DMVPN Phase 3 BGP Routing
In our first DMVPN lesson we explained the basics and the differences of the three phases. We also looked at an example for a basic DMVPN phase 3 configuration and how to configure RIP, EIGRP and OSPF on top of it.
This time, we are going to look at BGP. Here is the topology we shall use:
DMVPN Hub, Spoke1 and Spoke2 with tunnel 172.16.123.0/24, Gi0/1 192.168.123.x and loopbacks 1.1.1.1, 2.2.2.2 and 3.3.3.3
There is one hub router and two spoke routers. Let’s configure this!
Tunnel Interfaces
Let’s start with a basic DMVPN phase 3 configuration:
Hub(config)#interface Tunnel0
Hub(config-if)#end
Spoke1(config-if)#ip nhrp shortcut
Spoke2(config-if)#ip nhrp shortcut
Let’s make sure the spokes have registered themselves with the hub:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:00:04     D
     1 192.168.123.3      172.16.123.3    UP 00:00:03     D
And let’s check if we can ping the spoke routers:
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/7/8 ms
So far so good, time to configure BGP.
EBGP with same AS number on spokes
This configuration will be similar to what we used for BGP on DMVPN phase 2. Our spoke routers don’t need to know any specific routes so we can use a default route. We’ll use dynamic BGP peers so that we don’t have to configure static neighbors. Let’s start with the default route:
Hub(config)#ip route 0.0.0.0 0.0.0.0 Null0
Hub(config)#ip prefix-list DEFAULT_ROUTE permit 0.0.0.0/0
Hub(config)#route-map SPOKE_ROUTERS permit 10
Hub(config-route-map)#match ip address prefix-list DEFAULT_ROUTE
This route-map will be attached to the spoke routers. Let’s configure the hub:
Hub(config)#router bgp 65001
Hub(config-router)#bgp listen range 172.16.123.0/24 peer-group DMVPN_SPOKES
Hub(config-router)#neighbor DMVPN_SPOKES peer-group
Hub(config-router)#neighbor DMVPN_SPOKES remote-as 65023
Hub(config-router)#neighbor DMVPN_SPOKES route-map SPOKE_ROUTERS out
Hub(config-router)#network 0.0.0.0 mask 0.0.0.0
Our hub router uses a peer group for the spoke routers and we only advertise the default route. Let’s configure the spoke routers:
Spoke1(config)#router bgp 65023
Spoke1(config-router)#neighbor 172.16.123.1 remote-as 65001
Spoke1(config-router)#network 2.2.2.2 mask 255.255.255.255
Spoke2(config)#router bgp 65023
Spoke2(config-router)#neighbor 172.16.123.1 remote-as 65001
Spoke2(config-router)#network 3.3.3.3 mask 255.255.255.255
Now let’s check the routing tables:
Hub#show ip route bgp
B        2.2.2.2 [20/0] via 172.16.123.2, 00:06:32
B        3.3.3.3 [20/0] via 172.16.123.3, 00:06:02
Spoke1#show ip route bgp
B*    0.0.0.0/0 [20/0] via 172.16.123.1, 00:07:05
Spoke2#show ip route bgp
B*    0.0.0.0/0 [20/0] via 172.16.123.1, 00:09:04
The hub sees two specific entries and the spoke routers see the default route. Let’s send some traffic from spoke1 to spoke2:
Tracing the route to 3.3.3.3
  1 172.16.123.3 [AS 65001] 7 msec 7 msec *
This is looking good, traffic goes directly from spoke1 to spoke2. This is all thanks to NHRP which installed some entries in the routing tables:
Spoke1#show ip route | include 3.3.3.3
H        3.3.3.3 [250/255] via 172.16.123.3, 00:02:48, Tunnel0
Spoke2#show ip route | include 2.2.2.2
H        2.2.2.2 [250/255] via 172.16.123.2, 00:02:44, Tunnel0
We can also check the NHRP cache of the spoke routers:
Spoke1#show dmvpn | begin Peer
Type:Spoke, NHRP Peers:2,
     2 192.168.123.3      172.16.123.3    UP 00:02:12   DT1
     1 192.168.123.1      172.16.123.1    UP 00:35:27     S
Spoke2#show dmvpn | begin Peer
     2 192.168.123.2      172.16.123.2    UP 00:02:17   DT1
     1 192.168.123.1      172.16.123.1    UP 00:35:35     S
Above we can see that the spoke routers know about each other’s NBMA addresses.
Want to take a look for yourself? Here you will find the eBGP configuration of each device.
Hub
hostname Hub
interface Tunnel0
 no ip redirects
 ip nhrp redirect
interface GigabitEthernet0/1
 ip address 192.168.123.1 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
router bgp 65001
 bgp log-neighbor-changes
 network 0.0.0.0
ip prefix-list DEFAULT_ROUTE seq 5 permit 0.0.0.0/0
Spoke1
hostname Spoke1
interface Tunnel0
 no ip redirects
 ip nhrp shortcut
 ip address 192.168.123.2 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
router bgp 65023
Spoke2
hostname Spoke2
interface Tunnel0
 no ip redirects
 ip nhrp shortcut
 ip address 192.168.123.3 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
router bgp 65023
IBGP
Instead of eBGP we can also use iBGP. The configuration will be very similar to what we just did. Let’s create a default route on the hub:
  • Full Access to 448 lessons.
Tags: , ,
  1. Avatar for ranjannag ranjannag says:
    I noticed nhrp redirect is missing on the Hub DVMP configuration. Is this optional for DMVPN phase 3?
  2. Avatar for andrew andrew says:
    Hi Nagi,
    Good call! You are 100% correct. DMVPN phase 3 requires “ip nhrp redirect” to be on the hub–in fact the presence of “ip nhrp redirect” on the hub and “ip nhrp shortcut” on the spokes are the key differences in configuration between phase 3 and other phases.
    I suspect Rene just left that out by accident in the main body of the article. You will notice, however, at the bottom in the “tabbed” configuration section for the Hub, it is there.
    It has been fixed now, thanks for sharing!
  4. Avatar for gopalb85 gopalb85 says:
    Do we have this kind of tutorial with VRF ; customer vrf and transport vrf ?
    Gk
    Hi GK,
    Not for DMVPN but there’s a separate VRF lite tutorial:
    https://networklessons.com/mpl...tion-on-cisco-ios
32 more replies! Ask a question or join the discussion by visiting our Community Forum
