DMVPN Phase 3 Basic Configuration
DMVPN supports three different versions called “phases”. In my first DMVPN lesson I explained the basics and  the DMVPN phase 2 configuration and DMVPN phase 1 configuration lessons explain how to configure the first two phases.
This time, I’ll show you how to configure DMVPN phase 3. We’ll use the following topology for this:
Hub, Spoke1 and Spoke2 with the Gi0/1 underlay and the 172.16.123.0/24 tunnel
We have one hub router and two spoke routers.
The configuration of DMVPN phase 3 and 2 is very similar. Let’s start with the following DMVPN phase 2 configuration on all routers:
Hub(config)#interface Tunnel0
To migrate from DMVPN phase 2 to 3, we only need two commands…here’s the first command:
Hub(config)#interface tunnel 0
The NHRP redirect command on the hub will inform spoke routers that they can reach another spoke router directly. The second command is needed on the spoke routers:
  • Full Access to 447 lessons.
Tags: , ,
  1. Avatar for norman norman says:
    Hi !
    I didnt have “ip nhrp redirect” in my IOS (C3745-ADVENTERPRISEK9_SNA-M) ??? that´s the only one i got..
    /Oskar
    Hi Oskar,
    Check the http://tools.cisco.com/ITDIT/C...rchBySoftware.jsp to find out which IOS versions support certain commands.
    It seems the T11 release for the 3725 should support ip nhrp redirect:
    c3725-adventerprisek9_sna-mz.124-6.T11.bin
    http://tools.cisco.com/ITDIT/C...mp;featureId=5963
  3. Avatar for wdavis84 wdavis84 says:
    What is the advantages using the Phase 3 over Phase 2?
    Try to minimize the routing entry in the spoke router?
    Davis
    Hi Davis,
    The main advantage is that you have smaller routing tables. In phase 2, each spoke router requires specific entries for networks it wants to reach behind other spoke routers. With phase 3, a summary route is all you need.
  5. Avatar for wdavis84 wdavis84 says:
    ok. Thanks
    Davis
44 more replies! Ask a question or join the discussion by visiting our Community Forum
