Cisco’s Medianet Performance Monitor is an extension of Flexible NetFlow (FNF). Besides the regular NetFlow information like source and/or destination IP addresses or port numbers it can collect a wide range of metrics including:
- Jitter
- Packet loss
- Transport Event Packet Loss
- Round Trip Time
When you configure Performance Monitor, we need the following items:
- Flow record – type performance monitor: this is where we configure the metrics that we want to collect.
- Flow exporter: this is where we configure the server that we want to export our metrics to.
- Flow monitor – type performance monitor: this is where we link the flow record and flow exporter together.
- Class-map: we use a class map to define what traffic we want to monitor.
- Policy-map – type performance monitor: this is where we add all of our class maps.
- Interface: the policy-map is added to the interface. You can choose between inbound, outbound, or both directions.
Here is a visual representation of how everything is linked together:
There are two ways to configure Performance Monitor:
- Manual: we configure all the items I explained above ourselves.
- Easy Performance Monitor (ezPM): this is a simplified configuration that only requires a few commands. It includes Cisco validated records, monitors, class-maps, policy-maps, etc.
I’ll start with the manual method so you can see all the different items one-by-one. In a production network, it’s probably best to stick to the ezPM method or you will probably spend days figuring out the correct settings.
- H1 will generate some traffic with IP SLA.
- R1 will export Performance Monitor metrics to S1.
Manual
Flow Record
Let’s create two flow records:
- TCP traffic
- RTP traffic
For each traffic type, we need a flow record. I’ll add a bunch of different metrics in each flow record. Let’s start with the TCP flow record:
R1(config)#flow record type performance-monitor FLOW_RECORD_TCP
R1(config-flow-record)#match ipv4 protocol
R1(config-flow-record)#match ipv4 source address
R1(config-flow-record)#match ipv4 source prefix
R1(config-flow-record)#match ipv4 destination address
R1(config-flow-record)#match ipv4 destination prefix
R1(config-flow-record)#match transport source-port
R1(config-flow-record)#match transport destination-port
R1(config-flow-record)#collect routing forwarding-status
R1(config-flow-record)#collect ipv4 dscp
R1(config-flow-record)#collect ipv4 ttl
R1(config-flow-record)#collect ipv4 source mask
R1(config-flow-record)#collect ipv4 destination mask
R1(config-flow-record)#collect transport round-trip-time
R1(config-flow-record)#collect transport event packet-loss counter
R1(config-flow-record)#collect interface input
R1(config-flow-record)#collect interface output
R1(config-flow-record)#collect counter bytes
R1(config-flow-record)#collect counter packets
R1(config-flow-record)#collect counter bytes rate
R1(config-flow-record)#collect timestamp interval
R1(config-flow-record)#collect application media bytes counter
R1(config-flow-record)#collect application media packets rate
R1(config-flow-record)#collect application media event
R1(config-flow-record)#collect monitor event
Let’s add another one for RTP:
R1(config)#flow record type performance-monitor FLOW_RECORD_RTP
R1(config-flow-record)#match transport rtp ssrc
R1(config-flow-record)#collect transport packets expected counter
R1(config-flow-record)#collect transport packets lost counter
R1(config-flow-record)#collect transport packets lost rate
R1(config-flow-record)#collect transport rtp jitter mean
R1(config-flow-record)#collect transport rtp jitter minimum
R1(config-flow-record)#collect transport rtp jitter maximum
R1(config-flow-record)#collect application media bytes rate
R1(config-flow-record)#collect application media packets counter
Above, you can see I added some metrics (for example jitter) that are useful for RTP traffic.
Flow Exporter
We want to export our metrics somewhere so we need to configure a flow exporter. I’ll export everything to a server at 192.168.2.200:
R1(config)#flow exporter NETFLOW_SERVER
R1(config-flow-exporter)#destination 192.168.2.200
R1(config-flow-exporter)#source GigabitEthernet 0/1
R1(config-flow-exporter)#transport udp 2055
R1(config-flow-exporter)#template data timeout 60
Flow Monitor
Now we can combine the flow records and flow exporter in a flow monitor. I’ll create two, one for TCP traffic and another one for RTP traffic:
R1(config)#flow monitor type performance-monitor FLOW_MONITOR_RTP
R1(config-flow-monitor)#record FLOW_RECORD_RTP
R1(config-flow-monitor)#exporter NETFLOW_SERVER
R1(config)#flow monitor type performance-monitor FLOW_MONITOR_TCP
R1(config-flow-monitor)#record FLOW_RECORD_TCP
R1(config-flow-monitor)#export NETFLOW_SERVER
Class-map
So far, we configured what metrics we want to collect but we still have to tell the router what traffic we want to collect. I’ll create two class-maps for this. Let’s create one that matches all TCP traffic:
R1(config)#ip access-list extended TCP_TRAFFIC
R1(config-ext-nacl)#permit tcp any any
R1(config)#class-map TCP
R1(config-cmap)#match access-group name TCP_TRAFFIC
For my RTP traffic, I’ll create a simple access-list that matches all UDP traffic. We could use NBAR to classify RTP traffic but I intend to use IP SLA to generate RTP traffic. NBAR doesn’t classify IP SLA traffic as RTP so I’ll go with a simple access-list. Let’s create it:
R1(config)#ip access-list extended UDP_TRAFFIC
R1(config-ext-nacl)#permit udp any any
R1(config)#class-map RTP
R1(config-cmap)#match access-group name UDP_TRAFFIC
Policy-map
Our class-maps are ready so we can create a new policy-map and add the class-maps to it:
R1(config)#policy-map type performance-monitor PERFORMANCE_MONITOR
R1(config-pmap)#class RTP
R1(config-pmap-c)#flow monitor FLOW_MONITOR_RTP
R1(config-pmap-c)#monitor parameters
R1(config-pmap-c-mparams)#interval duration 10
R1(config-pmap-c-mparams)#flows 100
R1(config-pmap)#class TCP
R1(config-pmap-c)#flow monitor FLOW_MONITOR_TCP
R1(config-pmap-c-mparams)#flows 1000
R1(config-pmap-c-mparams)#exit
R1(config-pmap-c)#exit
Optionally, you can set parameters for each flow. Above, you can see I set a limit to the number of flows for each class-map.
Interface
Last but not least, let’s activate the policy-map on an interface. I’ll apply it in- and outbound on the interface that connects to H1:
R1(config-if)#service-policy type performance-monitor input PERFORMANCE_MONITOR
R1(config-if)#service-policy type performance-monitor output PERFORMANCE_MONITOR
That completes our configuration.
H1
hostname H1
no ip routing
no ip cef
interface GigabitEthernet0/1
ip sla 1
udp-jitter 1.2.3.4 16384 num-packets 500 interval 4
threshold 0
timeout 0
frequency 1
R1
hostname R1
ip cef
match ipv4 protocol
collect ipv4 dscp
collect ipv4 ttl
match ipv4 protocol
collect ipv4 dscp
collect ipv4 ttl
source GigabitEthernet0/1
output-features
transport udp 2055
option exporter-stats
option application-table
cache entries 100
cache entries 1000
class-map match-all TCP
class-map match-all RTP
class TCP
class RTP
interface GigabitEthernet0/2
permit tcp any any
permit udp any any
The configuration above is pretty complex with so many pieces and parameters. ezPM is based on some best practice templates and you only need a few lines to configure it. You only need to configure a profile and traffic monitor. You can find information about those in the AVC user guide.
For the sake of completeness, let me show you the configuration commands:
R1(config)#performance monitor context EZPM profile ?
application-experience Application eXperience performance monitor profile
application-performance Application performance profile
application-statistics Application statistics profile
Let’s pick one of the profiles:
R1(config)#performance monitor context EZPM profile application-statistics
We need to configure an exporter:
R1(config-perf-mon)#exporter destination 192.168.2.200 source GigabitEthernet 0/1
And select a traffic monitor:
R1(config-perf-mon)#traffic-monitor ?
application-client-server-stats Per interface, client, server and application statistics
application-stats Per application and interface statistics
I’ll pick the application-stats traffic monitor:
R1(config-perf-mon)#traffic-monitor application-stats
The only thing left to do is to enable ezPM on our interface:
R1(config-if)#performance monitor context EZPM
That’s all. A few lines to configure everything. You can then use the show performance monitor context command and it will show you what it is using behind the scenes:
R1#show performance monitor context
| Operational Information of Context EZPM |
Coarse-grain NBAR based profile
Exporters
Flow Exporter EZPM-1:
Description: performance monitor context EZPM exporter
Export protocol: IPFIX (Version 10)
Transport Configuration:
Destination IP address: 10.56.100.253
Source IP address: 172.16.1.56
Source Interface: GigabitEthernet0/1
Transport Protocol: UDP
Destination Port: 4739
Source Port: 65234
DSCP: 0x0
TTL: 255
Output Features: Not Used
Options Configuration:
interface-table (timeout 300 seconds) (active)
vrf-table (timeout 300 seconds) (active)
sampler-table (timeout 300 seconds) (active)
application-table (timeout 300 seconds) (active)
application-attributes (timeout 300 seconds) (active)
Packet send statistics (last cleared 20:44:23 ago):
Successfully sent: 4233 (5557680 bytes)
Client send statistics:
Client: Option options interface-table
Records added: 996
- sent: 996
Bytes added: 99600
- sent: 99600
Client: Option options vrf-id-name-table
Records added: 0
Bytes added: 0
Client: Option options sampler-table
Records added: 0
Bytes added: 0
Client: Option options application-name
Records added: 23406
- sent: 23406
Bytes added: 1942698
- sent: 1942698
Client: Option options application-attributes
Records added: 16932
- sent: 16932
Bytes added: 3284808
- sent: 3284808
Client: MMA EXPORTER GROUP MMA-EXP-3
Records added: 0
Bytes added: 0
| Traffic Monitor: application-stats |
Class-maps
Class Map match-all EZPM-app_stats_ipv4 (id 3)
Match protocol ip
Class Map match-all EZPM-app_stats_ipv6 (id 4)
Match protocol ipv6
Records and Monitors
Users : 1
Key Fields:
Name: flow direction
Name: flow observation point
Name: application id (172 / 0xAC)
Non Key Fields:
Name: routing vrf input
Name: counter bytes long
Name: counter packets long
Name: timestamp sys-uptime first
Name: timestamp sys-uptime last
Name: connection new-connections
Name: connection sum-duration
Flow Monitor EZPM-app_stats:
Description: User defined
Flow Record: not configured
Cache:
Type: synchronized
Status: not allocated
Size: 10000 entries / 0 bytes
Synchronized Timeout: 60 secs
| Policy-maps |
Policy Map type performance-monitor EZPM-in
Parameter default account-on-resolution
Class EZPM-app_stats_ipv4
flow monitor EZPM-app_stats
react status: inactive
Class EZPM-app_stats_ipv6
Policy Map type performance-monitor EZPM-out
| Interface Attachments |
GigabitEthernet0/2
Service-policy performance-monitor input: EZPM-in
Class-map: EZPM-app_stats_ipv4 (match-all)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: protocol ip
Total Packets classified: 0
Total Bytes classified: 0
Monitor AOR: disabled
Class-map: EZPM-app_stats_ipv6 (match-all)
0 packets, 0 bytes
Match: protocol ipv6
0 packets, 0 bytes
Match: any
Service-policy performance-monitor output: EZPM-out
0 packets, 0 bytes
Match: protocol ip
0 packets, 0 bytes
0 packets, 0 bytes
Match: any
This is much easier to configure or you can use it as a template for your manual configuration.
Verification
Everything you see in this section is based on the “manual” configuration I started with.
I am try to see the difference between Performance monitor and netflow
and what is the best solution
Hello Fabrice
Cisco Performance Monitor is not a replacement or an alternative to Netflow. CPM is an extension to Flexible Netflow, which itself is an extension to Netflow v9. Which you will choose depends on what level of monitoring you desire.
CPM is ideal for monitoring metrics for real-time applications. Metrics such as Jitter, packet loss and round trip time are all vital for such applications. CPM would be very beneficial if you have such applications, however, if you don’t, Netflow may be sufficient for your needs. You will have to evaluate this
... Continue reading in our forumHi Everyone,
I have just tried this lesson but don’t appear to have the full command set although my research suggests all commands should be available for these ios vers. Currently I have the following:
7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)S3,
C2600-IPBASEK9-M), Version 12.4(18)
In addition to the above I have tried multiple ADVENTERPRISE images from 3000 to 7000 series in GNS3 but dont appear to have any access to the command set for these labs.. can anyone advise?
Many Thanks
Frank
Hello Frank
Take a look at the following link. It contains the various Cisco Performance Monitor commands and the IOS versions that support them for the various platforms including the 2600 and the 7200.
https://www.cisco.com/c/en/us/...cr-perf-mon1.html
Hopefully this will give you a better idea of what’s available on your IOS versions.
In Reference to this lesson: https://networklessons.com/sys...formance-monitor.
some of the commands do not work in my cisco 9200 series, i try using also Easy Performance Monitor (ezPM) also for the cisco 9200.not working.
Kindly assist with configuration set for netflow for 9200 switches.I am tasked to send a the netflow to a PRTG monitor.
