MPLS TE Policy Based Routing (PBR)
As we have seen in the MPLS TE configuration lesson, no traffic is forwarded down an MPLS Traffic Engineering (TE) tunnel by default. It’s similar to a GRE tunnel. The tunnel is there but doesn’t do anything. You have to configure routing to forward traffic down the tunnel.
We have multiple options to route traffic down a TE tunnel. One of the options is Policy Based Routing (PBR). There is nothing special about this configuration. It’s straightforward PBR. We match specific traffic with a route map and set the TE tunnel interface as the next hop.
MPLS TE Tunnel 1 from PE1 to PE2
Routers PE1, P1, P2, P3, and PE2 run MPLS TE. We have a tunnel from PE1 to PE2. I use Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M4.
CE1
hostname CE1
ip cef
 ip router isis
 isis circuit-type level-2-only
interface GigabitEthernet0/0
 ip router isis
router isis
 net 49.0001.0001.0001.0001.0001.00
 is-type level-2-only
 metric-style wide
CE2
hostname CE2
ip cef
 ip address 7.7.7.7 255.255.255.255
 ip router isis
 ip address 192.168.67.7 255.255.255.0
 ip router isis
router isis
 net 49.0001.0007.0007.0007.0007.00
 metric-style wide
P1
hostname P1
ip cef
mpls traffic-eng tunnels
 ip router isis
 ip router isis
 mpls ip
 ip rsvp bandwidth 1000000
interface GigabitEthernet0/1
 ip address 192.168.36.3 255.255.255.0
 ip router isis
 mpls ip
router isis
 mpls traffic-eng router-id Loopback0
 mpls traffic-eng level-2
 net 49.0001.0003.0003.0003.0003.00
 metric-style wide
mpls ldp router-id Loopback0 force
P2
hostname P2
ip cef
 ip router isis
 ip router isis
 mpls ip
 ip address 192.168.45.4 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0004.0004.0004.0004.00
 metric-style wide
P3
hostname P3
ip cef
 ip router isis
 ip address 192.168.56.5 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.45.5 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0005.0005.0005.0005.00
 metric-style wide
PE1
hostname PE1
ip cef
mpls traffic-eng logging lsp setups
mpls traffic-eng logging lsp teardowns
mpls traffic-eng reoptimize events link-up
 ip router isis
interface Tunnel1
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 6.6.6.6
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 750
 tunnel mpls traffic-eng path-option 1 dynamic
 no routing dynamic
 ip router isis
 ip router isis
 mpls ip
interface GigabitEthernet0/2
 ip router isis
 mpls ip
router isis
 net 49.0001.0002.0002.0002.0002.00
 metric-style wide
PE2
hostname PE2
ip cef
 ip router isis
 ip address 192.168.67.6 255.255.255.0
 ip router isis
 ip address 192.168.36.6 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.56.6 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0006.0006.0006.0006.00
 metric-style wide
Here is the routing table of PE1:
PE1#show ip route isis
i L2     1.1.1.1 [115/20] via 192.168.12.1, 00:04:02, GigabitEthernet0/0
i L2     3.3.3.3 [115/20] via 192.168.23.3, 00:03:52, GigabitEthernet0/1
i L2     4.4.4.4 [115/20] via 192.168.24.4, 00:04:12, GigabitEthernet0/2
i L2     5.5.5.5 [115/30] via 192.168.24.4, 00:03:52, GigabitEthernet0/2
      6.0.0.0/32 is subnetted, 1 subnets
i L2     6.6.6.6 [115/30] via 192.168.23.3, 00:03:14, GigabitEthernet0/1
      7.0.0.0/32 is subnetted, 1 subnets
i L2     7.7.7.7 [115/40] via 192.168.23.3, 00:03:14, GigabitEthernet0/1
i L2  192.168.36.0/24 [115/20] via 192.168.23.3, 00:03:52, GigabitEthernet0/1
i L2  192.168.45.0/24 [115/20] via 192.168.24.4, 00:04:12, GigabitEthernet0/2
i L2  192.168.56.0/24 [115/30] via 192.168.24.4, 00:03:14, GigabitEthernet0/2
i L2  192.168.67.0/24 [115/30] via 192.168.23.3, 00:03:14, GigabitEthernet0/1
As you can see above, we don’t use the tunnel interface. We’ll configure PBR to forward some traffic down our TE tunnel.
Let’s start with an access-list that matches traffic between the loopback interfaces of CE1 and CE2:
PE1(config)#ip access-list extended CE1_L0_CE2_L0
PE1(config-ext-nacl)#permit ip host 1.1.1.1 host 7.7.7.7
And we’ll create a route-map that matches the access-list and sets the tunnel as the next hop:
PE1(config)#route-map CE1_CE2_TUNNEL1 permit 10
PE1(config-route-map)#match ip address CE1_L0_CE2_L0
PE1(config-route-map)#set interface Tunnel 1
We’ll attach the route-map on the interface that connects to CE1:
PE1(config)#interface GigabitEthernet 0/0
PE1(config-if)#ip policy route-map CE1_CE2_TUNNEL1
This completes our configuration.
Verification
Let’s verify our work. I’ll enable a debug so we can see it in action:
PE1#debug ip policy
Policy routing debugging is on
Let’s send a ping from CE1 to CE2:
CE1#ping 7.7.7.7 source 1.1.1.1 repeat 1
Sending 1, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
Packet sent with a source address of 1.1.1.1
Success rate is 100 percent (1/1), round-trip min/avg/max = 8/8/8 ms
This is what we see on our console:
  1. Avatar for william.redes william.redes says:
    Hi.
    The video in this lesson is not related to the lesson itself, but to the CBTS lesson.
    Where can I find the correct video for the PBR lesson?
    Hello William!
    Thanks for pointing this out, I will let Rene know to fix this issue.
    Thanks @william.redes , I just fixed this.
  4. Avatar for william.redes william.redes says:
    Hi @lagapidis and @ReneMolenaar !
    Thanks for fixing!
    Some other lessons like Autoroute has no videos. I don’t know if it was intentional or not, just letting you know…
    For me this is not a problem, because the text explanation is very clear! :slight_smile:
    Hello William
    Not all lessons contain videos, some are just text-based, so that is as it is intended to be. Thanks again for your sharp eye!
