Resource Public Key Infrastructure (RPKI) is used to validate whether certain prefixes belong to the AS that advertises them. Before you continue with this lesson, make sure you have a good understanding of what BGP route leaking is and how RPKI can help.
In this lesson, we’ll configure an RPKI validator using Docker and make a Cisco IOS XE router validate prefixes. We’ll see how the router deals with valid, invalid, and not found prefixes. You’ll also learn how to forward this RPKI state to other routers.
Let’s start with our topology:
Let me explain what we have:
- Routinator is open-source RPKI relying party software (RPKI validator) which downloads and verifies RPKI data.
- R1 and R2 are in AS 12 and will use RPKI to validate routes.
- R4 and R5 advertise prefixes to R1 through eBGP.
- R3 is only needed so I can reach Routinator from R1.
I use CSR1000v routers running Cisco IOS Software [Amsterdam], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.6.
Want to take a look for yourself? Here, you will find the startup configuration of each device.
R1
hostname R1
interface GigabitEthernet1
interface GigabitEthernet2
router bgp 12
neighbor 192.168.1.4 remote-as 8075
neighbor 192.168.1.5 remote-as 29256
neighbor 192.168.12.2 remote-as 12
neighbor 192.168.12.2 next-hop-self
neighbor 192.168.12.2 send-community extended
neighbor 192.168.12.2 announce rpki state
ip route 10.65.90.0 255.255.255.0 192.168.1.3
R2
hostname R2
router bgp 12
neighbor 192.168.12.1 remote-as 12
R4
hostname R4
ip address 4.128.0.4 255.240.0.0
interface Loopback1
ip address 5.0.0.5 255.255.224.0
interface Loopback2
ip address 44.44.44.44 255.255.255.255
ip address 192.168.1.4 255.255.255.0
router bgp 8075
network 4.128.0.0 mask 255.240.0.0
network 5.0.0.0 mask 255.255.224.0
network 44.44.44.44 mask 255.255.255.255
neighbor 192.168.1.1 remote-as 12
R5
hostname R5
ip address 192.168.1.5 255.255.255.0
router bgp 29256
neighbor 192.168.1.1 route-map AS_PATH_PREPEND out
route-map AS_PATH_PREPEND permit 10
set as-path prepend 29256 29256
docker-compose.yml
version: '3'
services:
routinator:
image: nlnetlabs/routinator
container_name: routinator
restart: unless-stopped
ports:
- "3323:3323"
- "8323:8323"
Routinator
My docker container with Routinator is up and running.
The GUI listens on HTTP TCP port 8323. Let’s have a look. Under Prefix Check, you can enter a prefix and AS number to see whether it’s valid, invalid, or not found:
This prefix checks out. Under Metrics, you can see how many Route Origin Authorizations (ROA) there are per Regional Internet Registry (RIR) and how many Validated ROA Payloads (VRPs) Routinator made from them. A VRP is one prefix, maximum length and origin AS combination from a valid ROA:
Under Repositories, you can see all the RPKI repositories from the different RIRs:
Under Connections, you see how Routinator communicates with the repositories. This can be RPKI Repository Delta Protocol (RRDP) or Rsync:
Our Routinator docker instance is working well. There’s nothing we have to configure here.
Router
Let’s configure our router. Before I enable route validation, I’ll add this command on R1:
R1(config)#router bgp 12
R1(config-router)#bgp bestpath prefix-validate disable
This will ensure that once I connect to Routinator, R1 will download the RPKI data, but it won’t validate prefixes, so it won’t change the BGP table yet.
Next, I’ll connect to Routinator:
R1(config-router)#bgp rpki server tcp 10.65.90.50 port 3323 refresh 300
Routinator uses TCP port 3323 for the RPKI-to-Router protocol (RTR).
Once connected, the router will now download a list of prefixes and the ASes they belong to. The server will send incremental updates, but the router can query the server for a refresh as well. I set the refresh time to 300 seconds, but on a production network, once every hour is probably more than enough.
Let’s check if R1 is connected to Routinator:
R1#show ip bgp rpki servers
BGP SOVC neighbor is 10.65.90.50/3323 connected to port 3323
Flags 64, Refresh time is 300, Serial number is 135, Session ID is 11494
InQ has 0 messages, OutQ has 0 messages, formatted msg 2
Session IO flags 3, Session flags 4008
Neighbor Statistics:
Prefixes 500539
Connection attempts: 20
Connection failures: 18
Errors sent: 0
Errors received: 0
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 255
Local host: 192.168.1.1, Local port: 53929
Foreign host: 10.65.90.50, Foreign port: 3323
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x3F80132):
Timer Starts Wakeups Next
Retrans 4 1 0x0
TimeWait 0 0 0x0
AckHold 7068 4 0x0
SendWnd 0 0 0x0
KeepAlive 8171 0 0x3F80628
GiveUp 0 0 0x0
PmtuAger 1 0 0x3FAACF2
DeadWait 0 0 0x0
Linger 0 0 0x0
ProcessQ 0 0 0x0
iss: 341721583 snduna: 341721604 sndnxt: 341721604
irs: 2065660931 rcvnxt: 2076787572
sndwnd: 64220 scale: 0 maxrcvwnd: 16384
rcvwnd: 15652 scale: 0 delrcvwnd: 732
SRTT: 234 ms, RTTO: 2984 ms, RTV: 2750 ms, KRTT: 0 ms
minRTT: 1 ms, maxRTT: 1000 ms, ACK hold: 200 ms
uptime: 427282 ms, Sent idletime: 14052 ms, Receive idletime: 14050 ms
Status Flags: active open
Option Flags: keepalive running, nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 8151 (out of order: 0), with data: 8124, total data bytes: 11126640
Sent: 8215 (retransmit: 1, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 2, total data bytes: 20
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
TCP Semaphore 0x7F272B14F018 FREE
We are connected. The number of prefixes (500539) is something to keep an eye on. It can take a few minutes for the router to download everything. We can see a list of all prefixes and AS numbers using this command:
R1#show ip bgp rpki table
367569 BGP sovc network entries using 58811040 bytes of memory
407525 BGP sovc record entries using 13040800 bytes of memory
Network Maxlen Origin-AS Source Neighbor
1.0.0.0/24 24 13335 0 10.65.90.50/3323
1.0.4.0/24 24 38803 0 10.65.90.50/3323
1.0.4.0/22 22 38803 0 10.65.90.50/3323
1.0.5.0/24 24 38803 0 10.65.90.50/3323
1.0.6.0/24 24 38803 0 10.65.90.50/3323
1.0.7.0/24 24 38803 0 10.65.90.50/3323
1.0.64.0/18 18 18144 0 10.65.90.50/3323
1.1.1.0/24 24 13335 0 10.65.90.50/3323
1.1.4.0/22 22 4134 0 10.65.90.50/3323
1.1.16.0/20 20 4134 0 10.65.90.50/3323
1.2.9.0/24 24 4134 0 10.65.90.50/3323
1.2.10.0/24 24 4134 0 10.65.90.50/3323
1.2.11.0/24 24 4134 0 10.65.90.50/3323
1.2.12.0/22 22 4134 0 10.65.90.50/3323
1.3.0.0/16 16 4134 0 10.65.90.50/3323
1.6.0.0/22 24 9583 0 10.65.90.50/3323
This is looking good. Let’s find out how R1 uses this information by checking the BGP table:
R1#show ip bgp
BGP table version is 10, local router ID is 192.168.12.1
t secondary path, L long-lived-stale,
*> 4.128.0.0/12 192.168.1.4 0 0 8075 i
*> 5.0.0.0/19 192.168.1.4 0 0 8075 i
* 192.168.1.5 0 0 29256 29256 29256 i
*> 44.44.44.44/32 192.168.1.4 0 0 8075 i
Three prefixes have been selected as the best path. Take a closer look at 5.0.0.0/19. I advertise this prefix from R4 and R5, but I used AS path prepending on R5 so that R4 becomes the best path.
This is what the routing table looks like:
R1#show ip route bgp
4.0.0.0/12 is subnetted, 1 subnets
B 4.128.0.0 [20/0] via 192.168.1.4, 00:07:29
5.0.0.0/19 is subnetted, 1 subnets
B 5.0.0.0 [20/0] via 192.168.1.4, 00:03:03
44.0.0.0/32 is subnetted, 1 subnets
B 44.44.44.44 [20/0] via 192.168.1.4, 00:14:35
Nothing new here. This is because of the bgp bestpath prefix-validate disable command we added earlier. Let’s get rid of it so you can see the difference:
R1(config-router)#no bgp bestpath prefix-validate disable
This changes the BGP table:
R1#show ip bgp
BGP table version is 11, local router ID is 192.168.12.1
V*> 4.128.0.0/12 192.168.1.4 0 0 8075 i
I* 5.0.0.0/19 192.168.1.4 0 0 8075 i
V*> 192.168.1.5 0 0 29256 29256 29256 i
N*> 44.44.44.44/32 192.168.1.4 0 0 8075 i
This time, we see something different:
- 4.128.0.0/12 from AS 8075 is a valid prefix.
- 5.0.0.0/19 from AS 8075 is an invalid prefix.
- 5.0.0.0/19 from AS 29256 is a valid prefix.
- 44.44.44.44/32 from AS 8075 is a prefix that is not found.
This influences the BGP best path selection. R1 selects the longer path through R5 as the best path to get to 5.0.0.0/19. Here’s the routing table:
B 4.128.0.0 [20/0] via 192.168.1.4, 00:08:50
B 5.0.0.0 [20/0] via 192.168.1.5, 00:00:32
B 44.44.44.44 [20/0] via 192.168.1.4, 00:15:56
Let’s check all prefixes in the RPKI table. Here’s the first one:
R1#show ip bgp 4.128.0.0/12 | include RPKI
path 7F2732260020 RPKI State valid
The 4.128.0.0/12 from AS 8075 is a valid prefix. We have two entries for 5.0.0.0/19:
R1#show ip bgp 5.0.0.0/19
BGP routing table entry for 5.0.0.0/19, version 11
Advertised to update-groups:
5 6
Refresh Epoch 1
8075
192.168.1.4 from 192.168.1.4 (44.44.44.44)
Origin IGP, metric 0, localpref 100, valid, external
path 7F27322601D0 RPKI State invalid
rx pathid: 0, tx pathid: 0
Updated on Jan 16 2024 10:08:41 UTC
Refresh Epoch 1
29256 29256 29256
192.168.1.5 from 192.168.1.5 (5.0.0.5)
Origin IGP, metric 0, localpref 100, valid, external, best
path 7F2732260140 RPKI State valid
rx pathid: 0, tx pathid: 0x0
Updated on Jan 16 2024 10:08:40 UTC
Above, you can see that prefix 5.0.0.0/19 from AS 8075 is invalid and the one from AS 29256 is valid.
Let’s check the last prefix:
R1#show ip bgp 44.44.44.44/32 | include RPKI
path 7F27322600B0 RPKI State not found
This prefix is not found because there is no ROA for it.
Invalid Prefixes
Let’s take a closer look at that invalid prefix. By default, a router refuses to use invalid prefixes. We can test this by shutting down R5 for now:
R5(config)#interface GigabitEthernet 1
R5(config-if)#shutdown
R1 now only has the invalid prefix 5.0.0.0/19 from AS 8075:
BGP routing table entry for 5.0.0.0/19, version 0
Paths: (1 available, no best path)
Flag: 0x4100
Not advertised to any peer
Refresh Epoch 2
8075
path 7F2732260140 RPKI State invalid
Updated on Jan 16 2024 10:47:03 UTC
R1 refuses to use this prefix:
R1#show ip route 5.0.0.0
% Network not in table
However, it is possible to tell R1 that you do want to use invalid prefixes. Here’s how:
R1(config-router)#bgp bestpath prefix-validate allow-invalid
Because it’s the only option, R1 now uses this as the best path:
BGP routing table entry for 5.0.0.0/19, version 4
10
Refresh Epoch 2
8075
And installs it in the routing table:
Routing entry for 5.0.0.0/19, 1 known subnets
B 5.0.0.0 [20/0] via 192.168.1.4, 00:00:33
Let’s enable R5 again:
R5(config-if)#no shutdown
Route-map
We can also use a route-map to match the different RPKI states and change one of the BGP attributes. For example, local preference. Here’s how to do it:
R1(config)#route-map RPKI permit 10
R1(config-route-map)#match rpki valid
R1(config-route-map)#set local-preference 200
R1(config)#route-map RPKI permit 20
R1(config-route-map)#match rpki not-found
R1(config-route-map)#set local-preference 100
R1(config)#route-map RPKI permit 30
R1(config-route-map)#match rpki invalid
R1(config-route-map)#set local-preference 50
R1(config)#route-map RPKI permit 40
We’ll give valid prefixes the highest local preference (200), not found the second best (100), and invalid prefixes the worst (50). Don’t forget to add an empty statement or your router will deny everything else. Let’s attach this route-map to R4 and R5:
R1(config-router)#neighbor 192.168.1.4 route-map RPKI in
R1(config-router)#neighbor 192.168.1.5 route-map RPKI in
Let’s speed things up and reset the BGP neighbor adjacencies:
Hello Dears,
Usually when it comes to RPKI, we just check the online tools such as Routinator as you mentioned to check if the route is valid or not,
Now could you please explain why we need to configure it up in the routers? does it going to help and not advertise those routes when is not valid or not found to the peer routers?
also this shouldn’t be router bgp 12 or it is okay ?
https://forum.networklessons.c...8e8ae817eeb228047
And please why prefix 44.44.44.44/32 is not found route?
Hello Ahmedlmad
ahmedamrici:
The validity of routes is something that is dynamic, and it can change. Checking the validity of routes on an online tool without any additional action is useful, but information can become out of date. For this reason, by configuring the routers to dynamically check upon the validity of the routes allows for them to get real-time updates to
... Continue reading in our forumHi,
Shouldn’t port 8323 be opened between the router and the Routinator instead of 3323?
Best regards,
Sepideh
Hello Sepideh
Port 3323 is the port used by the RPKI-to-Router protocol (RTR). This is the protocol used to allow BGP routers to communicate with the Routinator server. So for communication between the BGP routers and Routinator, 3323 is the correct TCP port.
The 8323 port is used to connect to the GUI of the Routinator. So from your PC, on a web browser you would include the port number to be used. For example, in this lesson, Rene used: docker1.nwl.ai:8323.
These port numbers are reaffirmed at this related Routinator documentation:
