BGP Private and Public AS Range
BGP public AS numbers are globally unique identifiers assigned by IANA for routing on the Internet, ranging from 1-64495 (16-bit) and extended to 32-bit for more availability. The public AS numbers have to be unique on the Internet and BGP uses the AS number for its loop prevention mechanism. When BGP learns about a route that has its own AS number in its path, then it will be discarded.
BGP private AS numbers (64512-65,34) are used within organizations or single-provider connections and are removed before routes reach the public Internet, similar to how NAT hides private IP addresses. In this lesson, we learn the difference between public and private AS numbers, when to use each type, and how BGP handles private AS numbers at network boundaries.
Key Takeaways
  • Public AS numbers (1-64495 for 16-bit, extended to 32-bit) must be globally unique and require IANA allocation.
  • Private AS numbers (64512-65534) can be used within single-provider connections or BGP confederations.
  • BGP automatically discards routes containing its own AS number for loop prevention.
  • ISPs remove private AS numbers before advertising routes to the public Internet.
  • 32-bit AS numbers (4-octet) were introduced to address the exhaustion of 16-bit AS numbers.
  • You must justify your need when requesting a public AS number from IANA.
Loop Prevention
Here’s an example:
BGP Duplicate AS Number
Above, we have three routers, R1 and R3 are using the same AS number. Once R1 sends an update, R2 will accept it, but R3 will not, since the AS number is the same.
AS Number Ranges
To prevent the above from happening, IANA manages AS numbers (similar to public IP addresses). If you want an AS number for the Internet, then you’ll have to request one. They started with 16-bit AS numbers (also called 2-octet AS numbers) that were assigned like this:
  • 0: reserved.
  • 1-64495: public AS numbers.
  • 64496 – 64511 – reserved to use in documentation.
  • 6.512 – 65534 – private AS numbers.
  • 65535 – reserved.
The 1-64495 public AS range is pretty small so there are similar issues to the IPv4 public IP addresses, there aren’t enough numbers. Right now (May 2015) there are only 199 AS numbers left that could be assigned.
To get more AS numbers, an extension has been created that supports 32-bit AS numbers (also called 4-octet AS numbers). This means we have about 4.294.967.296 AS numbers that we can use.
When you request an AS number, you’ll have to justify why you need a public AS number. For some organizations, using a private AS number should also be a solution.
Private AS Numbers
Private AS numbers can be used when you are connected to a single AS that uses a public AS number. Here’s an example:
  • Full Access to 393 lessons.
  1. Avatar for marty.stoyanoff marty.stoyanoff says:
    Excellent! Thank you Rene!
  2. Avatar for nnmore nnmore says:
    “Removing the private AS numbers is a bit similar to NAT where we hide private IP addresses behind one or more public IP addresses”
    Accepted.
    But how are we going to do the mapping from private AS to public AS and back when the private AS number is not advertised by AS2 to AS 3 ?
    Hi Nikhil,
    We don’t. The only thing we do is remove the private AS number and then advertise the prefix(es). Take a look here:
    BGP Remove Private AS
    There’s no need to create a mapping between the private/public AS number.
  4. Avatar for sahilbhola2 sahilbhola2 says:
    Hey Rene,
    In your last diagram in this lesson, suppose we have many private AS behind R2 which needs to go to the Internet, in this case how will R2 handle those sessions ? We all know that in similar situation in IPv4 world we have PAT which maps the private IP with one Public IP using unique port number how does R2 handle this situation? Appreciate if you shed some light on this.
    Best,
    Sahil
    Hi Sahil,
    You can see it in this example:
    R2 will have the private AS paths in its own BGP table so it knows what to do.
17 more replies! Ask a question or join the discussion by visiting our Community Forum
