DMVPN Phase 3 EIGRP Routing
In the first DMVPN lesson we discussed the basics and the different phases. I also showed you how to configure DMVPN phase 1, phase 2 and phase 3. In this lesson we’ll take a look how we can configure EIGRP on a DMVPN phase 3 network.
Here’s the topology we will use:
Above we have a hub and two spoke routers. Each router has a loopback interface which we will advertise in EIGRP.
Tunnel interfaces
Below you will find the configuration of the tunnel interfaces. This is a basic DMVPN phase 3 setup:
Hub(config)#interface Tunnel0
Spoke1(config-if)#ip nhrp shortcut
Let’s do a quick test to make sure the hub has two NHRP registrations from the spoke routers:
Hub#show dmvpn
        C - CTS Capable
Type:Hub, NHRP Peers:2,
     1 192.168.123.2      172.16.123.2    UP 00:00:04     D
     1 192.168.123.3      172.16.123.3    UP 00:00:03     D
That’s looking good, let’s do a quick ping:
Hub#ping 172.16.123.2
Hub#ping 172.16.123.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 7/7/8 ms
Time to configure EIGRP…
EIGRP
First we advertise all tunnel interfaces and the loopback interfaces of the spoke routers in EIGRP:
Hub(config)#router eigrp 123
Hub(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config)#router eigrp 123
Spoke1(config-router)#network 172.16.123.0 0.0.0.255
Spoke1(config-router)#network 2.2.2.2 0.0.0.0
Spoke2(config)#router eigrp 123
Spoke2(config-router)#network 172.16.123.0 0.0.0.255
Spoke2(config-router)#network 3.3.3.3 0.0.0.0
The spoke routers don’t require specific entries thanks to NHRP traffic indication. I will advertise a default route on the hub router:
Hub(config)#interface tunnel 0
Hub(config-if)#ip summary-address eigrp 123 0.0.0.0 0.0.0.0
Let’s check the routing tables:
Hub#show ip route eigrp
D*    0.0.0.0/0 is a summary, 00:00:19, Null0
D        2.2.2.2 [90/27008000] via 172.16.123.2, 00:01:19, Tunnel0
D        3.3.3.3 [90/27008000] via 172.16.123.3, 00:00:19, Tunnel0
Spoke1#show ip route eigrp
D*    0.0.0.0/0 [90/28160000] via 172.16.123.1, 00:00:31, Tunnel0
Spoke2#show ip route eigrp
D*    0.0.0.0/0 [90/28160000] via 172.16.123.1, 00:00:43, Tunnel0
The hub has two specific entries, the spoke routers only have a default route. Let’s see if direct spoke-to-spoke communication is possible:
  • Full Access to 393 lessons.
Tags: , ,
  1. Avatar for williamlindberg williamlindberg says:
    Hello René.
    Great basic DMVPN lab but i have a request:
    A DMVPN lab with 2 ISP’s (Multihoming) and load balancing using EIGRP Add-Path Support. I have had a hard time understanding the concept of that.
    Hi William,
    I just published two examples for this:
    DMVPN dual hub single cloud
    DMVPN dual hub dual cloud
    I haven’t included EIGRP Add-Path Support (yet) but this might be useful.
  3. Avatar for shashipen shashipen says:
    If I want to migrate DMVPN phase 2 to phase 3 with EIGRP configured … what are the 3 changes that need to be done ??
    Hi Shashi,
    For a detailed answer you can take a look here:
    DMVPN Phase 3
    DMVPN Phase 3 EIGRP
    The short answer is this:
    Spoke(config)#interface Tunnel 0
    And you need to advertise a summary route on the hub towards your spoke routers that covers the networks behind your spoke routers.
  5. Avatar for sdmann22 sdmann22 says:
    I’m using the IOS image you said you were but for some reason when i try show ip route nhrp it doesn’t recognize “nhrp”
    R2#sho ip route nhrp
    Translating "nhrp"
    Also my dmvpn table looks a bit different but still says two entries only displays one line for them
    R2#show dmvpn
    Legend: Attrb --> S - Static, D - Dynamic, I - Incompletea
    Tunnel0, Type:Spoke, NHRP Peers:2,
     # Ent
18 more replies! Ask a question or join the discussion by visiting our Community Forum
