MPLS TE Forwarding Adjacency
MPLS Traffic Engineering (TE) Forwarding Adjacency allows you to advertise a TE tunnel as a link in your IGP.
Why would you want to use this? Let’s take a look at the following scenario:
CE1 and CE2 with two paths: through PE1 and PE3, and through PE2, P1 and PE4
Imagine we want to load balance traffic from CE1 to CE2. All interfaces have the same metric. We have two paths, but because the path through PE1 is the shortest path, that’s the only path we will use. You could solve this by configuring two MPLS TE tunnels on CE1 destined for CE2:
Two MPLS TE tunnels from CE1 to CE2, one over each path
This would solve the issue. CE1 will have two TE tunnels and can load balance all traffic using both paths. This solution has two problems, though:
  • You need to configure MPLS TE on the CE routers.
  • It doesn’t scale.
The topology above is a small network. Now imagine we have 25 Points of Presence (POP), where each POP has two PE routers and ten CE routers.
25 POPs x 10 CE routers = 250 CE routers.
All CE routers have to communicate with each other, so we need a full mesh of TE tunnels. The full mesh formula looks like this:
number of TE tunnels = N * (N-1) / 2
Where N is the number of CE routers. This means we’ll have the following:
250 x (250 - 1) / 2 = 31.125 unidirectional TE tunnels.
TE tunnels are unidirectional, so you’ll need two tunnels if you want to load balance from CE1 to CE2 and vice versa. We’ll have 31.125 x 2 = 62.250 bidirectional TE tunnels. That is a lot of LSPs!
We can solve the scalability issue by moving the TE tunnels up one level in the hierarchy:
MPLS TE tunnels between PE1 and PE3 and between PE2 and PE4
We now have a TE tunnel between PE1/PE3 and PE2/PE4. The CE routers won’t have to run MPLS TE anymore. This also dramatically reduces the number of required TE tunnels.
With 25 POPs and 50 PE routers, we’ll have the following:
50 x (50 - 1) / 2 = 1.225 undirectional TE tunnels.
We want to load balance in both ways, so we’ll have 1.225 x 2 = 2.450 bidirectional TE tunnels. That is a significant improvement.
However, this introduces another issue…
The problem is that our CE routers don’t know about the TE tunnels on the PE routers. Enabling autoroute doesn’t solve this issue because it’s a local change in the routing table of the PE routers. The PE routers won’t advertise anything to other routers.
This is why we need forwarding adjacency. It allows the PE routers to advertise the TE tunnel as a link in your IGP.
Let’s take a look at this in action.
MPLS TE forwarding adjacency lab topology with CE1, PE1 to PE4, P1, CE2 and two TE tunnels
All P routers run MPLS TE. We have four TE tunnels:
  • PE1 to PE3
  • PE2 to PE4
  • PE3 to PE1
  • PE4 to PE2
MPLS TE tunnels are unidirectional, but IS-IS or OSPF assume links are bidirectional. Because forwarding adjacency advertises the TE tunnel as a link in your IGP, we need tunnels in both directions. If you only configure unidirectional TE tunnels and enable forwarding adjacency, the IGP won’t use the link.
The CE routers only run IS-IS. Our goal is to load balance traffic from CE1 to CE2 using both paths.
CE1
hostname CE1
ip cef
 ip router isis
 isis circuit-type level-2-only
interface GigabitEthernet0/0
 ip router isis
interface GigabitEthernet0/1
 ip router isis
router isis
 net 49.0001.0001.0001.0001.0001.00
 is-type level-2-only
 metric-style wide
CE2
hostname CE2
ip cef
 ip address 7.7.7.7 255.255.255.255
 ip router isis
 ip address 192.168.57.7 255.255.255.0
 ip router isis
 ip address 192.168.67.7 255.255.255.0
 ip router isis
router isis
 net 49.0007.0007.0007.0007.0007.00
 metric-style wide
P1
hostname P1
ip cef
mpls traffic-eng tunnels
 ip router isis
 ip router isis
 mpls ip
 ip rsvp bandwidth 1000000
 ip address 192.168.46.4 255.255.255.0
 ip router isis
 mpls ip
router isis
 mpls traffic-eng router-id Loopback0
 mpls traffic-eng level-2
 net 49.0001.0004.0004.0004.0004.00
 metric-style wide
mpls ldp router-id Loopback0 force
PE1
hostname PE1
ip cef
 ip router isis
interface Tunnel1
 ip unnumbered Loopback0
 isis metric 4 level-2
 tunnel mode mpls traffic-eng
 tunnel destination 5.5.5.5
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 750
 tunnel mpls traffic-eng path-option 1 dynamic
 no routing dynamic
 ip router isis
 ip address 192.168.25.2 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0002.0002.0002.0002.00
 metric-style wide
PE2
hostname PE2
ip cef
 ip router isis
interface Tunnel1
 tunnel destination 6.6.6.6
 no routing dynamic
 ip router isis
 ip router isis
 mpls ip
router isis
 net 49.0001.0003.0003.0003.0003.00
 metric-style wide
PE3
hostname PE3
ip cef
 ip router isis
interface Tunnel1
 tunnel destination 2.2.2.2
 no routing dynamic
 ip address 192.168.57.5 255.255.255.0
 ip router isis
 ip address 192.168.25.5 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0005.0005.0005.0005.00
 metric-style wide
PE4
hostname PE4
ip cef
 ip router isis
interface Tunnel1
 tunnel destination 3.3.3.3
 no routing dynamic
 ip address 192.168.67.6 255.255.255.0
 ip router isis
 ip address 192.168.46.6 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0006.0006.0006.0006.00
 metric-style wide
I use IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M4.
Without Forwarding Adjacency
This is how CE1 can reach CE2’s loopback interface:
CE1#show ip route 7.7.7.7
Routing entry for 7.7.7.7/32
  Known via "isis", distance 115, metric 40, type level-2
  Redistributing via isis
  Last update from 192.168.12.2 on GigabitEthernet0/0, 01:38:06 ago
  Routing Descriptor Blocks:
  * 192.168.12.2, from 7.7.7.7, 01:38:06 ago, via GigabitEthernet0/0
      Route metric is 40, traffic share count is 1
CE1 uses IGP routing, and the shortest path is through PE1. We can verify this with a traceroute:
CE1#traceroute 7.7.7.7 numeric probe 1
Tracing the route to 7.7.7.7
  1 192.168.12.2 2 msec
  2 192.168.25.5 1 msec
  3 192.168.57.7 3 msec
Enabling autoroute won’t do us any good here because this only changes the routing table of the PE routers. Autoroute doesn’t advertise anything to other routers.
With Forwarding Adjacency
Let’s fix this so that CE1 learns about both TE tunnels. Let’s enable forwarding adjacency on all PE routers:
PE1, PE2, PE3 & PE4
(config)#interface Tunnel 1
(config-if)#tunnel mpls traffic-eng forwarding-adjacency
(config-if)#isis metric 4 level-2
I also set the IS-IS metric of the tunnel interface. We want to ensure the metric is attractive enough for CE1 to use the tunnel interfaces.
Optionally, we can configure a holdtime timer:
PE1(config-if)#tunnel mpls traffic-eng forwarding-adjacency holdtime ?
  <0-4294967295>  Holdtime on MPLS TE Down.
The holdtime is important when the tunnel goes down. When a TE tunnel goes down, the router calculates a new path, and the TE tunnel comes back up. This causes the link to be withdrawn and readvertised in your IGP. The holdtime defines how long the tunnel must be down before telling the IGP it is down.
You can verify forwarding adjacency has been enabled with this command:
PE1#show mpls traffic-eng forwarding-adjacency
  destination 0005.0005.0005.00, area isis  level-2, has 1 tunnels
    Tunnel1     (load balancing metric 2666666, nexthop 5.5.5.5)
                (flags:  Forward-Adjacency, holdtime 0)
PE2#show mpls traffic-eng forwarding-adjacency
  destination 0006.0006.0006.00, area isis  level-2, has 1 tunnels
    Tunnel1     (load balancing metric 2666666, nexthop 6.6.6.6)
We can see that the TE tunnels are advertised as links in our IS-IS LSP. Here’s the LSP of PE1:
PE1#show isis database detail PE1.00-00
IS-IS Level-2 LSP PE1.00-00
LSPID                 LSP Seq Num  LSP Checksum  LSP Holdtime/Rcvd      ATT/P/OL
PE1.00-00           * 0x000000F0   0x6763                1014/*         0/0/0
  Area Address: 49.0001.0002
  NLPID:        0xCC
  Router ID:    2.2.2.2
  Hostname: PE1
  Metric: 10         IS-Extended PE1.01
  Metric: 10         IS-Extended PE3.02
  Metric: 4          IS-Extended PE3.00
  IP Address:   2.2.2.2
  Metric: 10         IP 2.2.2.2/32
  Metric: 10         IP 192.168.12.0/24
  Metric: 10         IP 192.168.25.0/24
Above, you see the link with a metric of 4. Here is the LSP of PE2:
  • Full Access to 447 lessons.
  1. Avatar for fangshucheng fangshucheng says:
    There is a typo,
    PE1 to PE3
    PE2 to PE4
    PE3 to PE1
    PE4 to PE1 <-------This one should be PE4 to PE2?
    Hello Martin
    Yes, you are correct, thanks for catching that! I will let Rene know to make the correction.
    Thanks again!
