CBWFQ not supported on Sub-Interfaces
If you are playing around with CBWFQ you might have discovered that it’s impossible to attach a policy-map to a sub-interface directly. There is a good reason for this and I’d like to show you why this occurs and how to fix it. This is the topology I will use to demonstrate this:
R1 R2 Frame Relay
Just two routers connected to each other using frame-relay. We will try to configure CBWFQ on the Serial 0/0.1 sub-interface of R1.
First, I’ll create a simple CBWFQ configuration:
R1(config)#class-map TELNET
R1(config-cmap)#match protocol telnet
R1(config)#class-map HTTP
R1(config-cmap)#match protocol http
R1(config)#policy-map CBWFQ
R1(config-pmap)#class TELNET
R1(config-pmap-c)#bandwidth percent 10
R1(config-pmap-c)#exit
R1(config-pmap)#class HTTP
R1(config-pmap-c)#bandwidth percent 20
Nothing special here…just a simple CBWFQ configuration that gives 10% of the bandwidth to telnet and 20% to HTTP traffic. Let’s try to apply it to the sub-interface:
R1(config)#interface serial 0/0.1
R1(config-subif)#service-policy output CBWFQ
CBWFQ : Not supported on subinterfaces
Too bad, it’s not going to happen…IOS has a day off. There is a workaround, however…we can’t apply it directly, but if we use a hierarchical policy-map, it will work. Let me show you what I mean:
R1(config)#policy-map PARENT
R1(config-pmap)#class class-default
R1(config-pmap-c)#service-policy CBWFQ
I’ll create a policy-map called PARENT that has our service-policy attached to the class-default class. Now let’s try to attach this to the sub-interface:
R1(config-subif)#service-policy output PARENT
CBWFQ : Hierarchy supported only if shaping is configured in this class
IOS is still complaining. It only allows a hierarchical policy-map when shaping is configured. Let’s give it what it wants:
R1(config-pmap-c)#shape average percent 100
I don’t want to shape, but if I have to configure something we’ll just set the shaper to 100% of the interface bandwidth so that it doesn’t limit our traffic. Let’s attach it to the sub-interface:
Bingo! It has been attached.
Verification
We’ll try to telnet from R1 to R2 to see if it matches the policy-map:
R1#telnet 192.168.12.2
Trying 192.168.12.2 ... Open
Password required, but none set
[Connection to 192.168.12.2 closed by foreign host]
Let’s check if it hit something:
R1#show policy-map interface serial 0/0.1
 Serial0/0.1
  Service-policy output: PARENT
      39 packets, 4086 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
              100 (%)                0 (ms)      0 (ms)
          1544000/1544000   9650   38600     38600     25        4825
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         39        4086      0         0         no
      Service-policy : CBWFQ
        Class-map: TELNET (match-all)
          11 packets, 514 bytes
          Match: protocol telnet
          Queueing
            Output Queue: Conversation 73
            Bandwidth 10 (%)
            Bandwidth 154 (kbps)Max Threshold 64 (packets)
            (pkts matched/bytes matched) 0/0
        (depth/total drops/no-buffer drops) 0/0/0
        Class-map: HTTP (match-all)
          0 packets, 0 bytes
          Match: protocol http
          Queueing
            Output Queue: Conversation 74
            Bandwidth 20 (%)
            Bandwidth 308 (kbps)Max Threshold 64 (packets)
          28 packets, 3572 bytes
          Match: any
Above, you can see that my telnet traffic matches the policy-map. The shaper is configured, but since it’s configured to shape to the entire interface bandwidth, it won’t bother us.
  1. Avatar for ReneMolenaar ReneMolenaar says:
    CBWFQ stands for Class-Based Weighted Fair Queuing
    Class-Based Weighted Fair Queuing. It’s meant to give a certain bandwidth to traffic classes when an interface is congested.
    Brilliant as ever Rene. Good post i was looking for it
    I’ve been following your tutorials for quite a while now and they have helped my a lot. Thanks for them.
    Two things I want to ask:
    1. Using Class-map, is it possible to block something like Facebook. I am able to block http://www.facebook.com but https is a headache. Can’t seem to block only one https site. I don’t want to block all https category.
    2. Do you have tutorials on different Switching stuffs like STP, RSTP, MST, VLAN etc?
    Please share if ya have. Will be grateful.
    rgds
    BJ
    Hi BJ,
    You can use NBAR to block HTTP but not HTTPS, here’s why:
    https://networklessons.com/quality-of-service/block-website-with-nbar-on-cisco-router
    I have quite some switching tutorials but I’m going to add more, take a look here:
    https://networklessons.com/switching
22 more replies! Ask a question or join the discussion by visiting our Community Forum
