DMVPN Phase 1 EIGRP Routing
In the first DMVPN lesson we discussed the basics and the three different phases. I also showed you how to create a basic DMVPN phase 1 configuration. In this lesson we’ll use that basic configuration and configure EIGRP on top of it. Here’s the topology we will use:
Each router has a loopback interface with an IP address that we’ll advertise in EIGRP.
Tunnel interfaces
Here is the tunnel configuration of the hub and spoke routers:
Hub(config)#interface Tunnel0
Let’s do some quick checks to verify that the tunnels are working correctly:
     1 192.168.123.2      172.16.123.2    UP 00:22:37     D
     1 192.168.123.3      172.16.123.3    UP 00:00:32     D
We see two NHRP registrations on the hub, let’s do a quick ping:
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
No issues here…let’s configure EIGRP.
EIGRP
Let’s advertise all networks:
Hub(config)#router eigrp 123
Hub(config-router)#network 1.1.1.1 0.0.0.0
Hub(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config)#router eigrp 123
Spoke1(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config-router)#network 2.2.2.2 0.0.0.0
Spoke2(config)#router eigrp 123
Spoke2(config-router)#network 172.16.123.0 0.0.0.255
Spoke2(config-router)#network 3.3.3.3 0.0.0.0
Let’s make sure we see two neighbors on the hub:
Hub#show ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(123)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
1   172.16.123.3            Tu0                      11 00:00:31   13  1434  0  4
0   172.16.123.2            Tu0                      13 00:01:02   82  1434  0  4
So far so good, let’s check our routing tables:
Hub#show ip route eigrp
D        2.2.2.2 [90/27008000] via 172.16.123.2, 00:01:16, Tunnel0
D        3.3.3.3 [90/27008000] via 172.16.123.3, 00:00:48, Tunnel0
The hub router has two entries, the next hop IP addresses are the tunnel addresses of spoke 1 and 2. When we want to resolve them, we’ll have to check the information in the NHRP cache:
Hub#show dmvpn | begin Hub
Type:Hub, NHRP Peers:2, </code>
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 192.168.123.2 172.16.123.2 UP 00:30:11 D
1 192.168.123.3 172.16.123.3 UP 00:21:28 D
This is how the hub is able to reach both spoke routers. What about the spoke routers?
Spoke1#show ip route eigrp
D        1.1.1.1 [90/27008000] via 172.16.123.1, 00:01:27, Tunnel0
Spoke2#show ip route eigrp
D        1.1.1.1 [90/27008000] via 172.16.123.1, 00:01:01, Tunnel0
Like RIP, EIGRP is a distance vector routing protocol so we have split horizon issues. The spoke routers don’t see each other’s networks. Let’s fix this for now:
  • Full Access to 395 lessons.
Tags: , ,
  1. Avatar for norman norman says:
    Hi !
    I am thinking to lab it up to try it to work. Anything that i should think of when a start with the nbma ? do you just have a switch between the interfaces ?
    Hi Oskar,
    I just used a switch to connect the routers to each other. It doesn’t matter much as long as they can reach each others NBMA addresses then you will be fine.
  3. Avatar for norman norman says:
    Hi !
    I work out the lab and it work. Great lab, now i want to put on some ipsec . I will try this for my CCNP security…
    /Thanks Oskar
  4. Avatar for sims sims says:
    If the tunnel interfaces are in same network why did you advertised again in EIGRP?
  5. Avatar for andrew andrew says:
    Sims,
    The network statement for the tunnel interface is telling EIGRP to use that interface to send and accept EIGRP packets. This is necessary in order to form EIGRP neighbor relationships between the hub and spokes.
25 more replies! Ask a question or join the discussion by visiting our Community Forum
