In this lesson, I’ll explain how to configure MPLS VPN per VRF TE tunnels. If you haven’t configured MPLS VPN over TE tunnels before, look at our MPLS VPN over MPLS TE tunnels first.
Building a TE tunnel for customer VRFs doesn’t make much sense because of scalability issues. If you have more traffic in a VRF than a single TE tunnel can support, you have an issue. It could make sense when you use VRFs for central services that require strict QoS requirements.
Having said that, let’s dive into the configuration.
To make this work, we need to configure three items for each VRF that require its own TE tunnel:
- A new loopback interface with an IP address that we’ll use as the BGP next hop.
- Change the VRF so it uses the BGP next hop of the loopback interface.
- A static route for each BGP next hop that points to the TE tunnel.
Here’s what we have:
- CE1 and CE3 are in VRF RED.
- CE2 and CE4 are in VRF BLUE.
- The CE routers have a loopback interface which we’ll use to verify reachability.
- PE1, P1, P2, and PE2 run MPLS TE.
- We have two unidirectional TE tunnels from PE1 to PE2 and PE2 to PE1:
- These tunnels both use the loopback0 interfaces on PE1 and PE2 (not shown in the picture).
- Tunnel two has an explicit path so that it uses the path through P2.
We’ll configure this network so that VRF RED uses tunnel one and VRF BLUE uses tunnel two.
I use Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6, RELEASE SOFTWARE (fc1) on all routers.
Want to take a look for yourself? Here, you will find the startup configuration of each device.
CE1
hostname CE1
ip cef
interface GigabitEthernet0/0
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
CE2
hostname CE2
ip cef
router ospf 1
CE3
hostname CE3
ip cef
ip address 7.7.7.7 255.255.255.255
ip address 192.168.67.7 255.255.255.0
router ospf 1
network 7.7.7.7 0.0.0.0 area 0
network 192.168.67.0 0.0.0.255 area 0
CE4
hostname CE4
ip cef
ip address 8.8.8.8 255.255.255.255
ip address 192.168.68.8 255.255.255.0
router ospf 1
network 8.8.8.8 0.0.0.0 area 0
network 192.168.68.0 0.0.0.255 area 0
P1
hostname P1
ip cef
mpls traffic-eng tunnels
ip router isis
isis circuit-type level-2-only
ip router isis
mpls ip
ip rsvp bandwidth 1000000
interface GigabitEthernet0/1
ip address 192.168.46.4 255.255.255.0
ip router isis
mpls ip
router isis
mpls traffic-eng router-id Loopback0
mpls traffic-eng level-2
net 49.0001.0004.0004.0004.0004.00
is-type level-2-only
metric-style wide
mpls ldp router-id Loopback0 force
P2
hostname P2
ip cef
ip router isis
ip address 192.168.35.5 255.255.255.0
ip router isis
mpls ip
ip address 192.168.56.5 255.255.255.0
ip router isis
mpls ip
router isis
net 49.0001.0005.0005.0005.0005.00
metric-style wide
PE1
hostname PE1
ip vrf BLUE
rd 2:2
route-target export 2:2
route-target import 2:2
ip vrf RED
rd 1:1
route-target export 1:1
route-target import 1:1
ip cef
ip router isis
interface Tunnel1
ip unnumbered Loopback0
tunnel mode mpls traffic-eng
tunnel destination 6.6.6.6
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 750
tunnel mpls traffic-eng path-option 1 dynamic
no routing dynamic
interface Tunnel2
tunnel mpls traffic-eng path-option 1 explicit name INCLUDE_P2
no routing dynamic
ip router isis
mpls ip
ip address 192.168.35.3 255.255.255.0
ip router isis
mpls ip
interface GigabitEthernet0/2
ip vrf forwarding RED
interface GigabitEthernet0/3
ip vrf forwarding BLUE
router ospf 1 vrf RED
redistribute bgp 1 subnets
router ospf 2 vrf BLUE
router isis
net 49.0001.0003.0003.0003.0003.00
metric-style wide
router bgp 1
neighbor 6.6.6.6 remote-as 1
neighbor 6.6.6.6 update-source Loopback0
address-family vpnv4
neighbor 6.6.6.6 activate
neighbor 6.6.6.6 send-community extended
exit-address-family
address-family ipv4 vrf BLUE
redistribute ospf 2
exit-address-family
address-family ipv4 vrf RED
redistribute ospf 1
exit-address-family
ip explicit-path name INCLUDE_P2 enable
next-address loose 5.5.5.5
PE2
hostname PE2
ip vrf BLUE
rd 2:2
ip vrf RED
rd 1:1
ip cef
ip router isis
interface Tunnel1
tunnel destination 3.3.3.3
no routing dynamic
interface Tunnel2
no routing dynamic
ip address 192.168.46.6 255.255.255.0
ip router isis
mpls ip
ip address 192.168.56.6 255.255.255.0
ip router isis
mpls ip
ip address 192.168.67.6 255.255.255.0
ip address 192.168.68.6 255.255.255.0
router isis
net 49.0001.0006.0006.0006.0006.00
metric-style wide
router bgp 1
neighbor 3.3.3.3 remote-as 1
neighbor 3.3.3.3 update-source Loopback0
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 send-community extended
exit-address-family
redistribute ospf 2
exit-address-family
redistribute ospf 1
exit-address-family
Loopback Interfaces
We’ll start with the loopback interfaces. We need one for each VRF:
PE1(config)#interface Loopback1
PE1(config-if)#ip address 172.16.3.3 255.255.255.255
PE1(config-if)#interface Loopback2
PE1(config-if)#ip address 172.16.33.33 255.255.255.255
PE2(config)#interface Loopback1
PE2(config-if)#ip address 172.16.6.6 255.255.255.255
PE2(config-if)#interface Loopback2
PE2(config-if)#ip address 172.16.66.66 255.255.255.255
BGP Next-Hop
Under the VRF configuration, we use the bgp next-hop command to change the BGP next hop:
PE1 & PE2
(config)#ip vrf RED
(config-vrf)#bgp next-hop Loopback1
(config)#ip vrf BLUE
(config-vrf)#bgp next-hop Loopback2
Static Routes
The only thing left to do is configure a static route so that we reach the BGP next hops through the TE tunnels:
PE1(config)#ip route 172.16.6.6 255.255.255.255 Tunnel1
PE1(config)#ip route 172.16.66.66 255.255.255.255 Tunnel2
PE2(config)#ip route 172.16.3.3 255.255.255.255 Tunnel1
PE2(config)#ip route 172.16.33.33 255.255.255.255 Tunnel2
This completes the configuration.
Verification
Let’s verify our work. I’ll use PE1 to show you everything we need to know. First, we’ll make sure that tunnels are up and running:
PE1#show mpls traffic-eng tunnels tunnel 1
Name: PE1_t1 (Tunnel1) Destination: 6.6.6.6
Status:
Admin: up Oper: up Path: valid Signalling: connected
path option 1, type dynamic (Basis for Setup, path weight 20)
Config Parameters:
Bandwidth: 750 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF
Metric Type: TE (default)
AutoRoute: disabled LockDown: disabled Loadshare: 750 bw-based
auto-bw: disabled
Active Path Option Parameters:
State: dynamic path option 1 is active
BandwidthOverride: disabled LockDown: disabled Verbatim: disabled
InLabel : -
OutLabel : GigabitEthernet0/0, 21
RSVP Signalling Info:
Src 3.3.3.3, Dst 6.6.6.6, Tun_Id 1, Tun_Instance 44
RSVP Path Info:
My Address: 192.168.34.3
Explicit Route: 192.168.34.4 192.168.46.4 192.168.46.6 6.6.6.6
Record Route: NONE
Tspec: ave rate=750 kbits, burst=1000 bytes, peak rate=750 kbits
RSVP Resv Info:
Record Route: NONE
Fspec: ave rate=750 kbits, burst=1000 bytes, peak rate=750 kbits
Shortest Unconstrained Path Info:
Path Weight: 20 (TE)
Explicit Route: 192.168.34.3 192.168.34.4 192.168.46.4 192.168.46.6
6.6.6.6
History:
Tunnel:
Time since created: 15 hours, 29 minutes
Time since path change: 15 hours, 9 minutes
Number of LSP IDs (Tun_Instances) used: 44
Current LSP:
Uptime: 15 hours, 9 minutes
Tunnel one is connected and uses the path through P1. We use label 21. Let’s check tunnel two:
PE1#show mpls traffic-eng tunnels tunnel 2
Name: PE1_t2 (Tunnel2) Destination: 6.6.6.6
Status:
path option 1, type explicit INCLUDE_P2 (Basis for Setup, path weight 10)
Config Parameters:
auto-bw: disabled
State: explicit path option 1 is active
InLabel : -
OutLabel : GigabitEthernet0/1, 21
Src 3.3.3.3, Dst 6.6.6.6, Tun_Id 2, Tun_Instance 46
RSVP Path Info:
My Address: 192.168.35.3
Explicit Route: 192.168.35.5 5.5.5.5
Record Route: NONE
RSVP Resv Info:
Record Route: NONE
6.6.6.6
History:
Tunnel:
Time since created: 15 hours, 30 minutes
Time since path change: 14 hours, 58 minutes
Number of LSP IDs (Tun_Instances) used: 46
Current LSP:
Uptime: 14 hours, 48 minutes
Selection: reoptimization
Prior LSP:
ID: path option 1 [44]
Removal Trigger: reoptimization completed
Tunnel two is also connected and uses the path through P2. We use label 21 for this tunnel.
Let’s check MP-BGP:
PE1#show ip bgp vpnv4 all
BGP table version is 9, local router ID is 172.16.33.33
t secondary path,
Route Distinguisher: 1:1 (default for vrf RED)
*> 1.1.1.1/32 192.168.13.1 2 32768 ?
*>i 7.7.7.7/32 172.16.6.6 2 100 0 ?
*> 192.168.13.0 0.0.0.0 0 32768 ?
*>i 192.168.67.0 172.16.6.6 0 100 0 ?
Route Distinguisher: 2:2 (default for vrf BLUE)
*> 2.2.2.2/32 192.168.23.2 2 32768 ?
*>i 8.8.8.8/32 172.16.66.66 2 100 0 ?
*> 192.168.23.0 0.0.0.0 0 32768 ?
*>i 192.168.68.0 172.16.66.66 0 100 0 ?
Above, we see the two VRFs and the routes PE1 learned. You can see that we use different BGP next hops. For example:
- 7.7.7.7/32 (CE3) uses next hop 172.16.6.6 (loopback 1 of PE2)
- 8.8.8.8/32 (CE4) uses next hop 172.16.66.66 (loopback 2 of PE2)
You can also look at one particular entry which also tells us the label we use for this route:
