Etherchannel on Cisco IOS Catalyst Switch
EtherChannel (also known as link aggregation) is a technology that bundles multiple physical links between switches into a single logical link. This increases bandwidth, provides redundancy, and prevents spanning tree from blocking redundant links. In this lesson, we’ll explore how EtherChannel works, when to use it, and how to configure it using PAgP, LACP, or manual configuration.
Key Takeaways
  • EtherChannel bundles up to 8 physical links into one logical link (LACP allows 16, with 8 active and 8 in hot-standby).
  • Spanning tree treats the bundle as a single link, preventing loop detection and port blocking.
  • Three configuration methods:
    • PAgP (Cisco proprietary)
    • LACP (IEEE standard)
    • Manual
  • Load balancing distributes traffic across physical links based on source/destination MAC or IP addresses.
  • All physical interfaces must have identical configurations (speed, duplex, VLAN settings).
  • Individual traffic flows are limited to single link bandwidth (adding links increases capacity, not speed)
Prerequisites
Before diving into EtherChannel, you should understand:
  • Basic switch configuration and interface commands
  • Spanning Tree Protocol (STP) and how it prevents loops
  • VLAN concepts and trunk configuration
  • The difference between access and trunk ports
How EtherChannel Works
Let’s start with an example of a small network:
H1 and H2 connect to SW1, H3 and H4 to SW2, every link including the single SW1-SW2 link is 1000 Mbit
Take a look at the picture above. I have two switches and two computers connected to each switch.  We use Gigabit Ethernet interfaces everywhere.
Now imagine that H1 sends 800 Mbit of traffic destined for H3 and H2 sends 600 Mbit of traffic destined for H4. The link between the switches will be a bottleneck. We require 800 + 600 = 1400 Mbit, but we only have a 1000 Mbit link.
There are two solutions to this problem:
  • Replace the link between the switches with something with a higher bandwidth, perhaps a 10-Gigabit link.
  • Add multiple links and bundle them into an EtherChannel.
Since this lesson is about EtherChannel, we’ll take a look at adding multiple links. Here’s an example:
H1 and H2 on SW1, H3 and H4 on SW2, with two parallel 1000 Mbit links between SW1 and SW2
In the picture above, I have added a couple of extra links. The problem with this setup is that we have a loop between the switches, so spanning tree would block one out of two links. EtherChannel solves this problem because it creates a single virtual link out of these physical links:
The two links between SW1 and SW2 bundled into one 2000 Mbit logical EtherChannel link, hosts on 1000 Mbit links
Spanning tree sees this link as one logical link, so there are no loops! EtherChannel will do load balancing among the different links that we have, and it takes care of redundancy. Once one of the links fails, it will keep working and use the links that we have left.
Keep in mind that the physical links remain the limiting factor. A single traffic flow won’t be able to exceed > 1000 Mbit (single Gigabit link). An Etherchannel is the equivalent of adding more lanes to a highway. The bandwidth increases, but the speed limit doesn’t change.
PAgP and manual EtherChannels support up to eight physical interfaces. With LACP, you can assign up to 16 physical interfaces, but only eight interfaces will be active at a time; the other eight are in hot-standby mode.
If you want to configure an EtherChannel, then we have three options:
  • Manual
PAgP and LACP are negotiation protocols that dynamically configure an Etherchannel. PAgP is a Cisco proprietary protocol so you can only use it between Cisco devices. LACP is an IEEE standard which many vendors support.
It’s also possible to configure a static EtherChannel without these protocols doing the negotiation of the link for you.
If you are going to create an EtherChannel you need to make sure that all interfaces have the same configuration:
  • Duplex.
  • Speed.
  • Native and allowed VLANs.
  • Switchport mode (access or trunk).
PAgP and LACP will check if the configuration of the interfaces that you use is the same.
Let’s see if we can configure an Etherchannel. We’ll try all three options, but start with PAgP.
PAgP
If you want to configure PAgP there are two options you can choose from. The interface can be configured as:
  • Desirable: The interface will actively ask the other side to become an EtherChannel.
  • Auto: The interface will wait passively for the other side to ask to become an EtherChannel.
Here’s a quick overview with the two PAgP configuration options and whether an EtherChannel will form or not:
Desirable Auto
Desirable Yes Yes
Auto Yes No
Let me show you an example of how to configure PAgP between two switches. I’ll use SW1 and SW2 for this demonstration:
SW1 and SW2 connected with two links: Gi0/1 to Gi0/1 and Gi0/2 to Gi0/2
SW1 and SW2 each have two Gigabit interfaces which we’ll bundle these into a single logical link.
Here are our options:
SW1(config)#interface GigabitEthernet 0/1
SW1(config-if)#channel-group 1 mode ?
  active     Enable LACP unconditionally
  auto       Enable PAgP only if a PAgP device is detected
  desirable  Enable PAgP unconditionally
  on         Enable EtherChannel only
  passive    Enable LACP only if a LACP device is detected
We use the channel-group command on the interface-level. You can pick any number you like, I’ll go for 1. We need to decide whether we use auto or desirable mode. I’ll configure SW1 to use desirable mode:
SW1(config)#interface range GigabitEthernet 0/1 - 2
SW1(config-if)#channel-group 1 mode desirable
I configure SW1 for PAgP desirable mode. It will actively ask SW2 to become an EtherChannel this way. We can configure SW2 in either auto or desirable mode. I’ll use auto mode:
SW2(config)#interface range GigabitEthernet 0/1 - 2
SW2(config-if)#channel-group 1 mode auto
With auto mode, SW2 will only respond to incoming PAgP requests. After a few seconds, you’ll see the following message on both switches:
SW1 %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
The switch automatically creates a new port-channel interface:
SW1#show interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is fa16.3e15.5fb2 (bia fa16.3e15.5fb2)
  MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  ARP type: ARPA, ARP Timeout 04:00:00
  Last input 00:03:04, output never, output hang never
  Last clearing of "show interface" counters never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 0 bits/sec, 0 packets/sec
  5 minute output rate 0 bits/sec, 0 packets/sec
     12 packets input, 973 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 input packets with dribble condition detected
     240 packets output, 17496 bytes, 0 underruns
     0 output errors, 0 collisions, 0 interface resets
     0 unknown protocol drops
     0 babbles, 0 late collision, 0 deferred
     0 lost carrier, 0 no carrier
     0 output buffer failures, 0 output buffers swapped out
At the moment, there’s nothing configured under the port-channel interface:
SW1#show run interface Port-channel 1
interface Port-channel1
Our two physical interfaces that belong to this EtherChannel only have the channel-group command:
SW1#show run interface GigabitEthernet 0/1
interface GigabitEthernet0/1
SW1#show run interface GigabitEthernet 0/2
interface GigabitEthernet0/2
If you want to make any changes like configuring the EtherChannel as a trunk, you need to do this under the port-channel interface. For example:
SW1(config)#interface Port-channel 1
SW1(config-if)#switchport trunk encapsulation dot1q
SW1(config-if)#switchport mode trunk
When you do this, the switch automatically adds the commands to the physical interfaces as well:
You shouldn’t make any changes to the physical interfaces that belong to the EtherChannel. Always use the port-channel interface.
Let’s continue and take a closer look at the status of the EtherChannel with some show commands. Here’s the first one:
SW1#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         PAgP      Gi0/1(P)   Gi0/2(P)
The show etherchannel summary command gives a nice clean overview with all your EtherChannels. It tells us whether the EtherChannel is up and which protocol we use. Here’s another show command:
SW1#show etherchannel 1 port-channel
		Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 0d:00h:10m:16s
Logical slot/port   = 2/1          Number of ports = 2
GC                  = 0x00010001      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   PAgP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     gi0/1   Desirable-Sl       0
  0     00     gi0/2   Desirable-Sl       0
Time since last port bundled:    0d:00h:00m:07s    Gi0/1
Time since last port Un-bundled: 0d:00h:04m:08s    Gi0/2
The show etherchannel command gives you an overview of our EtherChannel. You can see the protocol and interfaces we use, and it tells us whether the logical interface is up.
Here’s the last show command you can use:
SW1#show interfaces GigabitEthernet 0/1 etherchannel
Port state    = Up Mstr In-Bndl
Channel group = 1           Mode = Desirable-Sl    Gcchange = 0
Port-channel  = Po1         GC   = 0x00010001      Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   PAgP
Flags:  S - Device is sending Slow hello.  C - Device is in Consistent state.
        A - Device is in Auto mode.        P - Device learns on physical port.
        d - PAgP is down.
Timers: H - Hello timer is running.        Q - Quit timer is running.
        S - Switching timer is running.    I - Interface timer is running.
Local information:
                                Hello    Partner  PAgP     Learning  Group
Port      Flags State   Timers  Interval Count   Priority   Method  Ifindex
Gi0/1     SC	U6/S7   H	30s	 1        128        Any      5001
Partner's information:
          Partner              Partner          Partner         Partner Group
Port      Name                 Device ID        Port       Age  Flags   Cap.
Gi0/1     SW2              0019.569d.5700	Gi0/1      19s SAC	10001
Age of the port in the current state: 0d:00h:02m:37s
The third method to verify your EtherChannel is to use the show interfaces command. In my example, I am looking at the information of the GigabitEthernet 0/1 interface. Besides information on our local switch, you can also see the interface of our neighbor switch.
Want to take a look for yourself? Here you will find the final PAgP configuration of each device.
SW1
hostname SW1
interface port-channel 1
SW2
hostname SW2
LACP
LACP is similar to PAgP but uses different terminology:
  • Active: The interface will actively ask the other side to become an EtherChannel.
  • Passive: The interface waits passively for the other side to ask to become an EtherChannel.
At least one switch should use active mode. When both switches use passive mode, nothing will happen.
Active Passive
Active Yes Yes
Passive Yes No
I’ll use the same topology we used for PAgP:
We’ll configure SW1 to use active mode:
SW1(config-if)#interface range GigabitEthernet 0/1 - 2
SW1(config-if)#channel-group 1 mode active
And SW2 will use passive mode:
SW2(config-if)#channel-group 1 mode passive
Let’s verify our work. We can use the same show commands we use for PAgP:
        U - in use      N - not in use, no aggregation
        m - not in use, port not aggregated due to minimum links not met
        d - default port
        A - formed by Auto LAG
1      Po1(SU)         LACP      Gi0/1(P)    Gi0/2(P)
Let’s try the show etherchannel command:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:00h:01m:43s
Logical slot/port   = 16/0          Number of ports = 2
Protocol            =   LACP
Load share deferral = Disabled
  0     00     Gi0/1    Active             0
  0     00     Gi0/2    Active             0
Time since last port bundled:    0d:00h:01m:04s    Gi0/2
And last but not least, let’s try show interfaces:
Port state    = Up Mstr Assoc In-Bndl
Channel group = 1           Mode = Active          Gcchange = -
Port-channel  = Po1         GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi0/1     SA      bndl      32768         0x1       0x1     0x2         0x3D
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi0/1     SP      32768     5e00.0001.8000  18s    0x0    0x1    0x2     0x3C
Age of the port in the current state: 0d:00h:01m:37s
As you can see the protocol is now LACP, we have a Port-channel 1 interface with two member physical interfaces.
Want to take a look for yourself? Here you will find the final LACP configuration of each device.
SW1
hostname SW1
SW2
hostname SW2
Manual
Instead of PAgP or LACP, we can also manually enable the Etherchannel. I’ll use the same topology to demonstrate this:
Here’s the configuration:
SW1(config-if-range)#channel-group 1 mode on
SW2(config-if-range)#channel-group 1 mode on
That’s all there is to it. Let’s try our show commands. We’ll start with an overview:
        d - default port
1      Po1(SU)          -        Gi0/1(P)    Gi0/2(P)
In the output above, you can see we don’t use any protocol. Let’s take a closer look at the Port-channel interface:
Port-channel: Po1
Age of the Port-channel   = 0d:00h:06m:54s
GC                  = 0x00000000      HotStandBy port = null
Protocol            =    -
  0     00     Gi0/1    On                 0
  0     00     Gi0/2    On                 0
Time since last port bundled:    0d:00h:01m:21s    Gi0/2
Time since last port Un-bundled: 0d:00h:04m:05s    Gi0/2
And we can check one of the two physical interfaces and see the Etherchannel information:
Channel group = 1           Mode = On              Gcchange = -
Port index    = 0           Load = 0x00            Protocol =    -
Age of the port in the current state: 0d:00h:01m:41s
That’s all we have.
Want to take a look for yourself? Here you will find the final manual configuration of each device.
SW1
hostname SW1
SW2
hostname SW2
Load Balancing
The last thing I want to show you about EtherChannel is load-balancing. Take a look at the following output:
Tags: , , , ,
  1. Avatar for ReneMolenaar ReneMolenaar says:
    Hi, Rene. Thanks for info. What if you add note about pagp silent/non-silent submode? Thanks.
    Hi Andy,
    Here’s an example for PAgP silent/non-silent:
    https://networklessons.com/swi...s-catalyst-switch
  3. Avatar for 281332 281332 says:
    hi Rene, i can’t understand what’s different between PAgP and LACP, why cisco created PAgP? does it has some pros?
    Hi Yevgeniy,
    Good question. Etherchannel was originally invented by a company called Kalpana in the 90s. Cisco bought the company in 1994 and released PaGP. Later in 2000, IEEE released an open standard version for Etherchannel (802.3ad) which is LACP.
  5. Avatar for hussien.samer hussien.samer says:
    What is the benefit of etherchannel protocols if we can configure interface as etherchannel manually by setting the mode of etherchannel (on) in both side ? so why we need to set one side Desirable or Active and the other side Auto or Passive ?
183 more replies! Ask a question or join the discussion by visiting our Community Forum
