In large networks, you may encounter network designs where the network is under a single administrative authority but divided into multiple ASes, each with its own IGP.
Why do we see networks designed like this? There are several reasons:
- The IGP doesn’t scale for a network of this size.
- One company bought another company, and they haven’t merged their ASes (yet).
- Each business division has a separate network.
- You require a specific routing policy that you can’t do with an IGP.
- You use BGP confederations.
- You use seamless MPLS.
A network with multiple IGPs and BGP in between instead of a single IGP introduces a potential problem. BGP selects a path using the best path selection algorithm, which isn’t based on a “lowest metric” as IGPs do. What happens is that your router will sometimes select sub-optimal paths in your network.
The routers above don’t have any inside metric information about the other ASes. AS 1 can’t know that somewhere inside AS 3, there are slow and fast links.
The solution to this problem is to use a BGP attribute named Accumulated IGP Metric Attribute (AIGP).
AIGP is a non-transitive attribute that includes the accumulated IGP metric. BGP routers advertise this AIGP metric to neighbors in other ASes. This allows BGP routers to select the best path based on the end-to-end IGP metric.
To make this possible, AIGP makes some changes to the BGP best-path algorithm.
Once you enable AIGP, BGP will check the AIGP metric right after step 3 (originate). This means we use the AIGP metric as a tie-breaker before other important attributes like the AS path length or MED.
In this lesson, I’ll show you a “before” and “after” scenario. In the “before” scenario, we look at a network that doesn’t use AIGP and which selects a sub-optimal path. You will also see how other solutions like configuring the MED won’t solve our problem. This example will help to understand why we need AIGP. In the “after” scenario, we’ll configure AIGP, and you’ll see how AIGP solves our sub-optimal routing problem.
Let’s get started!
R1
hostname R1
ip cef
ip ospf cost 10
interface GigabitEthernet0/0
ip ospf cost 10
interface GigabitEthernet0/1
ip ospf cost 30
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
router bgp 123
network 1.1.1.1 mask 255.255.255.255
neighbor 2.2.2.2 remote-as 123
neighbor 2.2.2.2 update-source Loopback0
neighbor 3.3.3.3 remote-as 123
neighbor 3.3.3.3 update-source Loopback0
R2
hostname R2
ip cef
ip ospf cost 10
ip ospf cost 10
router ospf 1
router bgp 123
neighbor 1.1.1.1 remote-as 123
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 next-hop-self
neighbor 3.3.3.3 next-hop-self
neighbor 192.168.24.4 remote-as 456
R3
hostname R3
ip cef
ip ospf cost 10
ip ospf cost 30
ip address 192.168.35.3 255.255.255.0
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
router bgp 123
neighbor 2.2.2.2 next-hop-self
neighbor 192.168.35.5 remote-as 456
R4
hostname R4
ip cef
ip ospf cost 10
ip address 192.168.46.4 255.255.255.0
ip ospf cost 20
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
network 192.168.46.0 0.0.0.255 area 0
router bgp 456
neighbor 5.5.5.5 remote-as 456
neighbor 5.5.5.5 update-source Loopback0
neighbor 5.5.5.5 next-hop-self
neighbor 6.6.6.6 remote-as 456
neighbor 6.6.6.6 update-source Loopback0
neighbor 6.6.6.6 next-hop-self
neighbor 192.168.24.2 remote-as 123
R5
hostname R5
ip cef
ip ospf cost 10
ip address 192.168.56.5 255.255.255.0
ip ospf cost 10
ip address 192.168.35.5 255.255.255.0
router ospf 1
network 5.5.5.5 0.0.0.0 area 0
network 192.168.56.0 0.0.0.255 area 0
router bgp 456
neighbor 4.4.4.4 remote-as 456
neighbor 4.4.4.4 next-hop-self
neighbor 192.168.35.3 remote-as 123
R6
hostname R6
ip cef
ip ospf cost 10
ip address 192.168.46.6 255.255.255.0
ip ospf cost 20
ip address 192.168.56.6 255.255.255.0
ip ospf cost 10
router ospf 1
network 6.6.6.6 0.0.0.0 area 0
router bgp 456
network 6.6.6.6 mask 255.255.255.255
We have two ASes. Within each AS, we run OSPF. I changed the cost metric on some of the interfaces. Let’s see how this network behaves when we send traffic between 1.1.1.1 and 6.6.6.6.
I configured these examples on IOSv Software (VIOS-ADVENTERPRISE-M), Version 15.9(3)M2.
Default BGP
We’ll start with a “default” BGP scenario where we don’t have any route-maps to steer traffic in another direction.
From AS 123 to AS 456
Let’s see how R1 wants to reach 6.6.6.6:
R1#show ip bgp 6.6.6.6
BGP routing table entry for 6.6.6.6/32, version 3
Flag: 0x100
Not advertised to any peer
Refresh Epoch 1
456
3.3.3.3 (metric 40) from 3.3.3.3 (3.3.3.3)
Origin IGP, metric 0, localpref 100, valid, internal
rx pathid: 0, tx pathid: 0
Refresh Epoch 1
456
2.2.2.2 (metric 20) from 2.2.2.2 (2.2.2.2)
Origin IGP, metric 0, localpref 100, valid, internal, best
rx pathid: 0, tx pathid: 0x0
R1 uses R2 as the next hop because it has the lowest IGP metric to the BGP next hop. Traffic enters AS 456 through R4. Let’s check the IGP metric to 6.6.6.6 on R4 and R5:
R4#show ip route 6.6.6.6 | include metric
Known via "ospf 1", distance 110, metric 30, type intra area
Route metric is 30, traffic share count is 1
R5#show ip route 6.6.6.6 | include metric
Known via "ospf 1", distance 110, metric 20, type intra area
Route metric is 20, traffic share count is 1
Looking from AS 456’s perspective, R5 has the lowest IGP metric to get to 6.6.6.6. However, when we look at the total metric picture, using R4 is the best option:
- The path through R2 = 10 + 20 + 10 = 40
- The path through R3 = 30 + 10 + 10 = 50
So, traffic from R1 to R6 takes the best path, excellent.
From AS 456 to AS 123
What about the other way around? From R6 to R1. Let’s check the BGP table on R6:
R6#show ip bgp 1.1.1.1
BGP routing table entry for 1.1.1.1/32, version 4
Paths: (2 available, best #1, table default)
Flag: 0x100
Refresh Epoch 1
123
5.5.5.5 (metric 20) from 5.5.5.5 (5.5.5.5)
Refresh Epoch 1
123
4.4.4.4 (metric 30) from 4.4.4.4 (4.4.4.4)
R6 picks R5 because it has the lowest IGP metric to the next hop. Is that a good thing? Well, we know it’s not because we just figured out that the best path is through R4 and R2.
Let’s check it from AS 123’s perspective:
R2#show ip route 1.1.1.1 | include metric
R3#show ip route 1.1.1.1 | include metric
Known via "ospf 1", distance 110, metric 40, type intra area
Route metric is 40, traffic share count is 1
When we enter AS 123 through R3, we have to use the “slow” link with a higher metric. The total metric of our paths looks like this:
- The path through R4 = 20 + 10 + 10 = 40
- The path through R5 = 10 + 30 + 10 = 50
The path through R4 would be the better option, but AS 456 can’t know this because it doesn’t know what AS 123 looks like.
BGP MED
You might think, why don’t we use BGP MED or perhaps AS path prepending? That allows us to tell the AS on the other side how we like to receive traffic?
Let me show you what happens when we use MED. This helps to understand why we need AIGP.
MED Configuration
We’ll configure route-maps so that R2, R3, R4, and R5 set the MED based on their IGP metric to reach the loopback interface in their AS.
AS 123
Let’s start with R2:
R2(config)#ip access-list standard R1_L0
R2(config-std-nacl)#permit host 1.1.1.1
R2(config)#route-map R1_L0_METRIC
R2(config-route-map)#match ip address R1_L0
R2(config-route-map)#set metric 20
R2(config)#router bgp 123
R2(config-router)#neighbor 192.168.24.4 route-map R1_L0_METRIC out
Here is R3:
R3(config)#ip access-list standard R1_L0
R3(config-std-nacl)#permit host 1.1.1.1
R3(config)#route-map R1_L0_METRIC
R3(config-route-map)#match ip address R1_L0
R3(config-route-map)#set metric 40
R3(config-route-map)#router bgp 123
R3(config-router)#neighbor 192.168.35.5 route-map R1_L0_METRIC out
That’s all we need to configure in AS 123.
AS 456
Let’s configure R4:
R4(config)#ip access-list standard R6_L0
R4(config-std-nacl)#permit host 6.6.6.6
R4(config)#route-map R6_L0_METRIC
R4(config-route-map)#match ip address R6_L0
R4(config-route-map)#set metric 30
R4(config)#router bgp 456
R4(config-router)#neighbor 192.168.24.2 route-map R6_L0_METRIC out
And R5:
R5(config)#ip access-list standard R6_L0
R5(config-std-nacl)#permit host 6.6.6.6
R5(config)#route-map R6_L0_METRIC
R5(config-route-map)#match ip address R6_L0
R5(config-route-map)#set metric 20
R5(config)#router bgp 456
R5(config-router)#neighbor 192.168.35.3 route-map R6_L0_METRIC out
That’s all we need to configure for MED.
Once again, let’s find out how traffic from R1 reaches R6. We’ll check R1:
Flag: 0x100
Refresh Epoch 1
456
Origin IGP, metric 20, localpref 100, valid, internal, best
R1 has only one path now. That’s because R2 prefers the path through R3 over its own eBGP path:
R2#show ip bgp 6.6.6.6
Refresh Epoch 1
456
192.168.24.4 from 192.168.24.4 (4.4.4.4)
Origin IGP, metric 30, localpref 100, valid, external
Refresh Epoch 1
456
3.3.3.3 (metric 50) from 3.3.3.3 (3.3.3.3)
R3#show ip bgp 6.6.6.6
Advertised to update-groups:
14
Refresh Epoch 1
456
192.168.35.5 from 192.168.35.5 (5.5.5.5)
Origin IGP, metric 20, localpref 100, valid, external, best
BGP prefers the path with the lowest MED.
That’s not good. AS 123 now uses R3 to reach AS 456 and we know this is not the path with the lowest total metric.
Let’s check the other way around. What about traffic from R6 to R1?
Here’s R6:
BGP routing table entry for 1.1.1.1/32, version 2
Refresh Epoch 1
123
R6 only sees R4 as a possible path. This is because R5 prefers to use R4 over its eBGP path:
R5#show ip bgp 1.1.1.1
Refresh Epoch 1
123
4.4.4.4 (metric 40) from 4.4.4.4 (4.4.4.4)
Refresh Epoch 1
123
192.168.35.3 from 192.168.35.3 (3.3.3.3)
Origin IGP, metric 40, localpref 100, valid, external
R4#show ip bgp 1.1.1.1
11
Refresh Epoch 1
123
192.168.24.2 from 192.168.24.2 (2.2.2.2)
AS 456 is now using the most optimal path. However, AS 123 isn’t.
R1
hostname R1
ip cef
ip ospf cost 10
ip ospf cost 10
ip ospf cost 30
router ospf 1
router bgp 123
R2
hostname R2
ip cef
ip ospf cost 10
ip ospf cost 10
router ospf 1
router bgp 123
permit 1.1.1.1
route-map R1_L0_METRIC permit 10
set metric 20
R3
hostname R3
ip cef
ip ospf cost 10
ip ospf cost 30
router ospf 1
router bgp 123
permit 1.1.1.1
set metric 40
R4
hostname R4
ip cef
ip ospf cost 10
ip ospf cost 20
router ospf 1
router bgp 456
permit 6.6.6.6
route-map R6_L0_METRIC permit 10
set metric 30
R5
hostname R5
ip cef
ip ospf cost 10
ip ospf cost 10
router ospf 1
router bgp 456
permit 6.6.6.6
set metric 20
R6
hostname R6
ip cef
ip ospf cost 10
ip ospf cost 20
ip ospf cost 10
router ospf 1
router bgp 456
AIGP
It’s time for AIGP and to finally configure what you came for. Let’s make sure both AS 123 and AS 456 will use the most optimal path.
I’m glad to be the first to say, GREAT LESSON man :+1:
Thanks @joseph!
AIGP is easy to configure but it does take time to explain what the issue is with “regular” BGP in a scenario with multiple IGPs, and how things like MED/AS Path won’t fix it.
One thing Rene, I noticed in the config on R1 at the end of the lesson, there are two route-maps.
https://cdn-forum.networklesso...a5565194265ec59c7
I think the highlighted one needs to be removed.
Hello Joseph
Yes, I think you are correct! I’ll let Rene know.
First of all, thank you very much for sharing this post.
However in section 1.2.1.2, R4 keeping MED 30 and R5 keeping MED 40 they why would AS123 prefers path via R3-R5 ??
Please correct me if I misunderstood anything.
