MPLS TE Unequal Cost Load Balancing
Regular IP routing uses equal-cost load balancing (or sharing). EIGRP is an exception because it can load balance over feasible successors. When multiple paths with the same metric exist between two routers, traffic is distributed evenly across those paths. Depending on your IOS version and platform, the router supports up to 32 parallel paths.
Load balancing traffic on your network by changing the IGP metric can be challenging. You can change the metric on one link to steer the traffic in a particular direction, only to discover that it also influences routing in another part of the network you didn’t think of.
With MPLS TE, load balancing is much easier, and unequal cost load sharing works out of the box. When you have two TE tunnels to the same destination, the router can load balance its traffic. When the bandwidth of two tunnels is the same, we’ll do equal-cost multi-path load balancing. When you have different bandwidths, we’ll do unequal cost-load balancing.
The router does so by looking at the configured bandwidth on the tunnel interfaces. We divide the bandwidth of a TE tunnel interface by the sum of bandwidths on all tunnel interfaces.
For example, let’s say we have two tunnel interfaces:
  • Tunnel one: bandwidth 1000 kbps.
  • Tunnel two: bandwidth 2000 kbps.
Tunnel one would get 1000 / 3000 = ~33% of the traffic, and tunnel two 2000 / 3000 = ~66%.
When the router wants to create a new tunnel, RSVP checks the bandwidth request of the tunnel against the available bandwidth. If there is not enough bandwidth, the tunnel won’t come up (unless it can preempt an existing tunnel with its setup and hold priority).  This can be an issue if you want to change the bandwidth for load-balancing reasons. There is another option. If you want to configure load sharing without taking bandwidth into account, you can also use the tunnel mpls traffic-eng load-share command.
If you use this command, it will be used for load sharing. Bandwidth will only be used for RSVP reservations.
Let’s take a look at load sharing in action. Here is our topology:
Tunnel 1 from PE1 through P1 to PE2 and Tunnel 2 from PE1 through P2 and P3 to PE2
We have two tunnels between PE1 (headend) and PE2 (tailend). We use autoroute to install the tunnels in our routing table. I use IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6 on all routers.
CE1
hostname CE1
ip cef
 ip router isis
 isis circuit-type level-2-only
interface GigabitEthernet0/0
 ip router isis
router isis
 net 49.0001.0001.0001.0001.0001.00
 is-type level-2-only
 metric-style wide
CE2
hostname CE2
ip cef
 ip address 7.7.7.7 255.255.255.255
 ip router isis
 ip address 192.168.67.7 255.255.255.0
 ip router isis
router isis
 mpls traffic-eng level-2
 net 49.0001.0007.0007.0007.0007.00
 metric-style wide
P1
hostname P1
ip cef
mpls traffic-eng tunnels
 ip router isis
 ip router isis
 mpls ip
 ip rsvp bandwidth 1000000
interface GigabitEthernet0/1
 ip address 192.168.36.3 255.255.255.0
 ip router isis
 mpls ip
router isis
 mpls traffic-eng router-id Loopback0
 net 49.0001.0003.0003.0003.0003.00
 metric-style wide
mpls ldp router-id Loopback0 force
P2
hostname P2
ip cef
 ip router isis
 ip router isis
 mpls ip
 ip address 192.168.45.4 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0004.0004.0004.0004.00
 metric-style wide
P3
hostname P3
ip cef
 ip router isis
 ip address 192.168.56.5 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.45.5 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0005.0005.0005.0005.00
 metric-style wide
PE1
hostname PE1
ip cef
 ip router isis
interface Tunnel1
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 6.6.6.6
 tunnel mpls traffic-eng autoroute announce
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 1000
 tunnel mpls traffic-eng path-option 1 explicit name P2_EXCLUDE
 no routing dynamic
interface Tunnel2
 tunnel mpls traffic-eng bandwidth 2000
 tunnel mpls traffic-eng path-option 1 explicit name P1_EXCLUDE
 no routing dynamic
 ip router isis
 ip router isis
 mpls ip
interface GigabitEthernet0/2
 ip router isis
 mpls ip
router isis
 net 49.0001.0002.0002.0002.0002.00
 metric-style wide
PE2
hostname PE2
ip cef
 ip router isis
 ip address 192.168.67.6 255.255.255.0
 ip router isis
 ip address 192.168.36.6 255.255.255.0
 ip router isis
 mpls ip
 ip address 192.168.56.6 255.255.255.0
 ip router isis
 mpls ip
router isis
 net 49.0001.0006.0006.0006.0006.00
 metric-style wide
Verification
The two tunnel interfaces have different bandwidths:
PE1#show run interface Tunnel 1
interface Tunnel1
 no routing dynamic
PE1#show run interface Tunnel 2
interface Tunnel2
 no routing dynamic
  • Tunnel one requests a bandwidth of 1000 kbps.
  • Tunnel two requests a bandwidth of 2000 kbps.
I also use an explicit-path to send tunnel one through P1 and tunnel two through P2.
Autoroute Announce
Here’s how the headend router uses these two tunnels:
PE1#show ip route 6.6.6.6
Routing entry for 6.6.6.6/32
  Known via "isis", distance 115, metric 30, type level-2
  Redistributing via isis
  Last update from 6.6.6.6 on Tunnel2, 00:44:43 ago
  Routing Descriptor Blocks:
    6.6.6.6, from 6.6.6.6, 00:44:43 ago, via Tunnel2
      Route metric is 30, traffic share count is 2
  * 6.6.6.6, from 6.6.6.6, 00:44:43 ago, via Tunnel1
      Route metric is 30, traffic share count is 1
Both tunnels are installed in the routing table because they share the same metric. The reason why these tunnels have the same metric is explained in the autoroute metric lesson. You can see we have a 2:1 traffic share count.
Here we can see the routes that are announced to the IGP:
  • Full Access to 447 lessons.
  1. Avatar for gabai784 gabai784 says:
    hey Rene,
    i’m trying to configure mpls te tunnels in a lab and i would like to know if there is a way to load-balance the hops of a tunnel.
    for example, i have one ethernet line between 2 routers (P To P) and i want to add another line between them with the same bandwidth and affinity value.
    before adding the line’the tunnel is going exactly as it should be but when i add the second line, its not load-balancing on the lines between the routers and going only on one of them.
    there is a way to do this?
    Hello Dorel
    Keep in mind that each LSP tunnel will take a specific physical path through the MPLS topology. The tunnel itself cannot be load-balanced across two physical links. The only way to achieve load balancing of the traffic is to create two tunnels and load balance across them.
    If you do this, you should be able to achieve load balancing between tunnels that go through different links. Now keep in mind that there are two mechanisms working here:
    The first has to do with the path that each individual tunnel takes
    The second has to do with how
