How to configure BGP AS Path Prepending
The fourth BGP attribute is called AS Path:
  • BGP prefers the shortest AS path to get to a destination. Less is more!
  • We can manipulate this by using AS path prepending.
Let me show you an example:
bgp as path prepend
In my example AS 1 wants to make sure traffic enters the autonomous system through R2. We can add our own autonomous system number multiple times, so the as-path becomes longer. Since BGP prefers a shorter AS path, we can influence our routing. This is called AS path prepending.
Let’s see what this looks like on Cisco routers. This is the topology that I will use:
bgp as path prepend lab
Above we have 3 routers. R1 and R3 are both in AS 1 advertising the same network (1.1.1.0/24) to R2. We can use AS Path prepending to make R2 prefer a certain path.
  • Full Access to 447 lessons.
    It was a good article but got confusing when you mixed up Jack with John.
    Hi Tony,
    Thanks, I just fixed it…the names are now correct.
    nice explanation !!!
  4. Avatar for email email says:
    Thank you for yours articles, great job :wink: . I am beginner in learning of CCNP Routing so sorry for (probably) stupid question. In your articles missing the third attribute (Self-originated). Do you plan write about that? Thank you in advance.
    Daniel
    Great example. I do have one question: Are the prepending AS numbers arbitrary or do I have to coordinate this with my ISP. In other words, does it matter if I use random AS prepends are do they have to be reserved just as I reserved my own AS.
88 more replies! Ask a question or join the discussion by visiting our Community Forum
