DMVPN Phase 2 Basic Configuration
In the first lesson about DMVPN we discussed the basics of multipoint GRE and NHRP. The second lesson was a basic configuration of DMVPN phase 1. This time i’ll explain how you can configure DMVPN phase 2. Once we have a basic configuration then we can try to run RIP, EIGRP, OSPF and BGP on top of it.
The configuration of DMVPN phase 1 and 2 is similar except for two key items:
  • The spoke routers will now use multipoint GRE interfaces instead of point-to-point GRE interfaces.
  • We don’t configure a manual destination anymore on the spoke routers.
That’s it, those two changes make the difference between running DMVPN phase 1 or 2.  Let’s take a look at the configuration. Here’s the topology we will use:
dmvpn-example-topology
Above we have one hub router and two spoke routers. We use 192.168.123.0/24 as the underlay network and 172.16.123.0/24 as the overlay network.
Let’s start with the hub configuration:
Hub(config)#interface Tunnel0
Hub(config-if)#end
The configuration of the hub above is exactly the same as in DMVPN phase 1, no changes here. Let’s look at the spoke routers:
The configuration above is exactly the same as in DMVPN phase 1 except for two commands:
  • We removed the tunnel destination command.
  • We added the tunnel mode command to use GRE multipoint.
That’s it! We now have a DMVPN phase 2 network. Let’s verify our work…
Verification
First we should check if the hub has received some NHRP registrations from the spoke routers:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:09:48     D
     1 192.168.123.3      172.16.123.3    UP 00:09:56     D
Above we see two registrations with the NBMA and tunnel addresses of our spoke routers. Let’s use the same command on the spoke routers:
Tags: , ,
  1. Thanks for the good explanation Rene. I am using Cisco 7200 with IOS version 12.4(24g) but show dmvpn command is not working. Other configuration commands to setup DMVPN worked.
    R1#show dmvpn
    R1#
  2. Hello Abhishek
    It seems that this command is not available in your IOS version. You can see from the following Cisco CLI reference, that the command was introduced in the T train of code and not in the mainline which is your IOS version.
    https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/s1/sec-s1-cr-book/sec-cr-s4.html#wp2815505246
    Even so, this is simply a show command that conveniently displays the components of the topology. You can still obtain the same information with a variety of other show commands such as those indicated in the following Cis
  3. Hello Rene
    Hope you doing great.
    On show dmvpn output I see Attrb → S for Spokes routers meaning that the NBMA peer Address is learned Statically.
    Shouldn’t be Attrb → S like the Hub router?
    Thank you in advance!
    Victor
  4. Hello Victor
    When you use DMVPN with NHRP in the configuration found in the lesson, on each spoke you use the following command:
    ip nhrp map <tunnel address> <hub NBMA address>
    This creates a static peer address, and that’s why you see the “S” indicator on the spoke router. This is considered a statically configured NBMA peer address.
    On the hub, however, you have no such configuration. The hub is configured to accept NHRP requests to dynamically add the addresses of the spokes. For this reason, on the Hub, you will see the “D” designation that these are dyn
  5. Hi Laz,
    Please explain the commands by taking example of IPs we used in n/w topology for DMVPN.
    1. ip nhrp map 172.16.123.1 192.168.123.1
    2. ip nhrp map multicast 192.168.123.1
      3)ip nhrp nhs 172.16.123.1 ( why are we using tunnel address here, it should be
      public ip)
    3. diff b/w ip nhrp map multicast dynamic and ip nhrp map multicast
      192.168.123.1
    4. ip nhrp mode multipoint command instead of tunnel destination address.
      we know tunnel destination command is being used to specify destination
      address but multipoint mean it can be both source and destination ip. so how
      can w
7 more replies! Ask a question or join the discussion by visiting our Community Forum
