Management Plane Protection (MPP)
Management Plane Protection (MPP) is a security feature for Cisco IOS routers that accomplishes two things:
  • Restrict the interfaces where the router permits packets from network management protocols.
  • Restrict the network management protocols that the router permits.
The management plane is the logical path of all traffic related to the management of the router. For example:
  • Telnet
  • SSH
  • SNMP
  • HTTP
  • HTTPS
MPP makes it easier to protect management traffic. You need fewer access-lists because you can restrict most of the network management traffic with MPP. It also prevents network management packet flood attacks since it drops denied packets and does not forward them to the CPU. It’s a good tool to permit/deny most of your network management traffic. You can still use access-lists if you need to permit/deny specific subnets and/or IP addresses.
Let me show you how to configure MPP. This is the topology we’ll use:
MPP lab topology: H1 Gi2 .1 on 192.168.1.0/24 to R1 Gi2 .254, R1 Gi3 .254 on 192.168.2.0/24 to H2 Gi2 .2
H1 is on a trusted network we use to manage R1. H2 is on a remote network that should not be able to manage R1 with any network management protocols.
Want to look for yourself? Here you will find the startup configuration of each device.
H1
hostname H1
interface GigabitEthernet2
H2
hostname H2
R1
hostname R1
interface GigabitEthernet3
Let’s do a “before” and “after” scenario where you can see the difference between when we use MPP or not.
Without MPP
Let me show you what happens behind the scenes when MPP is disabled. I’ll configure R1 so it only accepts SSH traffic on the VTY lines:
R1(config)#line vty 0 4
R1(config-line)#transport input ssh
To see what is going on, we enable a debug:
R1#debug ip packet
IP packet debugging is on
Let’s try to telnet from H2 to R1:
H2#telnet 192.168.2.254
Trying 192.168.2.254 ...
% Connection refused by remote host
We see that the connection is refused, this is expected because we don’t accept telnet on the VTY lines of R1. When you look at R1 you see it sends a packet to H2:
R1#
IP: tableid=0, s=192.168.2.254 (local), d=192.168.2.2 (GigabitEthernet3), routed via FIB
IP: s=192.168.2.254 (local), d=192.168.2.2 (GigabitEthernet3), len 40, sending
R1 responds to H2, refusing the connection. Transmit enough telnet packets from H2 and you can perform a denial of service attack on R1.
With MPP
Let’s see if we can improve this situation. First, let’s enable telnet on the VTY lines of R1:
  • Full Access to 447 lessons.
  1. Avatar for braveheart814 braveheart814 says:
    The control-plane command is not recognized on
    3560CX iOS version 15.2
    nor on a
    3850 IOS-XE version 16.6.6
    Is there an alternative?
    Hello Bradley
    According to this Cisco Documentation, the Cisco IOS Release 15M&T supports these features.
    https://www.cisco.com/c/en/us/...os-plcshp-cpp.pdf
    Now for your specific IOS version, you can take a look at https://cfn.cloudapps.cisco.co...CFN/jsp/index.jsp to see which versions support which features.
  3. Avatar for clawrence clawrence says:
    Great presentation on MPP… I was wondering, is there a concept for MPP on Catalyst switches (3K and 9K) and what about NX-OS (9K). Other than dedicated management interfaces, is it possible to restrict management to a switch port?
    Hello Christopher
    Remember that Management Plane Protection (MPP) is a subset of https://networklessons.com/sys...l-plane-policing. CoPP is something that is available on all Cisco devices including IOS and NX-OS devices.
    Information about CoPP for NX-OS devices can be found here:
    https://www.cisco.com/c/en/us/...apter_010001.html
    Notice the “management plane” section of the document.
    Information about MPP for Catalyst devices, and in particular the 9K Catalyst series can be found here:
    https://www.cisco.com/c/en/us/...ane_policing.html
  5. Avatar for marlonfontenele marlonfontenele says:
    cool, but even using MPP, I still need ACL to block by IP(Line VTY)
12 more replies! Ask a question or join the discussion by visiting our Community Forum
