MPLS TE Autoroute Metric
MPLS TE Autoroute allows you to install Traffic Engineering (TE) tunnels as the next hop in the headend router’s routing table. As explained in the MPLS TE metric lesson, TE tunnels use the shortest path IGP metric as the TE tunnel metric.
It is possible, however, to influence the autoroute TE tunnel metric. In this lesson, we’ll look at some examples of how you can do this. There are three commands you can use to change the metric:
  1. tunnel mpls traffic-eng autoroute metric
  2. tunnel mpls traffic-eng autoroute metric absolute
  3. tunnel mpls traffic-eng autoroute metric relative
We’ll look at configuration options for these three commands.
Tunnel 1 from PE1 through P1 to PE2 and Tunnel 2 from PE1 through P2 and P3 to PE2
PE1 is our headend router and PE2 is the tailend router. We use IS-IS as the IGP. Each interface has a default metric of 10. I use IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6 on all routers.
CE1
hostname CE1
ip cef
 ip router isis
 isis circuit-type level-2-only
interface GigabitEthernet0/0
 ip router isis
router isis
 net 49.0001.0001.0001.0001.0001.00
 is-type level-2-only
 metric-style wide
CE2
hostname CE2
ip cef
 ip address 7.7.7.7 255.255.255.255
 ip router isis
 ip address 192.168.67.7 255.255.255.0
 ip router isis
router isis
 mpls traffic-eng level-2
 net 49.0001.0007.0007.0007.0007.00
 metric-style wide
P1
hostname P1
ip cef
mpls traffic-eng tunnels
 ip router isis
 ip router isis
 mpls ip
 ip rsvp bandwidth 1000000
interface GigabitEthernet0/1
 ip address 192.168.36.3 255.255.255.0
 ip router isis
 mpls ip
router isis
 mpls traffic-eng router-id Loopback0
 net 49.0001.0003.0003.0003.0003.00
 metric-style wide
mpls ldp router-id Loopback0 force
P2
hostname P2
ip cef
 ip router isis
 ip router isis
 mpls ip
 ip address 192.168.45.4 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0004.0004.0004.0004.00
 metric-style wide
P3
hostname P3
ip cef
 ip router isis
 ip address 192.168.56.5 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.45.5 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0005.0005.0005.0005.00
 metric-style wide
PE1
hostname PE1
ip cef
 ip router isis
interface Tunnel1
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 6.6.6.6
 tunnel mpls traffic-eng autoroute announce
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 750
 tunnel mpls traffic-eng path-option 1 explicit name EXCLUDE_P2
 no routing dynamic
interface Tunnel2
 tunnel mpls traffic-eng path-option 1 explicit name EXCLUDE_P1
 no routing dynamic
 ip router isis
 ip router isis
 mpls ip
interface GigabitEthernet0/2
 ip router isis
 mpls ip
router isis
 net 49.0001.0002.0002.0002.0002.00
 metric-style wide
ip explicit-path name EXCLUDE_P1 enable
 exclude-address 192.168.23.3
ip explicit-path name EXCLUDE_P2 enable
 exclude-address 192.168.24.4
PE2
hostname PE2
ip cef
 ip router isis
 ip address 192.168.67.6 255.255.255.0
 ip router isis
 ip address 192.168.36.6 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.56.6 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0006.0006.0006.0006.00
 metric-style wide
We have two TE tunnels:
PE1#show running-config interface Tunnel 1
interface Tunnel1
 shutdown
PE1#show running-config interface Tunnel 2
interface Tunnel2
 shutdown
Each tunnel uses an explicit path so that tunnel one goes through P1 and tunnel two goes through P2. The tunnels are currently shut down.
IGP Routing
Let’s look first at our IGP routing. With the tunnels disabled, here is the metric to reach the loopback interface (6.6.6.6) of PE2:
PE1#show ip route 6.6.6.6
Routing entry for 6.6.6.6/32
  Known via "isis", distance 115, metric 30, type level-2
  Redistributing via isis
  Last update from 192.168.23.3 on GigabitEthernet0/1, 00:13:31 ago
  Routing Descriptor Blocks:
  * 192.168.23.3, from 6.6.6.6, 00:13:31 ago, via GigabitEthernet0/1
      Route metric is 30, traffic share count is 1
The metric is 30. By default, IS-IS uses a metric of 10 for each interface. Here is the metric to reach the loopback interface (7.7.7.7) of CE2:
PE1#show ip route 7.7.7.7
Routing entry for 7.7.7.7/32
  Known via "isis", distance 115, metric 40, type level-2
  Last update from 192.168.23.3 on GigabitEthernet0/1, 00:13:35 ago
  * 192.168.23.3, from 7.7.7.7, 00:13:35 ago, via GigabitEthernet0/1
      Route metric is 40, traffic share count is 1
The total metric is 40. What we see above is the IGP shortest path to get to these destinations.
Tunnel Interfaces
Now let’s enable our tunnel interfaces:
PE1(config)#interface Tunnel 1
PE1(config-if)#no shutdown
PE1(config)#interface Tunnel 2
First, we’ll check the routing table to see how we reach the loopback of PE2:
  Last update from 6.6.6.6 on Tunnel2, 00:00:12 ago
    6.6.6.6, from 6.6.6.6, 00:00:12 ago, via Tunnel2
  * 6.6.6.6, from 6.6.6.6, 00:00:12 ago, via Tunnel1
TE tunnels use the shortest path IGP metric by default, so we see a metric of 30 here. Our headend router load balances using the two tunnels. Here we see the metric to reach the loopback of CE2:
  Last update from 6.6.6.6 on Tunnel2, 00:00:48 ago
    6.6.6.6, from 7.7.7.7, 00:00:48 ago, via Tunnel2
  * 6.6.6.6, from 7.7.7.7, 00:00:48 ago, via Tunnel1
We see a metric of 40.
To emphasize that TE tunnels use the IGP shortest path, try raising the IS-IS metric on PE1’s interfaces that connect to P1 and P2:
PE1(config)#interface GigabitEthernet 0/1
PE1(config-if)#isis metric 100
PE1(config)#interface GigabitEthernet 0/2
PE1(config-if)#isis metric 200
The path through GigabitEthernet0/1 that connects to P1 will remain the shortest path, but we see the TE tunnel metric increases:
  Known via "isis", distance 115, metric 120, type level-2
  Last update from 6.6.6.6 on Tunnel1, 00:00:15 ago
    6.6.6.6, from 6.6.6.6, 00:00:15 ago, via Tunnel1
      Route metric is 120, traffic share count is 1
  * 6.6.6.6, from 6.6.6.6, 00:00:15 ago, via Tunnel2
Let’s get rid of this metric change:
PE1(config)#interface range GigabitEthernet 0/1 - 2
PE1(config-if-range)#no isis metric
Autoroute Announce
You now know about the default TE tunnel metric behavior. Let’s see how we can influence it. Here are our options:
PE1(config-if)#tunnel mpls traffic-eng autoroute metric ?
  <1-4294967295>  Set tunnel metric for autoroutes
  absolute        Set metric for all autoroutes over tunnel
  relative        Adjust tunnel metric for autoroutes relative to IGP
We’ll try all options.
Metric
The first option overrides the IGP shortest path metric for the tunnel and uses the specified metric instead. Let’s try this:
PE1(config-if)#tunnel mpls traffic-eng autoroute metric 5
Let’s look at the new metric to reach PE2:
  Known via "isis", distance 115, metric 15, type level-2
  Last update from 6.6.6.6 on Tunnel1, 00:00:14 ago
  * 6.6.6.6, from 6.6.6.6, 00:00:14 ago, via Tunnel1
      Route metric is 15, traffic share count is 1
The metric is now 15:
  • TE tunnel: 5
  • Loopback on PE2: 10
Let’s check the new metric to reach CE2:
  Known via "isis", distance 115, metric 25, type level-2
  Last update from 6.6.6.6 on Tunnel1, 00:00:32 ago
  * 6.6.6.6, from 7.7.7.7, 00:00:32 ago, via Tunnel1
      Route metric is 25, traffic share count is 1
The metric is now 25:
  • Full Access to 447 lessons.
