oops yes :slight_smile: Just fixed it! Thanks Scott.
  4. Avatar for husamshabeebit husamshabeebit says:
    check this command its not working
    this one is working
    Router#show ip protocols | include Reference
  5. Avatar for ivoaleksiev ivoaleksiev says:
    Hey Rene,
    I’ve seen auto-cost reference-bandwidth as well as reference-bandwidth.
    Is there any difference between those two commands or are they just IOS version dependent?
    Thank you!
29 more replies! Ask a question or join the discussion by visiting our Community Forum
