QoS LLQ (Low Latency Queueing) on Cisco IOS
LLQ (Low Latency Queuing) is an extension of CBWFQ (Class Based Weighted Fair Queuing) where we add a priority queue to the scheduler. Here’s an illustration to help you visualize this:
Four output queues: queue 1 goes to the LLQ scheduler, queues 2, 3 and 4 go to the CBWFQ scheduler, both exit through Gi0/2
In the picture above, output queues 2, 3 and 4 are attached to the regular CBWFQ scheduler and are served in a (weighted) round robin fashion. Queue 1 however, is attached to the LLQ scheduler and bypasses the CBWFQ scheduler. This turns queue 1 into a priority queue. Everything that ends up in queue 1 will be served before any of the other queues.
To demonstrate this, I will use the following topology:
R1, R2 and R3 in a row with the policy map on R2 outbound towards R3
All we need are three routers to demonstrate LLQ. R1 will send some packets to R3, R2 in the middle will do the queuing.
R1
hostname R1
ip cef
interface GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 192.168.12.2
R2
hostname R2
ip cef
interface GigabitEthernet0/2
R3
hostname R3
ip cef
ip route 0.0.0.0 0.0.0.0 192.168.23.2
First, we need a class-map to classify the traffic that you want to put in the priority queue. I will create two class-maps. One for VOICE traffic (marked with DSCP ef) and another one for CALL_SIGNALING that is marked with cs3. The voice traffic will end up in the priority queue, the call signaling traffic will be served by CBWFQ.
R2(config)#class-map VOICE
R2(config-cmap)#match dscp ef
R2(config)#class-map CALL_SIGNALING
R2(config-cmap)#match dscp cs3
Now we can create a policy-map and create a priority queue for the voice class-map:
R2(config)#policy-map LLQ
R2(config-pmap)#class VOICE
R2(config-pmap-c)#priority ?
  <1-2000000>  Kilo Bits per second
  level        Multi-Level Priority Queue
  percent      % of total bandwidth
  <cr>
Depending on your hardware, you might have two or three options. You can configure a priority queue for a certain kilobit per second rate or a percentage of the bandwidth. The third option on my router is the multi-level priority queue. Most routers will only allow one priority queue, but in this case, I can create two priority queues (high and low). This can be useful if, for example, you have real-time voice and video traffic and you want to prioritize both. With a single priority queue, you can’t decide if voice or video traffic should be prioritized first. Within the priority queue, life is best effort.
With a high and low priority queue, you can ensure that both are prioritized, but one priority queue is still prioritized over the other.
Let’s keep it simple. I will create a priority queue for 2000 Kbps:
R2(config-pmap-c)#priority 2000
R2(config-pmap-c)#exit
For our signaling traffic, we’ll configure a bandwidth guarantee of 1000 Kbps:
R2(config-pmap)#class CALL_SIGNALING
R2(config-pmap-c)#bandwidth 1000
Last but not least, let’s activate the policy map on our interface:
R2(config-if)#service-policy output LLQ
That’s all we have to do…
The Kbps rates that I configured are not hard limits. When there is no congestion on the interface, both classes can get more bandwidth. When there is congestion, the router polices the priority class to its configured rate (2000 Kbps here) and drops the excess, so the priority queue can’t starve the other queues. If you want to enforce a hard limit, you can configure policing for the class.
Verification
Let’s verify our work. Let’s take a look at our class-maps:
R2#show class-map
 Class Map match-all CALL_SIGNALING (id 2)
   Match   dscp cs3 (24)
 Class Map match-any class-default (id 0)
   Match any
 Class Map match-all VOICE (id 1)
   Match   dscp ef (46)
Above, we can see the two class-maps I created. The class-default class is always there. Traffic that is not matched by one of your class-maps will end up in the class-default class. Here’s the policy-map:
R2#show policy-map
  Policy Map LLQ
    Class VOICE
      priority 2000 (kbps)
    Class CALL_SIGNALING
      bandwidth 1000 (kbps)
Let’s generate some traffic and see what happens. I can use some simple pings for this, but I will have to set the ToS byte. The ping command only accepts a ToS parameter in decimal, so I’ll have to do some conversion:
  • DSCP EF (46) is 101110 in binary, that’s 184 in decimal.
  • DSCP CS3 (24) is 011000 in binary, that’s 96 in decimal.
DSCP only uses the first 6 bits of the 8-bit ToS field. The last 2 bits are the ECN bits.
Let’s send those pings:
R1#ping 192.168.23.3 tos 184 repeat 100
Sending 100, 100-byte ICMP Echos to 192.168.23.3, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 5/6/11 ms
R1#ping 192.168.23.3 tos 96 repeat 200
Sending 200, 100-byte ICMP Echos to 192.168.23.3, timeout is 2 seconds:
Success rate is 100 percent (200/200), round-trip min/avg/max = 2/6/16 ms
Let’s see if our traffic matched:
R2#show policy-map interface GigabitEthernet 0/2
 GigabitEthernet0/2
  Service-policy output: LLQ
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 100/11400
    Class-map: VOICE (match-all)
      100 packets, 11400 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match:  dscp ef (46)
      Priority: 2000 kbps, burst bytes 50000, b/w exceed drops: 0
    Class-map: CALL_SIGNALING (match-all)
      200 packets, 22800 bytes
      Match:  dscp cs3 (24)
      Queueing
      (pkts output/bytes output) 200/22800
      bandwidth 1000 kbps
      7 packets, 724 bytes
      Match: any
      (pkts output/bytes output) 7/724
There we go, you can see that my packets ended up in the correct queues. Keep in mind that as long as there is no congestion, both classes can get more bandwidth.
  1. Avatar for azmuddincisco azmuddincisco says:
    Couple of questions.
    Is it possible to provide me an example to show the difference between congestion management and congestion avoidance. As a matter of fact, I do not understand TCP Global Synchronization very well. It will be great if you use an example to explain congestion management and avoidance by relating to TCP Global Synchronization.
    This question is basically based upon Priority command VS Bandwidth command. Priority command is used to ensure the maximum bandwidth during the congestion. On the other hand, Bandwidth is used to ensure
    Hi Azm,
    Congestion management is about dealing with congestion when it occurs and congestion avoidance is trying to avoid congestion. To understand congestion avoidance, you have to think about how the TCP window size and global synchronization works. I explained this in this lesson:
    https://networklessons.com/net...ndow-size-scaling
    Congestion avoidance works by dropping certain TCP segments so that the window size reduces, slowing down the TCP transmission and by doing so, preventing congestion from happening.
    The difference between priority and
  3. Avatar for azmuddincisco azmuddincisco says:
    Thanks a lot for your explanation. However, still needs some more clarification. Lets’ say I have an interface GIg 0/1 that is capable of handling 100 packets per second. I have three different kinds of traffic passing through the interface. They are Traffic A, B and C.
    And the QoS is configured like this:
    Traffic A: Priority 50 packets
    Traffic B: Bandwidth 25 packets
    Traffic C: Bandwidth 25 packets
    I am just using packets per second instead of MB or KB per second.
    As far as my understanding goes, QoS will work like this:
    #Every second the
    Hello Azm
    azmuddincisco:
    If I draw this, the queue will be like this:
    B + C + A =========>>Out
    25 + 25 + 50
    or
    C + B + A ===========>Out
    25 + 25 + 50
    Meaning Traffic A will be delivered first.
    Is it correct?
    In your example, we assume that Traffic A has been configured to be attached to an LLQ scheduler, and that is what you mean by priority traffic. Also, we assume that Traffic B and C are functioning in a round robin format without weighting.
    If this is the case, then yes this is
  5. Avatar for azmuddincisco azmuddincisco says:
    That was my question and that is the answer I was looking for. Thank you so much as usual.
    Azm
93 more replies! Ask a question or join the discussion by visiting our Community Forum
