Cisco’s CCNP R&S track currently has 3 exams, ROUTE, SWITCH and TSHOOT. Pass all three exams, and you will be CCNP R&S certified. I receive many questions from students asking what the best method is to study for these exams and how to prepare themselves. In this lesson, I’ll explain what you will encounter on the exams and the best way to pass the exams.
Knowledge Foundation
Before I dive into CCNP R&S, let’s talk a little bit about CCNA R&S first. I will assume that you passed the CCNA exam and now you are looking to become CCNP R&S certified. Before you start with the CCNP material, you should consider if your “knowledge foundation” is strong enough. Most of the topics in CCNP are not new but will be more in-depth than what you learned from CCNA. To illustrate this, take a good look at the Cisco certification pyramid:
Most students don’t pay a lot of attention to this picture but if you take a good look, you’ll see that CCNA is the largest part of the pyramid. If you want to pass the CCNP exams, you will have to be absolutely 100% comfortable with the things you learned in CCNA R&S. If it’s been a while since you became CCNA certified, please do yourself a favor and re-read your CCNA material or do some more CCNA level labs. If you have difficulty doing subnetting questions without a calculator or have no idea anymore how spanning tree, frame-relay, OSPF, and EIGRP work…then CCNP will be a very bumpy ride. If you are familiar with everything from CCNA, then CCNP will be a very enjoyable ride! Be honest with yourself, even if you passed the CCNA exam…if you had some difficulties with certain topics, visit those again and make sure you have no knowledge gaps. If you want to learn how to ride a motorcycle, you should start learning how to ride a bike…having said that, let’s look at the CCNP R&S exams!
ROUTE
Let’s start with an overview of all the major ROUTE topics:
- EIGRP Packets and Metrics
- EIGRP Summarization
- EIGRP over Frame-Relay
- EIGRP Authentication
- EIGRP Advanced Features
- OSPF LSA Types
- OSPF Summarization
- OSPF Special Area Types
- OSPF Authentication
- OSPF Virtual Links
- Routing Manipulation
- Redistribution
- BGP (Border Gateway Protocol)
- IPv6 Routing Protocols
- IPv6 Tunneling
In short, the ROUTE exam is about EIGRP, OSPF, some routing “manipulation”, BGP, and IPv6. You already learned about EIGRP and OSPF and a little bit of IPv6 in CCNA so these should be familiar topics. You will learn (a lot) more about them, however. For example, in CCNA you learned about OSPF and its LSDB (Link State Database) but in CCNP you will take a close look at all the LSA types that fill the LSDB. You learned about IPv6 in CCNA, but now you will also learn some migration and tunneling techniques so you can connect IPv6 networks over existing IPv4 networks. If you forgot about the difference between EIGRP/OSPF and things like “link state” vs “distance vector” then please re-visit the CCNA material before you dive into ROUTE.
My recommendation is to start with the ROUTE exam first since you will find some routing-related topics in the SWITCH exam, while there are no “switch” topics in the ROUTE exam. Also, you won’t need any hardware to study for this exam since you can do everything with the GNS3 router emulator!
SWITCH
Let me show you the major topics of the SWITCH exam:
- VLANs and Trunking
- Private VLANs
- Spanning Tree Basics
- Rapid Spanning Tree
- MST (Multiple Spanning Tree)
- Spanning Tree Toolkit
- Etherchannel (Link Aggregation)
- InterVLAN Routing
- Gateway Redundancy (VRRP, GLBP, HSRP)
- Switch Security
Some of these topics should ring a bell. You learned about VLANs and Trunks from CCNA, but you’ll learn more about them. Spanning tree should be familiar, but you will learn about the different flavors like “rapid” spanning tree and Multiple spanning tree in-depth. Etherchannels were mentioned in CCNA, but now you’ll learn about the different types and how to configure them. There are also some “multilayer” switch topics like routing between VLANs and creating virtual gateways for clients using VRRP, GLBP, and HSRP. In CCNA, you learned about port-security, which is also in the SWITCH exam, but you’ll also learn about DHCP and ARP snooping. Last but not least, you will learn how to prepare your switched network for Voice over IP, Video, and/or wireless networking.
If you are fuzzy about spanning tree and its port states like the designated, non-designated, root port, port priority, and such…please take a look at the CCNA material again before you start with SWITCH!
To study SWITCH at home, you will need some real hardware switches. GNS3 can only emulate routers and the NM-16ESW switch module, which doesn’t support rapid spanning tree, multiple spanning tree or the different etherchannel protocols. You don’t need expensive hardware, my recommendation is to buy 2x Cisco Catalyst 2950 switches and 1x Cisco Catalyst 3550 switch. For more information, take a look at my CCNA hardware recommendation lesson. Most of it also applies to the CCNP SWITCH exam.
TSHOOT
The TSHOOT exam is different compared to what you have seen so far. The ROUTE and SWITCH exams are similar to CCNA, you will get some multiple-choice questions, labs, click-all-that-apply questions, etc.
TSHOOT is different as the exam will present you with a (large) network topology that has a number of issues. You don’t have to fix these issues, but you have to be able to look at the configurations of the devices and answer what the problem is. If you want to pass this exam, there are two things you will have to do:
- Truly understand all the topics that you learned in CCNA, ROUTE, and SWITCH.
- Become familiar with the topology that Cisco uses in the TSHOOT exam.
There is no “magic” troubleshooting technique that will help you solve any problem. The only way to become good at troubleshooting is to understand all the protocols and how they work together. You can become good at troubleshooting by doing labs, breaking stuff,
Cisco released the TSHOOT exam topology to the public. Take a good look at it to understand all the different components. You don’t want to see this topology for the first time when you are doing the exam…
CCNP Study Strategy
You now have an idea what the exams are about and that it’s best to start with ROUTE, SWITCH, and finish with TSHOOT. So where do you start?
As you are reading, stick to one topic at a time, and don’t read the book from front to back right away. As you are reading and learning about a topic or feature, try to configure it yourself on your GNS3 routers or switches and make sure you understand what you are doing. Look at some show commands, and try some debugs. I can’t emphasize enough how important it is to do labs, labs and even more labs. Most people make the mistake of trying to “brute force” all the theory in their heads and doing not enough labs. If you want to know why I’m such a big fan of labs, please read my “How to study Cisco and Networking” lesson.
Also, as you are working your way through a chapter, make sure to take notes:
- Use mindmapping to write down all the “theory” in a structured order. You can learn how to do this in my “How to use Mindmapping” lesson.
- Take notes (I use notepad) to write down some of the commands that you have difficulty with remembering. This helps to speed up doing labs.
Once you have mastered a topic, move on to the next chapter. Try to focus on 1 item at a time instead of reading about everything at the same time. Focusing is your friend when it comes to studying.
Hey Rene, this is a very enlighting lesson. My question is: based on real job demands, would you say that a mastery on multi-area OSPF would seem much more useful than EIGRP, aside from the exam?
Hi Apostolis,
The short answer is that you will probably see more OSPF than EIGRP since OSPF is an “open standard” and EIGRP only runs on Cisco devices. Cisco submitted EIGRP to IETF to become an open standard as well so maybe in the future you’ll see it on other vendor routers and it might become a bit more popular…
You’ll see multi-area OSPF when you have larger networks that require summarization (since OSPF can only summarize between areas).
Also, keep in mind that it really depends on the job what you will encounter. If you work on the internal network of
... Continue reading in our forumGreat! Thanks for the feedback, seems quite useful. I got my CCNA r&s last June, with a little internship work experience, prospects in Greece for finding a job ranges from difficult to extremely difficult.
Anyways, I 've already started studying for CCNP r&s and I was wondering whether I should go straight for it, or pick a specific certification. My inclination lies more upon on SP, but as far as I can see, VoIP, Security and Wireless are very popular (I was thinking on taking a bite of VoIP/Video)
What would you advise on that?
oh, btw, your GNS3 labs seem
... Continue reading in our forumHi Rene.. greetings from Venezuela:
i’m about to start the CNNA module 4 (wan technologies) and i want to buy some cisco’s equipment for me personal lab.
as you just said, i’m looking to buy 1 router C2950 and 2 switches C3640 but i can’t find a single web where it shows me which one is the last IOS version for those equipments.
where can i find that kind of information?
thx!
Hello Juan,
The Cisco website is where you can find this kind of information, look at the support section.
