MPLS TE Load Balancing between IGP and TE
When you have a TE tunnel and use something like autoroute to use it in your routing table, you’ll notice that the router installs the tunnel as the next hop for the tailend router and any destinations behind it.
It’s impossible to load balance traffic between your IGP and a TE tunnel to the tailend router. You can’t do this because if you could, it would be impossible to route traffic down a TE tunnel that follows a suboptimal path. Here is an example:
PE1 to PE2: MPLS TE Tunnel 1 through P1 and IGP paths through P1 and through CE2
PE1 is the headend router. PE2 is the tailend router. To get from PE1 to PE2, we have three paths:
  • TE Tunnel:
    • PE1 > P1 > PE2
  • IGP:
    • PE1 > P1 > PE2
    • PE1 > CE2 > PE2
When we use the default IGP metric, these three paths have the same metric.
If PE1 didn’t prefer the TE tunnel, it would load balance traffic using these three paths. The headend router would send only 33% of the traffic through the TE tunnel.
If you want to load balance traffic to your tailend router, you’ll have to use multiple TE tunnels. This works and even supports unequal cost-load balancing.
What is possible is that you can load balance traffic between your IGP and TE tunnel to destinations behind the tailend router. In this lesson, I’ll demonstrate how this works.
Here is our topology:
Lab topology with Gi interfaces, 192.168.x.0/24 subnets, IS-IS metric 10 on every link and CE2 L0 4.4.4.4/32
PE1 is the headend router. PE2 is our tailend router. I configured an explicit path so the tunnel goes through P1. We have three links that are not enabled for MPLS:
  • PE1 – CE2
  • P1 – CE2
  • PE2 – CE2
These three links are only advertised in the IGP (IS-IS). All links have the default IS-IS metric of 10. Our goal is to load balance traffic from PE1 to CE2’s loopback interface using the TE tunnel and IGP links.
All routers use IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6.
CE2
hostname CE2
ip cef
 ip router isis
 isis circuit-type level-2-only
interface GigabitEthernet0/0
 ip address 192.168.14.4 255.255.255.0
 ip router isis
interface GigabitEthernet0/1
 ip router isis
interface GigabitEthernet0/2
 ip router isis
router isis
 mpls traffic-eng level-2
 net 49.0001.0004.0004.0004.0004.00
 is-type level-2-only
 metric-style wide
P1
hostname P1
ip cef
mpls traffic-eng tunnels
 ip router isis
 ip router isis
 mpls ip
 ip rsvp bandwidth 1000000
 ip router isis
 mpls ip
 ip router isis
router isis
 mpls traffic-eng router-id Loopback0
 net 49.0001.0002.0002.0002.0002.00
 metric-style wide
mpls ldp router-id Loopback0 force
PE1
hostname PE1
ip cef
 ip router isis
interface Tunnel1
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 3.3.3.3
 tunnel mpls traffic-eng autoroute announce
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 750
 tunnel mpls traffic-eng path-option 1 explicit name INCLUDE_P1
 ip router isis
 mpls ip
 ip address 192.168.14.1 255.255.255.0
 ip router isis
router isis
 net 49.0001.0001.0001.0001.0001.00
 metric-style wide
ip explicit-path name INCLUDE_P1 enable
 next-address loose 192.168.12.2
PE2
hostname PE2
ip cef
 ip router isis
 ip router isis
 mpls ip
 ip router isis
router isis
 net 49.0001.0003.0003.0003.0003.00
 metric-style wide
Let’s make sure the tunnel is up:
PE1#show mpls traffic-eng tunnels Tunnel 1
Name: PE1_t1                              (Tunnel1) Destination: 3.3.3.3
  Status:
    Admin: up         Oper: up     Path: valid       Signalling: connected
    path option 1, type explicit INCLUDE_P1 (Basis for Setup, path weight 10)
  Config Parameters:
    Bandwidth: 750      kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    Metric Type: TE (default)
    AutoRoute:  enabled   LockDown: disabled  Loadshare: 750      bw-based
    auto-bw: disabled
  Active Path Option Parameters:
    State: explicit path option 1 is active
    BandwidthOverride: disabled  LockDown: disabled  Verbatim: disabled
  InLabel  :  -
  OutLabel : GigabitEthernet0/0, 16
  RSVP Signalling Info:
       Src 1.1.1.1, Dst 3.3.3.3, Tun_Id 1, Tun_Instance 13
    RSVP Path Info:
      My Address: 192.168.12.1
      Explicit Route: 192.168.12.2 2.2.2.2
      Record   Route:   NONE
      Tspec: ave rate=750 kbits, burst=1000 bytes, peak rate=750 kbits
    RSVP Resv Info:
      Record   Route:   NONE
      Fspec: ave rate=750 kbits, burst=1000 bytes, peak rate=750 kbits
  Shortest Unconstrained Path Info:
    Path Weight: 20 (TE)
    Explicit Route: 192.168.12.1 192.168.12.2 192.168.23.2 192.168.23.3
                    3.3.3.3
  History:
    Tunnel:
      Time since created: 12 minutes, 7 seconds
      Time since path change: 11 minutes, 24 seconds
      Number of LSP IDs (Tun_Instances) used: 13
    Current LSP:
      Uptime: 11 minutes, 24 seconds
The tunnel is connected. You can see the explicit route and that autoroute is enabled. Let’s look at the routing table of PE1:
PE1#show ip route isis
i L2     2.2.2.2 [115/20] via 192.168.12.2, 00:12:02, GigabitEthernet0/0
i L2     3.3.3.3 [115/30] via 3.3.3.3, 00:09:50, Tunnel1
i L2     4.4.4.4 [115/20] via 192.168.14.4, 00:09:50, GigabitEthernet0/1
i L2  192.168.23.0/24 [115/20] via 192.168.12.2, 00:09:50, GigabitEthernet0/0
i L2  192.168.24.0/24 [115/20] via 192.168.14.4, 00:07:38, GigabitEthernet0/1
                      [115/20] via 192.168.12.2, 00:07:38, GigabitEthernet0/0
i L2  192.168.34.0/24 [115/20] via 192.168.14.4, 00:09:50, GigabitEthernet0/1
In the output above, we see:
  • We only use tunnel 1 to reach the tailend router (3.3.3.3). The metric is 30.
  • We use the direct IGP path to CE2 to reach the loopback interface of CE2 (4.4.4.4).  The metric is 20.
There are three paths to get from PE1 to CE2:
  • TE Tunnel:
    • PE1  > PE2 > CE2
  • IGP:
    • PE1 > CE2
    • PE1 > P1 > CE2
Let’s see if we can play with the IS-IS metric so that PE1 load balances traffic on these three paths to reach CE2. The metric of the TE tunnel is the same as the shortest IGP path. To get from PE1 to PE2, we must cross two GigabitEthernet links. That’s a metric of 20.
To get from PE2 to CE2’s loopback interface, we must cross one GigabitEthernet link (10) and the loopback of CE2 (10) for a total metric of 20. The total metric through the TE tunnel to CE2’s loopback is 40.
I’ll increase the metric on the direct link from PE1 to CE2 so that it is equal to the total metric of the TE tunnel:
  • Full Access to 448 lessons.
