OSPF DR/BDR Election explained
OSPF uses a DR (Designated Router) and BDR (Backup Designated Router) on each multi-access network to reduce routing update traffic and LSA flooding. If you have multiple routers on a multi-access segment, and all those routers would form neighbor adjacencies with each other, you would have a lot of unnecessary LSA flooding. The DR acts as a central point for the distribution of LSAs.
This election happens per multi-access segment, not per area. A multi-access network is a network segment with more than two routers where routers can reach each other directly. OSPF figures out whether a network is multi-access or not by looking at the interface type. For example, an Ethernet interface is considered multi-access, and a serial interface with PPP encapsulation is considered a point-to-point interface. OSPF automatically sets the correct OSPF network type for each interface.
Key Takeaways
  • DR/BDR election occurs per multi-access segment, not per OSPF area
  • Default OSPF priority is 1. The higher priority wins the election
  • Setting priority to 0 prevents a router from becoming DR or BDR
  • Election requires clear ip ospf process command to take effect after priority changes
  • Point-to-point links (like serial interfaces) don’t use DR/BDR
  • Routers that are neither DR nor BDR are called DROTHER
Let’s look at this in action.
Multi-Access Network
We’ll start with an example of a multi-access network with a DR/BDR election. This is the topology we’ll use:
ospf 3 routers multi access
Here’s an example of a network with 3 OSPF routers on a FastEthernet network. They are connected to the same switch (multi-access network) so there will be a DR/BDR election. OSPF has been configured, so all routers have become OSPF neighbors. Let’s take a look:
R1#show ip ospf neighbor
Neighbor ID     Pri   State       Dead Time   Address       Interface
192.168.123.2   1   FULL/BDR      00:00:32    192.168.123.2 FastEthernet0/0
192.168.123.3   1   FULL/DR       00:00:31    192.168.123.3 FastEthernet0/0
From R1’s perspective, R2 is the BDR, and R3 is the DR.
R3#show ip ospf neighbor
192.168.123.1   1   FULL/DROTHER  00:00:36    192.168.123.1 FastEthernet0/0
192.168.123.2   1   FULL/BDR      00:00:39    192.168.123.2 FastEthernet0/0
When a router is not the DR or BDR, it’s called a DROTHER. Here we can see that R1 is a DROTHER.
R2#show ip ospf neighbor
192.168.123.1   1   FULL/DROTHER  00:00:31    192.168.123.1 FastEthernet0/0
192.168.123.3   1   FULL/DR       00:00:32    192.168.123.3 FastEthernet0/0
And R2 (the BDR) sees the DR and DROTHER.
Of course, we can change which router becomes the DR/BDR by playing with the priority. Let’s turn R1 in the DR:
R1(config-if)#ip ospf priority 200
You change the priority if you like by using the ip ospf priority command:
  • The default priority is 1.
  • A priority of 0 means you will never be elected as DR or BDR.
  • You need to use clear ip ospf process before this change takes effect.
192.168.123.2   1   FULL/BDR      00:00:31    192.168.123.2 FastEthernet0/0
As you can see, R3 is still the DR, we need to reset the OSPF neighbor adjacencies so that we’ll elect the new DR and BDR.
R3#clear ip ospf process
Reset ALL OSPF processes? [no]: yes
R2#clear ip ospf process
I’ll reset all the OPSF neighbor adjacencies.
192.168.123.2   1   FULL/DROTHER  00:00:36    192.168.123.2 FastEthernet0/0
192.168.123.3   1   FULL/BDR      00:00:30    192.168.123.3 FastEthernet0/0
Now you can see R1 is the DR because the other routers are DROTHER and BDR.
192.168.123.1   200  FULL/DR      00:00:30    192.168.123.1 FastEthernet0/0
192.168.123.2   1    FULL/DROTHER 00:00:31    192.168.123.2 FastEthernet0/0
Or we can confirm it from R3. You’ll see that R1 is the DR and that the priority is 200.
R1
hostname R1
ip cef
interface FastEthernet0/0
 ip address 192.168.123.1 255.255.255.0
router ospf 1
 network 192.168.123.0 0.0.0.255 area 0
R2
hostname R2
ip cef
 ip address 192.168.123.2 255.255.255.0
router ospf 1
R3
hostname R3
ip cef
 ip address 192.168.123.3 255.255.255.0
router ospf 1
Something you need to be aware of is that the DR/BDR election is per multi-access segment…not per area!). Let me give you an example:
Ospf R1 R2 R3 Two Broadcast Domains
In the example above, we have two multi-access segments between R2 and R1, and between R2 and R3. For each segment, there will be a DR/BDR election.
🔥 2343 people registered in the last 30 days
Tags: ,
  1. Really helpful series of posts on OSPF. Thank you!
  2. Thanks for this lesson, very helpful! :slight_smile:
  3. Wonderful explanation!! The best I’ve found on the web. CCNA books are not so clear!
  4. Thanks Davide, glad to hear you like it!
  5. simply awesome!!! Thanks a lot..
168 more replies! Ask a question or join the discussion by visiting our Community Forum
