DMVPN Phase 3 Basic Configuration
DMVPN supports three different versions called “phases”. In my first DMVPN lesson I explained the basics and  the DMVPN phase 2 configuration and DMVPN phase 1 configuration lessons explain how to configure the first two phases.
This time, I’ll show you how to configure DMVPN phase 3. We’ll use the following topology for this:
dmvpn-example-topology
We have one hub router and two spoke routers.
The configuration of DMVPN phase 3 and 2 is very similar. Let’s start with the following DMVPN phase 2 configuration on all routers:
Hub(config)#interface Tunnel0
To migrate from DMVPN phase 2 to 3, we only need two commands…here’s the first command:
Hub(config)#interface tunnel 0
The NHRP redirect command on the hub will inform spoke routers that they can reach another spoke router directly. The second command is needed on the spoke routers:
  • Unlock Access to 808 lessons by becoming a member.
🔥 2410 people registered in the last 30 days
Tags: , ,
  1. Hi !
    I didnt have “ip nhrp redirect” in my IOS (C3745-ADVENTERPRISEK9_SNA-M) ??? that´s the only one i got..
    /Oskar
  2. Hi Rene,
    What is the advantages using the Phase 3 over Phase 2?
    Try to minimize the routing entry in the spoke router?
    Davis
  3. Hi Davis,
    The main advantage is that you have smaller routing tables. In phase 2, each spoke router requires specific entries for networks it wants to reach behind other spoke routers. With phase 3, a summary route is all you need.
  4. Hi Rene,
    ok. Thanks
    Davis
44 more replies! Ask a question or join the discussion by visiting our Community Forum
