APIC-EM Path Trace ACL Analysis Tool
In a previous lesson, I explained how to install APIC-EM and some of its basics. In this lesson, we’ll take a look at the path trace ACL analysis tool which is one of the topics on the blueprint of CCNA R&S.
I will use the following physical topology for this example:
apic em physical lab topology
I used this to build the following logical topology:
apic em logical topology lab
The routers above are running OSPF.  Let’s see if we can trace some traffic.
R1
hostname R1
enable password Cisco123
ip domain name NETWORKLESSONS.LOCAL
username admin password 0 Cisco123
interface FastEthernet0/0
interface FastEthernet0/1
router ospf 1
snmp-server community readonly RO
snmp-server community readwrite RW
line vty 5 9
 login local
 transport input ssh
R2
hostname R2
router ospf 1
ip access-list extended NO_SSH
 deny   tcp host 192.168.12.1 any eq 22
 permit ip any any
line vty 5 9
 login local
 transport input ssh
R3
hostname R3
router ospf 1
 network 3.3.3.3 0.0.0.0 area 0
ip http server
line vty 5 9
 login local
 transport input ssh
SW1
hostname SW1
ip domain-name NETWORKLESSONS.LOCAL
 switchport access vlan 12
 switchport mode access
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
 switchport access vlan 13
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/24
 switchport mode trunk
 ip access-group R1_R3_HTTP in
interface Vlan12
 ip address 192.168.12.100 255.255.255.0
ip default-gateway 192.168.12.1
ip classless
ip access-list extended R1_R3_HTTP
 deny   tcp host 192.168.13.1 host 3.3.3.3 eq www
 permit ip any any
line vty 5 9
 login local
 transport input ssh
line vty 10 15
 login
SW2
hostname SW2
 switchport access vlan 23
interface FastEthernet0/10
interface Vlan12
 ip address 192.168.12.101 255.255.255.0
line vty 5 9
 login local
 transport input ssh
line vty 10 15
 login
In the menu on the left side, select Path Trace:
apic em menu path trace
Select “Start new Path Trace”:
apic em start new path trace
Now we can enter a source and destination. Let’s select R1 as the source:
apic em menu path trace source router
Once you select the device, you can select one of its interfaces. Let’s pick FastEthernet 0/1:
apic em r1 interface fastethernet two
For the destination, we will use R3 and its loopback interface. We will select options and choose TCP as our protocol with destination port 80. For the source port, I’ll pick 50001. Make sure you select ACL trace:
apic em start new path trace acl option
Click on Start Trace and APIC-EM will do its magic. You will see the following screen:
  1. This is really Beautiful Tool.
    Thanks Rene!
  2. This is really sweet and informative, since I deal with ACLs consistently at work. Thanks again for the great work.
