In a Cisco SD-WAN network, vEdge routers build a full-mesh topology with vEdge routers in other sites. This is the default behavior, and it means that all devices within a service VPN can communicate with each other. However, a full mesh topology is not always required, and with many vEdge routers, it can even become a scalability issue.
This lesson will explain how you can use a centralized policy to configure a hub and spoke topology. The hub site will be able to communicate with all spoke sites. However, spoke sites can only communicate with the hub and not with other spoke sites.
We have three sites, and I assigned the Ge0/3 interfaces of all vEdge routers to service VPN 10. We’ll do a “before and after” scenario so you can see the difference between the default (full mesh) and a hub and spoke topology. I am using Cisco SD-WAN version 19.3.0.
vEdge1
system
host-name vEdge1
system-ip 172.16.1.1
site-id 2
organization-name nwl-lab-sdwan
vbond 10.1.0.2
omp
no shutdown
graceful-restart
advertise connected
advertise static
banner
motd "Welcome to the vEdge router!"
vpn 0
interface ge0/0
ip address 10.65.91.1/24
tunnel-interface
encapsulation ipsec
color biz-internet
allow-service all
no shutdown
interface ge0/1
ip address 10.65.92.1/24
tunnel-interface
encapsulation ipsec
color public-internet
allow-service all
no shutdown
ip route 10.1.0.0/24 10.65.92.100
vpn 10
interface ge0/3
ip address 10.2.0.254/24
no shutdown
omp
advertise connected
vpn 512
interface eth0
shutdown
vEdge3
system
host-name vEdge3
system-ip 172.16.1.3
site-id 3
vbond 10.1.0.2
omp
no shutdown
graceful-restart
advertise connected
advertise static
banner
vpn 0
interface ge0/0
ip address 10.65.91.3/24
tunnel-interface
encapsulation ipsec
color biz-internet
allow-service all
no shutdown
interface ge0/1
ip address 10.65.92.3/24
tunnel-interface
encapsulation ipsec
allow-service all
no shutdown
vpn 10
interface ge0/3
ip address 10.3.0.254/24
no shutdown
omp
advertise connected
vpn 512
interface eth0
shutdown
vEdge4
system
host-name vEdge4
system-ip 172.16.1.4
site-id 4
vbond 10.1.0.2
omp
no shutdown
graceful-restart
advertise connected
advertise static
banner
vpn 0
interface ge0/0
ip address 10.65.91.4/24
tunnel-interface
encapsulation ipsec
color biz-internet
allow-service all
no shutdown
interface ge0/1
ip address 10.65.92.4/24
tunnel-interface
encapsulation ipsec
allow-service all
no shutdown
vpn 10
interface ge0/3
ip address 10.4.0.254/24
no shutdown
omp
advertise connected
vpn 512
interface eth0
shutdown
SW1
hostname SW1
no ip routing
interface GigabitEthernet0/0
no switchport
ip address 10.2.0.101 255.255.255.0
ip default-gateway 10.2.0.254
SW3
hostname SW3
no ip routing
no switchport
ip address 10.3.0.103 255.255.255.0
ip default-gateway 10.3.0.254
SW4
hostname SW4
no ip routing
no switchport
ip address 10.4.0.104 255.255.255.0
ip default-gateway 10.4.0.254
Full Mesh Topology
The default is a full mesh topology. This means that all sites can reach each other. So, for example, I can ping from SW3 to both SW1 and SW4:
SW3#ping 10.2.0.101
Sending 5, 100-byte ICMP Echos to 10.2.0.101, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 51/63/79 ms
SW3#ping 10.4.0.104
Sending 5, 100-byte ICMP Echos to 10.4.0.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/65/74 ms
SW4 can also ping SW1:
SW4#ping 10.2.0.101
Success rate is 100 percent (5/5), round-trip min/avg/max = 55/63/72 ms
We have full connectivity because each vEdge router advertises its prefix through OMP to the vSmart controller. The vSmart controller advertises all prefixes to the vEdge routers.
show ip routes omp and show ipsec outputs below, I removed non-relevant columns to keep it readable.You can see the OMP routes below:
vEdge1# show ip routes omp | begin VPN
VPN PREFIX PROTOCOL TLOC IP COLOR ENCAP STATUS
10 10.3.0.0/24 omp 172.16.1.3 biz-internet ipsec F,S
10 10.3.0.0/24 omp 172.16.1.3 public-internet ipsec F,S
10 10.4.0.0/24 omp 172.16.1.4 biz-internet ipsec F,S
10 10.4.0.0/24 omp 172.16.1.4 public-internet ipsec F,S
vEdge3# show ip routes omp | begin VPN
10 10.2.0.0/24 omp 172.16.1.1 biz-internet ipsec F,S
10 10.2.0.0/24 omp 172.16.1.1 public-internet ipsec F,S
vEdge4# show ip routes omp | begin VPN
In the output above, you can see that all prefixes are learned and installed. One for each WAN connection.
This also means that all vEdge routers establish IPSec connections with each other. Between TLOCs on one WAN interface and TLOCs of different WAN interfaces (if there is reachability between the two WAN clouds). That is the case with two Internet connections like I have, but not if you have a private WAN connection (like MPLS). You can see the IPSec connections below:
vEdge1# show ipsec outbound-connections
SOURCE SOURCE DEST DEST REMOTE REMOTE
IP PORT IP PORT SPI TUN MTU TLOC ADDRESS TLOC COLOR
10.65.91.1 12346 10.65.91.3 12346 259 1441 172.16.1.3 biz-internet
10.65.91.1 12346 10.65.91.4 12346 256 1441 172.16.1.4 biz-internet
10.65.91.1 12346 10.65.92.3 12346 259 1442 172.16.1.3 public-internet
10.65.91.1 12346 10.65.92.4 12346 256 1442 172.16.1.4 public-internet
10.65.92.1 12346 10.65.91.3 12346 259 1442 172.16.1.3 biz-internet
10.65.92.1 12346 10.65.91.4 12346 256 1442 172.16.1.4 biz-internet
10.65.92.1 12346 10.65.92.3 12346 259 1441 172.16.1.3 public-internet
10.65.92.1 12346 10.65.92.4 12346 256 1441 172.16.1.4 public-internet
vEdge3# show ipsec outbound-connections
10.65.91.3 12346 10.65.91.1 12346 257 1441 172.16.1.1 biz-internet
10.65.91.3 12346 10.65.91.4 12346 256 1441 172.16.1.4 biz-internet
10.65.91.3 12346 10.65.92.1 12346 257 1442 172.16.1.1 public-internet
10.65.91.3 12346 10.65.92.4 12346 256 1442 172.16.1.4 public-internet
10.65.92.3 12346 10.65.91.1 12346 257 1442 172.16.1.1 biz-internet
10.65.92.3 12346 10.65.91.4 12346 256 1442 172.16.1.4 biz-internet
10.65.92.3 12346 10.65.92.1 12346 257 1441 172.16.1.1 public-internet
10.65.92.3 12346 10.65.92.4 12346 256 1441 172.16.1.4 public-internet
vEdge4# show ipsec outbound-connections
10.65.91.4 12346 10.65.91.1 12346 257 1441 172.16.1.1 biz-internet
10.65.91.4 12346 10.65.91.3 12346 259 1441 172.16.1.3 biz-internet
10.65.91.4 12346 10.65.92.1 12346 257 1442 172.16.1.1 public-internet
10.65.91.4 12346 10.65.92.3 12346 259 1442 172.16.1.3 public-internet
10.65.92.4 12346 10.65.91.1 12346 257 1442 172.16.1.1 biz-internet
10.65.92.4 12346 10.65.91.3 12346 259 1442 172.16.1.3 biz-internet
10.65.92.4 12346 10.65.92.1 12346 257 1441 172.16.1.1 public-internet
10.65.92.4 12346 10.65.92.3 12346 259 1441 172.16.1.3 public-internet
Each vEdge router has 8 IPSec connections, and we only have three routers (with two WAN interfaces). This can become a scalability issue with large topologies, especially if you have low-end branch vEdge routers.
Let’s change our topology from full mesh to a hub and spoke topology.
Centralized Policy
Go to Configuration > Policies > Centralized Policy and click on Add Policy:
Groups of Interest
We need to create two items:
- Site List: A list so we know which site will be the hub and which sites will be the spokes.
- VPN List: The VPN that we want to create a hub and spoke topology for.
Site List
Under Groups of Interest, add a New Site List:
We create two lists here:
- HUB: site 2.
- SPOKES: sites 3 and 4.
Create the lists, so your overview looks like this:
VPN
Let’s create the VPN list. Under Groups of Interest, select VPN. Enter a name and the VPN number (10) here:
Click on Add to continue. Then, under Topology, click on Add Topology and select Hub-and-Spoke:
Give the policy a name, select the VPN List we created, and select the Hub and Spoke Sites. Click on Save Hub-And-Spoke Policy to save the policy:
The policy now shows up in the overview. Click on Next:
We don’t need any Traffic Rules, so click on Next:
Thanks for your video. What if I want a hub and spoke topology, but I still want a communication between the Spokes (Through the HUB).
In this example we see that the communications between spokes is now impossible.
Nicolas
Hello Nicolas
I think there may be confusion as far as what we mean when we say hub-and-spoke.
The default behavior of an SD-WAN topology is full mesh. This means that all sites can communicate with each other directly. The hub and spoke topology that Rene mentioned in the lab refers to the restriction of allowing each vEdge to communicate ONLY with the central site, and not communicate with any other vEdge device. This is not to be confused with hub and spoke topologies such as https://networklessons.com/cis...oduction-to-dmvpn for example.
What you are
... Continue reading in our forumHello Laz,
Thank you for this detailed answer.
Imagine I have only MPLS underlay with different SP (many MPLS SP) tow sites each attached to an MPLS SP that need to communicate together through the hub (that have connectivity to both MPLS SP must be able to receive the routes of each other’s for example. Adding a default route could be a solution right?
Thanks :folded_hands:
Nicolas
Hello Nicolas
OK I understand. So by design, your initial “underlay” network is such that there are parts of the network that can’t communicate directly. So you have multiple MPLS service providers, and you have a particular site that is connected to two (or more) MPLS networks that acts as the “hub” for communication between entities in those MPLS networks.
So if you have topology where two vEdge devices cannot communicate directly over the underlay due to the restrictions you describe, but can each communicate with the main site where the controllers are
... Continue reading in our forumHello,
Thanks for the lesson, but I do have a doubt. I am labbing a HUB and Spoke topology on SD-WAN and I am having a hard time on the design. Here is my idea:
I can get the HUB up on the SD-WAN fabric overlay, with all control connections successfully established. But when I get into the SPOKE, I ran into the folloeing issue:
The Spoke router can ping 68.1.1.1 (the HUB) and also 214.15.10.254 (G0/0/0.214 on the HUB), but I cannot ping the vBond or non of the control elements from the Spoke.
... Continue reading in our forumSame applies viceversa, I can
