Internal BGP (Border Gateway Protocol) Explained
Internal BGP (IBGP) means we run BGP between routers within the same autonomous system (AS). External BGP (EBGP) is used between routers that are in different ASes. You might be wondering, why not use an IGP like OSPF or EIGRP inside the AS?
The IPv4 Internet routing table contains more than one million prefixes, and IGPs are not designed for this scale. When you learn prefixes from different ASes with EBGP, they can be advertised through IBGP without issues. Another reason is that BGP stores quite a lot of information about its prefixes with attributes. For example, the AS Path. When you redistribute prefixes into an IGP, that information is lost.
In this lesson, I’ll explain how IBGP works and how to configure it. We’ll also look at issues such as next hop reachability and the IBGP split horizon rule.
Key Takeaways
  • IBGP runs between routers in the same AS.
  • IBGP requires an underlying IGP (like OSPF or EIGRP) for connectivity between IBGP neighbors
  • IBGP does not change the next hop by default, which can cause reachability issues. These can be solved with:
    • The next-hop-self command to change the next hop to the IBGP router.
    • Advertising an additional prefix with the network command.
  • Loopback interfaces for IBGP neighbor adjacencies are a best practice because:
    • They never go down
    • You can have path redundancy if you have two or more equal routes to your BGP neighbor.
  • IBGP split horizon means that prefixes learned from one IBGP neighbor are not advertised to another IBGP neighbor.
  • IBGP requires a full mesh, meaning all IBGP routers must peer with each other.
  • All routers in a transit AS require IBGP to prevent traffic black holes.
Explanation
Let’s start with an example topology, and I’ll explain a couple of things:
5 Routers AS1 AS2 AS3
Above, you see three autonomous systems and five routers. When AS1 wants to reach AS3, we have to cross AS2. This makes AS2 our transit AS. This is a typical scenario where AS1 and AS3 are customers and AS2 is the ISP.
In our scenario, AS1 has a loopback interface with network 1.1.1.0 /24, and AS3 wants to reach this network. This means we’ll have to advertise this network through BGP. Here’s what it looks like:
Bgp Synchronization Example Topology Ibgp Ebgp
So what is going on here? Let me explain it step-by-step:
  1. We need EBGP between AS1 and AS2 because these are two different autonomous systems. This allows us to advertise a prefix on R1 in BGP so that AS2 can learn it.
  2. We also need EBGP between AS2 and AS3 so R5 can learn prefixes through BGP.
  3. We need to get the prefix that R2 learned from R1 somehow to R5. We do this by configuring IBGP between R2 and R4, this allows R4 to advertise it to R5.
So that’s the first reason we need IBGP…so you can advertise a prefix from one autonomous system to another. You might have a few questions after reading this:
  1. Why don’t we use OSPF (or EIGRP) on AS2 instead and redistribute the prefix on R2 from BGP into OSPF and on R4 from OSPF back into BGP?
  2. Doesn’t IBGP have to be directly connected?
  3. How are R2 and R4 able to reach each other through IBGP if we don’t have any routing protocol within AS2?
  4. What about R3? do we need IBGP?
These are some of the questions I get all the time from students who are learning BGP. Here are the answers:
  1. Technically this is possible…we can run OSPF (or EIGRP) within AS2 and use redistribution between BGP and OSPF. In my example, R1 will only have a single prefix, so it’s no problem, but what if R1 had a full internet routing table? (over one million IPv4 prefixes). IGPs like OSPF or EIGRP are not able to handle that many prefixes so you’ll need BGP for this.
  2. IBGP does not have to be directly connected, this might be a little confusing when you only know about OSPF or EIGRP since they always form adjacencies on directly connected links.
  3. They are not! This is why we need an IGP within the AS. Since R2 and R4 are not directly connected, we’ll configure an IGP so that they can reach each other.
  4. I’ll give you the answer to this question in a bit…I want to show you what will go wrong if we don’t configure R3 🙂
Enough reading for now. Let’s get our hands dirty with some configuration. We’ll start with BGP between R1/R2, R2/R4, and R4/5 as I just described.
First, we’ll configure R1 and R2. I am also advertising a prefix (on a loopback interface) in BGP:
R1(config)#interface loopback 0
R1(config-if)#ip address 1.1.1.1 255.255.255.0
R1(config)#router bgp 1
R1(config-router)#network 1.1.1.0 mask 255.255.255.0
R2(config-router)#neighbor 192.168.12.1 remote-as 1
That’s easy enough, just a few commands. Our next step will be to configure IBGP between R2 and R4…what IP addresses are we going to use for this? Let’s look at our options:
R2#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.12.2    YES NVRAM  up                    up
FastEthernet1/0            192.168.23.2    YES NVRAM  up                    up
R4#show ip interface brief
FastEthernet0/0            192.168.34.4    YES NVRAM  up                    up
FastEthernet1/0            192.168.45.4    YES NVRAM  up                    up
I can use any of these IP addresses, but we need connectivity. That’s why we need an IGP like we talked about earlier. So, which IP addresses will we select? In this particular scenario, it really doesn’t matter since there is only 1 path between R2 and R4. What if we had multiple paths between R2 and R4?
When there are multiple paths, it’s better to use a loopback interface with an IP address and to advertise that into your IGP. We will use the loopback interface as the source for our BGP session. Why?
A physical interface can go down, which means the IP address on the interface is no longer reachable. A loopback interface will never go down unless the router crashes or when you “shut” it. This is why it’s best practice to use loopback interfaces when configuring IBGP.
I’ll add a loopback interface on R2 and R4 and use these for IBGP, we’ll have to configure an IGP (I’ll use OSPF) to advertise them:
R2(config)#interface loopback 0
R2(config-if)#ip address 2.2.2.2 255.255.255.0
R4(config)#interface loopback 0
R4(config-if)#ip address 4.4.4.4 255.255.255.0
That takes care of the loopback interfaces. Now we can enable OSPF:
R2(config)#router ospf 1
R2(config-router)#network 2.2.2.0 0.0.0.255 area 0
R3(config)#router ospf 1
R3(config-router)#network 192.168.34.0 0.0.0.255 area 0
R4(config)#router ospf 1
R4(config-router)#network 192.168.34.0 0.0.0.255 area 0
R4(config-router)#network 4.4.4.0 0.0.0.255 area 0
Excellent, R2 and R4 will now be able to reach each other’s loopback interfaces. It’s not a bad idea to test this though:
R2#ping 4.4.4.4 source 2.2.2.2
Sending 5, 100-byte ICMP Echos to 4.4.4.4, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/52/60 ms
Alright we are now prepared for IBGP between R2 and R4. Here’s what it looks like:
R2(config)#router bgp 2
R2(config-router)#neighbor 4.4.4.4 remote-as 2
R2(config-router)#neighbor 4.4.4.4 update-source loopback 0
R4(config)#router bgp 2
R4(config-router)#neighbor 2.2.2.2 remote-as 2
R4(config-router)#neighbor 2.2.2.2 update-source loopback 0
This takes care of our IBGP session. Note that we have to use the update-source command to specify that we will use the loopback interfaces as the source for the IBGP session.
Last but not least, let’s configure EBGP between R4 and R5:
R4(config-router)#neighbor 192.168.45.5 remote-as 3
R5(config)#router bgp 3
R5(config-router)#neighbor 192.168.45.4 remote-as 2
Great, that takes care of that. Whenever you configure BGP, you will see a message on the console that shows you that the neighbor adjacency has been established. You can also check it with the show ip bgp summary command.
Verification
If everything went OK, all routers should have learned about the 1.1.1.0 /24 prefix that I advertised on R1. Let’s see if that is true:
First, we’ll check R1:
R1#show ip bgp
BGP table version is 2, local router ID is 1.1.1.1
              r RIB-failure, S Stale
*> 1.1.1.0/24       0.0.0.0                  0         32768 i
You can see that it is in the BGP table. This means that I successfully used the network command to advertise into BGP. The next hop is 0.0.0.0 since it originated on this router. If you don’t see anything here, then normally there are two reasons for this:
  • You can’t advertise something in BGP that is not in your routing table. Make sure the interface is up/up.
  • You typed an incorrect subnet mask when you used the network command (it has to be an exact match!).
Let’s see what R2 thinks about this:
R2#show ip bgp
BGP table version is 2, local router ID is 2.2.2.2
*> 1.1.1.0/24       192.168.12.1             0             0 1 i
That’s looking good too. R2 knows about our prefix, you can see that the next hop is the IP address of R1. If you take a closer look, you can see the > symbol in front of the prefix, this means that the router selected this entry as the best one and that it installed it in the routing table. Let’s check R4, it should receive this information from R2:
R4#show ip bgp
BGP table version is 1, local router ID is 4.4.4.4
* i1.1.1.0/24       192.168.12.1             0    100      0 1 i
R4 learned about the prefix, but there’s something going on here…there is no > symbol before the prefix, so R4 didn’t install this in the routing table. Can you tell why this is happening? Take a close look at the next hop…I’ll give you the answer in a second, let’s check R5 first:
R5#show ip bgp
There’s nothing in R5…that’s because R4 is having some issues. Look closely:
Does R4 have any idea how to reach the next hop? BGP doesn’t change the next hop IP address by default, so this can cause some issues. Let’s verify if R4 knows how to reach the next hop:
R4#show ip route 192.168.12.1
% Network not in table
No next hop, so we can’t install the prefix from BGP into the routing table…how are we going to fix this? As always, there are multiple options:
  • Advertise network 192.168.12.0 /24 in a routing protocol (IGP or BGP).
  • Change the next hop IP address with the next-hop-self command.
I’ll change the next hop IP address since it’s a good practice. Here’s how it works:
R2(config-router)#neighbor 4.4.4.4 next-hop-self
R4(config-router)#neighbor 2.2.2.2 next-hop-self
I’m doing this on both R2 and R4. For this scenario, I don’t have to do it, but if I would advertise something on R5, then R2 would have the same problem as R4. Take a look again at R4 to see the changes:
R4#show ip bgp
BGP table version is 2, local router ID is 4.4.4.4
*>i1.1.1.0/24       2.2.2.2                  0    100      0 1 i
Excellent….two important changes here. First of all, you see the > symbol, which means R4 was able to install this prefix in the routing table. Secondly, the next hop IP address has been changed to something R4 knows (the loopback interface of R2).
Since R4 is now able to install it in the routing table, it can advertise the prefix to R5:
R5#show ip bgp
BGP table version is 2, local router ID is 5.5.5.5
*> 1.1.1.0/24       192.168.45.4                           0 2 1 i
R5 has learned about the prefix…so far, so good. You can see that it’s in the routing table:
R5#show ip route bgp
B       1.1.1.0 [20/0] via 192.168.45.4, 00:02:08
That’s looking good. So, are we done? Is there connectivity? Let’s find out:
R5#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Uh-oh…something went wrong. This is often a very frustrating moment for many BGP students; they see something in the routing table, but it doesn’t work. What is going on here?
Let’s do a quick trace from R5 to see how far we can get to R1:
R5#traceroute 1.1.1.1
Tracing the route to 1.1.1.1
  1 192.168.45.4 52 msec 16 msec 32 msec
  2  *  *  *
  3  *  *  *
So, our IP packet reached R4, but after that, it went somewhere into oblivion. R4 is not the problem, so we’ll have to check the next device in the path towards R1. That’s R3.
R3 is an interesting router since it doesn’t run BGP, only OSPF. Let’s check R3:
R3#show ip route 1.1.1.0
There’s our problem: R3 receives an IP packet with destination 1.1.1.1 but has no clue where to send it, so it will be dropped. How do we fix this?
Once again, you could redistribute BGP into OSPF, but that’s a bad idea…1 prefix could work, but an entire internet routing table is not gonna happen!
This is why you need IBGP on all your routers in your transit AS. We need to configure IBGP on R3, so it learns about our 1.1.1.0 /24 prefix and will know how to reach the destination.
Just like R2 and R4, I’ll use a loopback interface on R3 as the source of our IBGP session.
I will configure IBGP between R2/R3 and R3/R4.  Let’s create a loopback, advertise it in OSPF, and configure BGP:
R3(config)#interface loopback 0
R3(config-if)#ip address 3.3.3.3 255.255.255.0
R3(config-router)#network 3.3.3.0 0.0.0.255 area 0
R3(config)#router bgp 2
R3(config-router)#neighbor 2.2.2.2 remote-as 2
R3(config-router)#neighbor 2.2.2.2 update-source loopback 0
R3(config-router)#neighbor 4.4.4.4 remote-as 2
R3(config-router)#neighbor 4.4.4.4 update-source loopback 0
That takes care of R3, now we’ll configure R2 and R4 to peer with R3:
R2(config-router)#neighbor 3.3.3.3 remote-as 2
R2(config-router)#neighbor 3.3.3.3 update-source loopback 0
R2(config-router)#neighbor 3.3.3.3 next-hop-self
R4(config-router)#neighbor 3.3.3.3 remote-as 2
R4(config-router)#neighbor 3.3.3.3 update-source loopback 0
R4(config-router)#neighbor 3.3.3.3 next-hop-self
This will establish IBGP between R2/R3 and R3/R4. Take a look at the BGP table of R3:
R3#show ip bgp
BGP table version is 2, local router ID is 3.3.3.3
Very nice…R3 now knows how to reach the 1.1.1.0 /24 network, so it’s no longer the problem. Can R5 finally reach R1? Let’s find out:
R5#ping 1.1.1.1
It still doesn’t work. I’ll show you what the problem is here…
It’s a good idea to check some of the routers that are closer to R1, and see if they are able to ping 1.1.1.1. Let’s start with R2:
R2#ping 1.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/24 ms
No problem for R2, what about R3?
R3#ping 1.1.1.1
R3 is unable to reach R1…interesting! Previously, we checked the BGP and routing table of R3, and it has all the information required to reach R1. What could go wrong here? The problem is not R3, but it’s R1..take a look here:
R1#show ip route
C       1.1.1.0 is directly connected, Loopback0
This is all that R1 has in its routing table. What happens is that R1 receives an IP packet from R3 that looks like this:
  • Source IP address: 192.168.23.3
  • Destination IP address: 1.1.1.1
When R1 wants to reply to 192.168.23.3, it has no clue where to send it…it’s not in its routing table! If you want you can verify this with a debug:
R1#debug ip packet
IP packet debugging is on
This will show us what happens when R1 receives the IP packet. Don’t do this on a production router, as it will produce way too much debug information:
R1#
IP: s=1.1.1.1 (local), d=192.168.23.3, len 100, unroutable
R1 says it’s unroutable. The destination is unknown. To fix this problem, we have to advertise some additional networks. I don’t care about R3 being able to reach R1, but I do want R5 to reach R1.
What we’ll do is advertise the 192.168.45.0 /24 prefix into BGP, we can do this on R4 or R5:
R5(config-router)#network 192.168.45.0 mask 255.255.255.0
Let’s see if R1 learns this prefix:
R1#show ip bgp
BGP table version is 3, local router ID is 1.1.1.1
*> 192.168.45.0     192.168.12.2                           0 2 3 i
It’s in the BGP table and also in the routing table:
R1#show ip route bgp
B    192.168.45.0/24 [20/0] via 192.168.12.2, 00:00:50
Let’s try a ping:
R5#ping 1.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 84/104/120 ms
Finally! it’s working! If you also want to ping R1 from any of the other routers, then you need to make sure R1 knows where to send the return traffic.
Want to take a look for yourself? Here, you will find the final configuration of each device.
R1
hostname R1
ip cef
interface FastEthernet0/0
router bgp 1
 bgp log-neighbor-changes
R2
hostname R2
ip cef
interface FastEthernet0/1
router ospf 1
router bgp 2
 neighbor 3.3.3.3 update-source Loopback0
R3
hostname R3
ip cef
router ospf 1
router bgp 2
 neighbor 2.2.2.2 update-source Loopback0
R4
hostname R4
ip cef
 ip address 192.168.45.4 255.255.255.0
router ospf 1
router bgp 2
R5
hostname R5
ip cef
 ip address 192.168.45.5 255.255.255.0
router bgp 3
Are we done now? Almost…there’s one more thing I want to teach you about the IBGP neighbor adjacencies…
IBGP Neighbor Adjacencies
Right now, our routers within AS2 are configured like this:
R2 R3 R4 full mesh IBGP
This is called full-mesh IBGP. All routers within AS 2 are neighbors with each other. Do we really need the IBGP peering between R2 and R4? Let’s find out what happens when I remove it…
R2(config-router)#no neighbor 4.4.4.4
R4(config-router)#no neighbor 2.2.2.2
To visualize it, our picture now looks like this:
R2 R3 R4 partial mesh IBGP
Let’s check out the BGP table of R3 to see what it has:
R3#show ip bgp
BGP table version is 3, local router ID is 3.3.3.3
*>i192.168.45.0     4.4.4.4                  0    100      0 3 i
R3 learned about 1.1.1.0 /24 from R2 and 192.168.45.0 /24 from R4. This is good. These are prefixes that we advertised before. Now look at R2:
R2#show ip bgp
BGP table version is 4, local router ID is 2.2.2.2
R2 only knows about 1.1.1.0 /24, it didn’t learn about 192.168.45.0 /24 from R3. What about R4?
R4#show ip bgp
BGP table version is 5, local router ID is 4.4.4.4
r> 192.168.45.0     192.168.45.5             0             0 3 i
R4 only learned about 192.168.45.0 /24 from R5, we don’t see 1.1.1.0 /24 here.
The problem is that IBGP does not advertise prefixes from one IBGP neighbor to another IBGP neighbor. This is called BGP split horizon.
There is a good reason why IBGP works like this…
Between different ASes, BGP uses the AS_PATH attribute to avoid routing loops. A prefix will not be accepted by a BGP router if it sees its own AS number in it…plain and simple. However, within the autonomous system, the AS number does not change, so we can’t use this loop prevention mechanism.
Without BGP split horizon, a route could be advertised like this:
Unlock This Lesson for Free - No Credit Card Needed!
  • Get Instant Access to this Full Lesson, Completely for Free!
  • Unlock More to Read. More Lessons Added Every Week!
2298 Sign Ups in the last 30 days
  1. Could not understand this…
    “loop prevention van BGP is “als AS hetzelfde is dan hebben we een loop maar dit kan niet met ibgp want AS is altijd hetzelfde.”. dus wat doen we dan….IBGP -> IBGP -> IBGP niet doorsturen.”
  2. You caught one of my notes in Dutch… Just removed it :slight_smile:
  3. Hi Rene,
    Ur explanation was good..plz also describes about BGP Route Reflectors and Confederations.
  4. Thanx . you explained it step by step and it was very informative..
  5. your explanation is great and every clear… thanks a lot…
284 more replies! Ask a question or join the discussion by visiting our Community Forum
