Python Loops
A loop is an instruction that executes code multiple times.
Python supports two loop types:
For both loop types, it’s possible to skip items in the loop or to break out of the loop. Each time we go through the loop is called an iteration.
For Loop
The for loop runs a defined amount of times before it ends. This is useful if you want to execute some code an X amount of times. You can also use the for loop to go through items in a sequence. For example, the items in a list.
While Loop
The while loop repeats itself over and over again and doesn’t end until a certain condition is no longer true.Each time the loop ends, we check the condition again. When the condition is true, we execute the code in the loop again. When the condition is false, the loop ends.
Conclusion
Loops are useful when you want to execute the same line(s) of code multiple times or when you want to process multiple items, for example, the items in a list. In the next two lessons, we’ll go through both loop types.
