BGP Neighbor Adjacency States
Just like OSPF or EIGRP, BGP establishes a neighbor adjacency with other BGP routers before they exchange any routing information. Unlike other routing protocols however, BGP does not use broadcast or multicast to “discover” other BGP neighbors.
Neighbors have to be configured manually and BGP uses TCP port 179 for the connection.
In this lesson we’ll take a close look at the different “states” when two BGP routers try to become neighbors. Here they are:
  1. Idle:This is the first state where BGP waits for a “start event”. The start event occurs when someone configures a new BGP neighbor or when we reset an established BGP peering. After the start event, BGP will initialize some resources, resets a ConnectRetry timer and initiates a TCP connection to the remote BGP neighbor. It will also start listening for a connection in case the remote BGP neighbor tries to establish a connection. When successful, BGP moves to the Connect state. When it fails, it will remain in the Idle state.
  2. Connect: BGP is waiting for the TCP three-way handshake to complete. When it is successful, it will continue to the OpenSent state. In case it fails, we continue to the Active state. If the ConnectRetry timer expires then we will remain in this state. The ConnectRetry timer will be reset and BGP will try a new TCP three-way handshake. If anything else happens (for example resetting BGP) then we move back to the Idle state.
  3. Active: BGP will try another TCP three-way handshake to establish a connection with the remote BGP neighbor. If it is successful, it will move to the OpenSent state. If the ConnectRetry timer expires then we move back to the Connect state. BGP will also keep listening for incoming connections in case the remote BGP neighbor tries to establish a connection. Other events can cause the router to go back to the Idle state (resetting BGP for example).
  4. OpenSent: In this state BGP will be waiting for an Open message from the remote BGP neighbor. The Open message will be checked for errors, if something is wrong (incorrect version numbers, wrong AS number, etc.) then BGP will respond with a Notification message and jumps back to the Idle state. This is also the moment where BGP decides whether we use EBGP or IBGP (since we check the AS number). If everything is OK then BGP starts sending keepalive messages and resets its keepalive timer. At this moment, the hold time is negotiated (lowest value is picked) between the two BGP routers. In case the TCP session fails, BGP will jump back to the Active state. When any other errors occur (expiration of hold timer), BGP will send a notification message with the error code and jumps back to the Idle state. In case someone resets the BGP process, we also jump back to the Idle state.
  5. OpenConfirm: BGP waits for a keepalive message from the remote BGP neighbor. When we receive the keepalive, we can move to the established state and the neighbor adjacency will be completed. When this occurs, it will reset the hold timer. If we receive a notification message from the remote BGP neighbor then we fall back to the Idle state. BGP will keep sending keepalive messages.
  6. Established: The BGP neighbor adjacency is complete and the BGP routers will send update packets to exchange routing information. Every time we receive a keepalive or update message, the hold timer will be resetted. In case we receive a notification message we will jump back to the Idle state.
This whole process of becoming BGP neighbors can be visualized, this might be a bit easier then just reading about it. The official name of a “diagram” that shows the different states and we can move from one state to another is called a FSM (Finite State Machine). For BGP, it looks like this:
BGP states neighbor adjacency
Now you know about the different states, let’s take a look at some Cisco BGP routers to see what it actually looks like on two routers. I’ll use the following topology for this:
BGP R1 R2 AS1 AS2
Just two routers in two different autonomous systems. Before I configure BGP, let’s enable a debug:
If you like to keep on reading, Become a Member Now!
  • Full Access to our 807 Lessons. More Lessons Added Every Week!
491 Sign Ups in the last 30 days
satisfaction-guaranteed
  • No Questions Asked!
  1. This information on how BGP neighbors establish adjacency is articulate and useful. Thank You!
    Joey
  2. Hi Rene
    Thank you for great article. I had a question though.
    Why didn’t R1 enter connect state and instead shifted to Active straight from idle? On the other hand i see R2 did enter connect state?
    thanks
    Kandhla
  3. Hi Kandhla,
    Good question, I’m not sure why it doesn’t show up initially…
  4. Hei Rene,
    Thanks for the lesson, in my working experience, i am stuck in a situation for 2 sites. i have the ebgp peering up, but i am receiving 0 prefix from my isp. The isp said when they show ip bgp nei adverticed route that are hundreds of routes advertised, they can receive our route. Any good debug command to troule should this? We have plain bgp config, the same config (different peering ip though) is working with other sites.
    One interesting thing is that when i ping the isp with mtu 1500 it does not work, but it works with 1496. After reading cisco doc
  5. Hi Jie,
    It’s possible that the MTU is causing your issue. Your ISP might be sending BGP updates of 1500 bytes which are dropped on your end. Here’s the default TCP segment size that is used for BGP:
    R1#show ip bgp neighbors 192.168.12.2 | include segment
    Maximum output segment queue size: 50
    Datagrams (max data segment is 1460 bytes):
    The segment size is 1460 bytes, add a TCP header (20 bytes) and IP header (20 bytes) and you have a 1500 byte packet. In other words, you should be able to send/receive up to 1500 bytes which is not possible at the moment.
    There’
46 more replies! Ask a question or join the discussion by visiting our Community Forum
