Cisco ASA Hairpin Remote VPN Users
The Cisco ASA firewall doesn’t like traffic that enters and exits the same interface. This behavior is typically known as “hairpin” or “u-turn”. Sometimes however we need our ASA to permit this kind of traffic. Here’s an example:
Cisco ASA Remote Access VPN Hairpin
Above we have an ASA firewall on the left side, there’s a remote VPN uses that connects to our firewall. This remote VPN user is not using split tunneling so all traffic is being tunneled to the ASA. Let’s say this user wants to reach some webserver (2.2.2.2) on the Internet behind R2.
Here’s what our traffic pattern will look like:
Cisco ASA Remote Access VPN Hairpin Traffic
Our traffic will enter the ASA on its outside Gigabit 0/0 interface and exits the same interface. By default, the ASA will drop this traffic. The second issue with this setup is that the source IP address will be from the 192.168.10.0/24 subnet. Since this is a private range, R2 will drop the traffic when it has to be routed to the Internet.
Let’s see what we have to do to fix this issue…
Startup Configurations
R2
hostname R2
interface GigabitEthernet0/1
 duplex auto
 speed auto
 media-type rj45
ip http server
ASA1
hostname ASA1
ip local pool VPN_POOL 192.168.10.100-192.168.10.200
interface GigabitEthernet0/0
 nameif OUTSIDE
 security-level 0
ftp mode passive
object network VPN_POOL
 subnet 192.168.10.0 255.255.255.0
route OUTSIDE 0.0.0.0 0.0.0.0 192.168.2.2 1
crypto ipsec ikev1 transform-set MY_TRANSFORM_SET esp-aes esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map MY_DYNA_MAP 10 set ikev1 transform-set MY_TRANSFORM_SET
crypto map MY_CRYPTO_MAP 10 ipsec-isakmp dynamic MY_DYNA_MAP
crypto map MY_CRYPTO_MAP interface OUTSIDE
crypto isakmp identity address
crypto ikev1 enable OUTSIDE
crypto ikev1 policy 10
 authentication pre-share
 encryption aes
 hash sha
 group 2
 lifetime 86400
group-policy VPN_POLICY internal
group-policy VPN_POLICY attributes
 vpn-idle-timeout 15
dynamic-access-policy-record DfltAccessPolicy
username VPN_USER password E5PbZWWQ.j3bJJHz encrypted
tunnel-group MY_TUNNEL type remote-access
tunnel-group MY_TUNNEL general-attributes
 address-pool VPN_POOL
 default-group-policy VPN_POLICY
tunnel-group MY_TUNNEL ipsec-attributes
 ikev1 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ip-options
  inspect netbios
  inspect rtsp
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
  inspect icmp
policy-map type inspect dns migrated_dns_map_1
 parameters
service-policy global_policy global
: end
Let’s take a look at the configuration…
There are two things we have to fix here:
  • We need to configure the ASA to permit traffic that enters and exits the same interface.
  • Traffic from the 192.168.10.0/24 subnet has to be NAT translated.
Before we make any changes, let’s try a ping from our remote VPN user:
C:\Users\H1>ping 2.2.2.2
Pinging 2.2.2.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2.2.2.2:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
As expected these pings are failing. Let’s configure the ASA to permit traffic that enters and exits the same interface:
ASA1(config)# same-security-traffic permit intra-interface
The command above will allow the traffic to be routed. The second thing to do is to configure a NAT rule:
  • Full Access to our 801 Lessons. More Lessons Added Every Week!
2396 Sign Ups in the last 30 days
satisfaction-guaranteed
  • No Questions Asked!
  1. Hi Rene,
    Nice Article . Please carry on .
    br/
    zaman
  2. Hi Rene,
    ASA1(config)# nat (OUTSIDE,OUTSIDE) source dynamic VPN_POOL interface
    I got few doubt about the above statements
    [1] Why is the key word SOURCE used in the NAT statement
    [2] waht effect it would make if the Dynamic is changed to Static in NAT statment
  3. STATIC is a one to 1 mapping ie public 8.8.8.8 maps to private 10.10.10.1 all the time.
    DYNAMIC would be used if you had multiple connections that needed to be NATTed as you can then define a range of IP addresses using an access list and when a NAT translation needed to be made, then it would use a free public IP address from the access list.
  4. Rene,
    I was thinking through how to lab up this lesson and was having trouble on the layout for the cloud that labeled outside and the vpn user. I was thinking the cloud was a router with regular ospf passing all traffic and the vpn user… Could you point me in the right direction (configs) on how to lab up this lesson
    thank you
  5. Hello Christopher
    Yes, actually, you’re on the right track. You can create a router with three interfaces, each on a different subnet. Say something like this:
    https://cdn-forum.networklessons.com/uploads/default/original/1X/faa6c2a873f74ae636d9ace51661a2d25e161669.jpg
    In this case, all of the 10.10.X.X address space can be considered “the Internet.”
    You can use OSPF if you like to convey routing information to all routers involved, or you could use static routing if you like as well. Just keep in mind that both the ASA and R2 must be informed of each other’
9 more replies! Ask a question or join the discussion by visiting our Community Forum
