In my first lesson about DMVPN we covered the basics, the second lesson explained how to configure DMVPN phase 1 and DMVPN phase 2. I also showed you an example where we use OSPF on DMVPN phase 1.
As I explained before, OSPF is not the best solution for DMVPN. It’s a link state protocol so all spoke routers have to be in the same area. When something changes on one spoke router then it will trigger SPF on the other spoke routers.
When we use DMVPN phase 2, spoke-to-spoke traffic will be direct and doesn’t go through the hub.
In this lesson I will show you what happens when you configure the following OSPF network types on DMVPN phase two:
Here’s the topology that we will use:
Tunnel Interfaces
Here is the hub router:
Hub(config)#interface Tunnel0
Hub(config-if)#end
And the spoke routers:
Let’s see if the hub sees two NHRP spokes:
Hub#show dmvpn
C - CTS Capable
Type:Hub, NHRP Peers:2,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 192.168.123.2 172.16.123.2 UP 00:09:48 D
1 192.168.123.3 172.16.123.3 UP 00:09:56 D
And try a quick ping to test connectivity:
Hub#ping 172.16.123.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/7/11 ms
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/7/10 ms
The tunnel interfaces are up and running. Let’s continue with OSPF.
OSPF
Point-to-point
We can skip the first network type (point-to-point) since it doesn’t work. I showed you in the DMVPN phase 1 OSPF routing lesson what happens when you try this. The hub expects one neighbor on its tunnel interface while in reality we have two neighbors.
Broadcast
This is the best OSPF network type to use for DMVPN phase 2 and I’ll show you why. First let’s configure it:
Hub, Spoke1 & Spoke2
(config)#interface Tunnel 0
(config-if)#ip ospf network broadcast
You need to make sure that the spoke routers will never be elected as DR or BDR:
Spoke1 & Spoke2
(config-if)#ip ospf priority 0
Now let’s configure some network commands. We’ll go for “best practices” and use a different area number for the DMVPN network:
Hub(config)#router ospf 1
Hub(config-router)#network 1.1.1.1 0.0.0.0 area 0
Hub(config-router)#network 172.16.123.0 0.0.0.255 area 1
Spoke1(config)#router ospf 1
Spoke1(config-router)#network 2.2.2.2 0.0.0.0 area 1
Spoke1(config-router)#network 172.16.123.0 0.0.0.255 area 1
Spoke2(config)#router ospf 1
Spoke2(config-router)#network 3.3.3.3 0.0.0.0 area 1
Spoke2(config-router)#network 172.16.123.0 0.0.0.255 area 1
Let’s see if the hub has two neighbors:
Hub#show ip ospf neighbor
2.2.2.2 0 FULL/DROTHER 00:00:38 172.16.123.2 Tunnel0
3.3.3.3 0 FULL/DROTHER 00:00:37 172.16.123.3 Tunnel0
It does and the spoke routers have been elected as DROTHER, that’s good…we don’t want to see DR or BDR here. Let’s take a look at the routing tables:
Hub#show ip route ospf
O 2.2.2.2 [110/1001] via 172.16.123.2, 00:00:24, Tunnel0
O 3.3.3.3 [110/1001] via 172.16.123.3, 00:00:24, Tunnel0
Spoke1#show ip route ospf
O IA 1.1.1.1 [110/1001] via 172.16.123.1, 00:00:28, Tunnel0
O 3.3.3.3 [110/1001] via 172.16.123.3, 00:00:28, Tunnel0
Spoke2#show ip route ospf
O IA 1.1.1.1 [110/1001] via 172.16.123.1, 00:00:31, Tunnel0
O 2.2.2.2 [110/1001] via 172.16.123.2, 00:00:21, Tunnel0
Above you can see that all routers have learned the networks on each others loopback interfaces. Take a close look at the next hop IP addresses for the 2.2.2.2/32 and 3.3.3.3/32 entries. This is looking good, these are the IP addresses of the spoke routers. You can also see that 1.1.1.1/32 shows up as an inter-area route. This is good, it means we can summarize networks “behind” the hub towards the spoke routers if we want to.
Let’s see if spoke1 can reach spoke2:
Tracing the route to 3.3.3.3
1 172.16.123.3 7 msec 6 msec *
Great this is working. We have spoke-to-spoke connectivity which worked “out of the box”. OSPF neighbor adjacencies were automatically established and the next hop addresses were correct for spoke-to-spoke communication.
Non-broadcast
The non-broadcast OSPF network type behaves the same as broadcast with the exception that we have to configure static neighbors:
(config-if)#ip ospf network non-broadcast
On the hub we will configure our neighbors:
Hub(config-router)#neighbor 172.16.123.2
Hub(config-router)#neighbor 172.16.123.3
We can see our neighbors on the hub:
Let’s try another traceroute:
The end result will be the same as with “broadcast”. The only difference is the static neighbor command.
Point-to-multipoint
This network type is a poor choice, let me show you why. First we’ll get rid of the static neighbors from the previous example and we’ll set the network type:
Excellent lesson
What amazing posting ! Thx Rene.
what is the default network type for DMVPN tunnel?
If it is point-to-point, we must change it and become mandatory to change it?
Mahmoud,
You are exactly right. The default network type of a DMVPN tunnel is Point-to-Point.
One of the rules of a P2P interface is there can be at most 1 OSPF neighbor. With the Hub’s tunnel interface, however, the OSPF process hears Hello messages from numerous different neighbors’ OSPF processes. This causes the Hub’s OSPF process to churn over and over, throwing out the previously formed Exstart relationship to form a new neighborship with the most recently received Hello. When this happens, you will see these messages on the Hub over and over again
... Continue reading in our forumMany Thanks Andrew for your support
