Introduction to Python
Python is one of the most popular programming languages in the world. It is free and open-source. Python is developed by Guido van Rossum in the late 1980s and named not after the snake but after the television show “Monty Python”.
The syntax of Python is simple, which makes it easy to read and write code, even if you’ve programmed anything before.  Python runs on an interactive interpreter, which means that you can execute code right away, you don’t have to compile your code before you can run it.
All major platforms are supported, including Windows, macOS, and Linux. There is an active user community, and there are thousands of packages you can use.
Python Usage
Let me start with some examples for those of us who are interested in Python for anything network-related:
  • Scripting: Do you have any repetitive tasks that could be automated? Write a Python script to do it for you.
  • Interact with network devices: You can connect with your network devices through SSH or the API to configure the device or to fetch information from it.
  • Embedded Applications: You can use MicroPython on IoT devices.
You can also use Python for:
  • Web development: With the Django or Flask framework, you can build websites. Some big websites that use Django are NASA, Instagram, and Bitbucket.
  • Machine learning: Create programs that can automatically learn and improve.
  • Data analysis: Analyze data and create visualizations with charts.
  • Games: You can create games in Python.
  • Desktop applications: It’s possible to create GUI applications.
How to learn Python
If you want, there is a lot to learn about Python. However, someone who intends to use Python to build a website or to create games is going to use Python in a different way than someone who wants to use it for network automation.
In the Python course, I explain the basics of Python to get you started as quickly as possible. It should take a couple of hours to go through. Once you understand the basics, you can dive into specifics for your work field. For example, learning how to use SSH and REST APIs in Python.
The examples I provide are with “networking” in mind. Instead of strings like “hello world”, I’ll use examples with hostnames or sentences you might encounter when working with network devices.
  1. Avatar for syedabrar_8055 syedabrar_8055 says:
    Will like to bring to your attention. When we use search box for “Python” lessons it shows “no results” found. But however under CCNP and CCIE course, if we manually search its available.
    On other Note in CCIE Introduction page their is an typo in certification spelling .
    Abrar
    Hello Abrar
    I tried searching for “python” and I did get some results:
    https://cdn-forum.networklesso...a7a7e4b2eca0a2897
    Can you try again and replicate the error and let us know under what circumstances it happens? As for the typo, thanks for pointing it out, I will let Rene know to make the appropriate changes. Laz
    Hello @syedabrar_8055,
    Thanks for pointing out that typo, I fixed it. About the search function, if you are still having issues, could you share a screenshot? I’m getting the same result as @lagapidis
  4. Avatar for syedabrar_8055 syedabrar_8055 says:
    What I notice is we have to use complete word “python”. If I use “pytho” (Even I single letter less) the search fails.
    Attach is the screenshot
    Abrar
    https://cdn-forum.networklesso...7ed1ba1bb6247a7bc
    Hi Abrar,
    Thanks for letting me know, that is interesting. We are replacing the search engine soon, I’ll make sure it will also work for partial matches.
16 more replies! Ask a question or join the discussion by visiting our Community Forum
