Class-based tunnel selection (CBTS) is an MPLS Traffic Engineering (TE) feature where you can forward traffic with certain EXP values onto different TE tunnels. You can assign one or more EXP values to a tunnel and assign a TE tunnel as the default. This way, you don’t have to assign all EXP values separately.
CBTS is a local mechanism on the headend router and only works for TE tunnels between the same headend and tailend router. We call this “set” of TE tunnels a bundle. There is one master tunnel that bundles the member tunnels.
CBTS is not a routing solution. You still need something like a static route or autoroute to send traffic down the master tunnel interface. When the headend router receives traffic in the master tunnel interface, it will automatically select the correct member tunnel interface based on the EXP value of the packet. That’s the only thing CBTS does.
Let’s see how we configure CBTS. This is the topology I’ll use:
Routers PE1, P1, P2, and PE2 run MPLS TE. I have two TE tunnels from PE1 to PE2. I use IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M4 on all routers.
Want to take a look for yourself? Here you will find the configuration of each device.
CE1
hostname CE1
ip cef
ip router isis
isis circuit-type level-2-only
interface GigabitEthernet0/0
ip router isis
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface GigabitEthernet0/3
no ip address
router isis
net 49.0001.0001.0001.0001.0001.00
is-type level-2-only
metric-style wide
PE1
hostname PE1
ip cef
mpls traffic-eng tunnels
ip router isis
interface Tunnel1
ip unnumbered Loopback0
tunnel mode mpls traffic-eng
tunnel destination 5.5.5.5
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 750
tunnel mpls traffic-eng path-option 1 dynamic
no routing dynamic
interface Tunnel2
no routing dynamic
ip router isis
ip router isis
mpls ip
ip rsvp bandwidth 1000000
ip router isis
mpls ip
router isis
mpls traffic-eng router-id Loopback0
mpls traffic-eng level-2
net 49.0001.0002.0002.0002.0002.00
metric-style wide
mpls ldp router-id Loopback0 force
P1
hostname P1
ip cef
ip router isis
ip router isis
mpls ip
ip address 192.168.35.3 255.255.255.0
ip router isis
mpls ip
router isis
net 49.0001.0003.0003.0003.0003.00
metric-style wide
P2
hostname P2
ip cef
ip router isis
ip router isis
mpls ip
ip address 192.168.45.4 255.255.255.0
ip router isis
mpls ip
no ip address
no ip address
router isis
net 49.0001.0004.0004.0004.0004.00
metric-style wide
PE2
hostname PE2
ip cef
ip router isis
ip address 192.168.56.5 255.255.255.0
ip router isis
ip address 192.168.35.5 255.255.255.0
ip router isis
mpls ip
ip address 192.168.45.5 255.255.255.0
ip router isis
mpls ip
no ip address
router isis
net 49.0001.0005.0005.0005.0005.00
metric-style wide
CE2
hostname CE2
ip cef
ip router isis
ip address 192.168.56.6 255.255.255.0
ip router isis
no ip address
no ip address
no ip address
router isis
net 49.0001.0006.0006.0006.0006.00
metric-style wide
Let’s say we use tunnel 1 for VoIP traffic and tunnel 2 for all other traffic. You would probably use an explicit path option in a production network so that the tunnels use two different paths through the network. For this lab, we won’t need this.
There are two things we need to configure:
- Assign EXP values to member tunnel interfaces.
- Create a new master tunnel interface and add the member tunnel interfaces.
Let’s configure our two member tunnels so that packets with EXP value 5 end up in tunnel 1 and everything else ends up in tunnel 2:
PE1(config)#interface Tunnel 1
PE1(config-if)#tunnel mpls traffic-eng exp 5
PE1(config)#interface Tunnel 2
PE1(config-if)#tunnel mpls traffic-eng exp default
Now we configure the master TE tunnel:
PE1(config)#interface Tunnel 10
PE1(config-if)#ip unnumbered Loopback0
PE1(config-if)#tunnel mode mpls traffic-eng
PE1(config-if)#tunnel destination 5.5.5.5
PE1(config-if)#tunnel mpls traffic-eng autoroute announce
PE1(config-if)#tunnel mpls traffic-eng exp-bundle master
PE1(config-if)#tunnel mpls traffic-eng exp-bundle member Tunnel1
PE1(config-if)#tunnel mpls traffic-eng exp-bundle member Tunnel2
The configuration of the master tunnel interface is the same as the member tunnel interfaces. We turn this tunnel interface into a master tunnel with the tunnel mpls traffic-eng exp-bundle master command. We add the two member tunnel interfaces with the tunnel mpls traffic-eng exp-bundle member command.
I also enable autoroute on the master tunnel interface. That’s all you need to configure.
Quick Question,
Why the TU1 and TU2 tunnels has the destination address as 5.5.5.5 which is PE2 loopback and the master tunnel has 6.6.6.6 which is CE2 loopback
Hello Anudeep
You are correct, the destination address of the master tunnel should be the PE2 router. However, it seems that there was a typo in the configuration. If you look at the final configs at the bottom of the lesson, you will see that the loopback address of PE2 is indeed 6.6.6.6. Rene is aware of this, and will make the appropriate corrections.
Thanks for pointing that out!
Hello @cdeepu702 ,
You are right, I messed something up.
My PE2 router had loopback 6.6.6.6 instead of 5.5.5.5.
The CE2 router had loopback 7.7.7.7 instead of 6.6.6.6.
I just fixed this. It now matches the topology. I’ll have to re-record the video which I’ll do soon.
thanks Rene for the modifications, Just pointed out to make sure if its a typo or there is a concept behind having that IP
