Cisco SD-WAN Device and Feature Templates
We used the CLI to configure all the devices in our Cisco SD-WAN controllers installation and vEdge onboarding lessons. The CLI is a good way to configure something quickly. You configure one device, and with a bit of copy/pasting, it’s easy to configure other devices. The CLI, however, doesn’t scale. To configure a few devices it’s OK, but when you need to manage dozens of devices, it takes too much time and is prone to errors.
A scalable alternative is templates. Everything that you can configure through the CLI, you can also configure with templates. We create templates beforehand, and then you can apply them to one or as many devices as you like. When you start with templates, there is a learning curve, and it is time-consuming. However, once everything is set up, you will save time and reduce the chance of configuration errors.
The controllers and vEdge routers which we configured are currently in CLI mode. We are going to change this for the vEdge routers so that we can manage them with templates. When we create templates, we have to convert the existing CLI configurations to templates. If you don’t do this, some items in the configuration will be overwritten with default values.
Once the devices are managed through templates, you can’t configure them through the CLI anymore. However, you can still use show commands.
In this lesson, I’ll show you how to create and attach templates to our vEdge routers.
CLI Mode
Go to Configuration > Devices and look at the WAN Edge List and Controllers tabs. You’ll see that all devices are in CLI mode:
Cisco Vmanage Wan Edge List Cli Mode
Cisco Vmanage Wan Controllers Cli Mode
I’ll explain how to change the vEdge routers from CLI mode to vManage mode. When we finish this lesson, you’ll have to manage them through templates from then on and you can’t make any changes through the CLI anymore. But, of course, you can always detach templates from a device and switch back to CLI mode.
Templates
There are two template types:
  • Device template: For each device “type”, we create a device template. This is the template that we attach to a device.
  • Feature template: We create a feature template for each “feature” that you want to configure. Some examples are the system configuration, VPN, VPN interface, OSPF, EIGRP, BGP, AAA, etc.
Parent-child relation: a vEdge uses a device template with four feature templates
There is a “parent-child” relation between the device and feature templates. First, we create feature templates and attach them to a device template. We then attach the device template to a device, like a vEdge Cloud router.
Feature Templates
Let’s start with the feature templates. Below is the configuration of the vEdge routers which we created in the vEdge onboarding lesson.
system
 host-name               vEdge1
 system-ip               172.16.1.1
 site-id                 2
 organization-name       nwl-lab-sdwan
 vbond 10.1.0.2
vpn 0
 interface ge0/0
  ip address 10.65.91.1/24
  ipv6 dhcp-client
  tunnel-interface
   encapsulation ipsec
   color biz-internet
   allow-service all
  no shutdown
 interface ge0/1
  ip address 10.65.92.1/24
  tunnel-interface
   encapsulation ipsec
   color public-internet
   allow-service all
  no shutdown
We’ll convert the above configuration into multiple feature templates.  Open Configuration > Templates > Feature and click on Add Template.
On the left side, choose the device type. I’m using vEdge Cloud:
Cisco Sd Wan Add Feature Template
On the right side, choose System:
Cisco Sd Wan Add Feature Template System
System
We can configure almost all the parameters that you find in the “system” part of the vEdge router configuration in the next screen. But, first, we give the template a name:
Cisco Sd Wan Add Feature Template System Name
Below, there is a bunch of items we can configure, divided into four main sections:
  • Basic Configuration
  • GPS
  • Tracker
  • Advanced
Let’s take a look at the Basic Configuration Section:
Cisco Sd Wan Add Feature Template System Options
Above, you see some familiar items like the Site ID and System IP. For each item we want to configure, we have three options:
  • Device Specific: (the icon with the radio)
  • Default: (the blue checkmark)
  • Global: (the green globe)
Let me explain these options.
Device Specific
We can use a feature template for multiple devices but some configuration items are specific to the device. For example:
  • We want to use site ID 2 on two vEdge routers and site ID 3 on another vEdge router.
  • The system IP is unique on every device.
We can do this with the device-specific option, which uses variables:
Cisco Sd Wan Add Feature Template Device Specific
In the screenshot above, you see these two items:
  • [system_site_id]
  • [system_system_ip]
These two are variables but are called “keys” in the template. Later, when we apply the template, you’ll see that we have to manually fill these fields. If you want, you can change the variable name:
Cisco Sd Wan Add Feature Template Device Specific Key
Default
The default setting has some fields filled with default values. For example, the overlay ID or Timezone. Other fields are empty by default.
Cisco Sd Wan Add Feature Template Default
Global
The global values apply to all devices that you use this feature template for. One example is the Console Baud Rate:
Cisco Sd Wan Add Feature Template Global
If I use a global value for the Console Baud Rate, all devices using this feature template will have their baud rate set to 115200.
Let’s save this system feature template as it is. The default settings look good to me.
VPN0
Let’s configure the VPN0 interface. Create another feature template and select VPN:
Cisco Sd Wan Add Feature Template Vpn
There are not many items that we have to configure here. I set the template name to “template-vedge-vpn0” and the default VPN is already set to 0:
Cisco Sd Wan Add Feature Template Vpn0 Basic
I do need to add a static route. The default is global, which is fine because all my vEdge routers need this static route:
Cisco Sd Wan Add Feature Template Vpn0 Route
Click on + Add Next Hop and then once more on Add Next Hop:
Cisco Sd Wan Add Feature Template Vpn0 Route Nh
The next hop is also a global value. That’s fine by me because the next hop is also the same for all my vEdge routers. Click on Add to continue. You’ll see this overview:
Cisco Sd Wan Add Feature Template Vpn0 Route Add
Click on Add one more time, and the static route shows up like this:
Cisco Sd Wan Add Feature Template Vpn0 Route Overview
I don’t have to configure anything else here for VPN0. Click on Save to save this feature template.
Interfaces
We created the VPN0 template, but we also need the feature templates for the ge0/0 and ge0/1 interfaces.
Ge0/0 Interface
Create another feature template and select VPN Interface Ethernet:
Cisco Sd Wan Add Feature Template Ge00 Interface
Let’s look at all the settings. First, we set a name and description:
Cisco Sd Wan Add Feature Template Ge0 0 Name
Under the basic configuration, add these settings:
Cisco Sd Wan Add Feature Template Ge0 0 Basic
Most of the configuration items are the same for all my vEdge routers. However, the IPv4 address is device-specific. I’ll use the “vpn_if_ge_0_0_ipv4_address” key here. Here’s the tunnel configuration:
Cisco Sd Wan Add Feature Template Ge0 0 Tunnel
I enable the tunnel-interface option and set the correct color (biz-internet). I also allow all services. Click on Save to store the template.
Ge0/1 Interface
The Ge0/1 interface is almost the same as the Ge0/0 interface. So, instead of creating this feature template from scratch, I’ll copy our Ge0/0 template. Click on the three dots next to the template we just created:
Cisco Sd Wan Add Feature Template Copy
And click on Copy:
Cisco Sd Wan Add Feature Template Copy Button
Give the template a new name:
Cisco Sd Wan Add Feature Template Copy Name
And click on the Copy button. Now click on the three dots next to the new template and click on Edit. Under the basic configuration, I change these items:
  • Full Access to 448 lessons.
  1. Avatar for ngockham12312 ngockham12312 says:
    Hi, I see some field is “Device Specific” but I don’t see any picture we need input value into this field
    Hello Gioi
    For each item in the Basic Configuration section, there is a mini dropdown menu from which you can choose one of three options. These options are depicted using icons, which I have listed below:
    https://cdn-forum.networklesso...202b3f7df32bf.png
    - Global
    https://cdn-forum.networklesso...abc9afea08803.png
    - Device specific
    https://cdn-forum.networklesso...c15e9ef2b554e.png
    - Default
    Not all options have all three available. For example, the Site ID doesn’t have a Default available because it is unique to each individual device. When you
  3. Avatar for kanu.rattan kanu.rattan says:
    Could you please explain about GPS and Tracker in template config.
    Hello Kanu
    These are additional parameters that you can set for Viptela devices. The details of each tab are further described in the following Cisco Viptela documentation:
    https://sdwan-docs.cisco.com/P.../Templates/System
    If you have any further questions, please let us know!
  5. Avatar for champ champ says:
    Hi Rene and Laz,
    What is the point of the template if we still have to add the device to vmanage.
    In your notes you mentioned that the we attach the device, but the device needs to be added first to vmanage?
    Shouldn’t the template automatically discover and add the vmanage?
7 more replies! Ask a question or join the discussion by visiting our Community Forum
