Python Read and Write Files
Sometimes you need to work with external files in Python. Perhaps you want to read a configuration file from a network device or you need to parse a log file. Fortunately, Python can read and write files.
Open() Function
To work with files in Python, we need to use the open() function. There are three basic options to work with files:
  • Read (r): This is the default option which opens a file to read.
  • Write (w): Open a file and write to it. Overwrites any current content in the file.
  • Append (a): Opens the file and writes to it but instead of overwriting, appends to the file.
Python can work with text or binary (JPG, PNG, MP3, etc.) files.
Let’s see what we can do.
Open File
I’ll create a text file named “demo.txt” with the following contents:
This is a text file to test Python file handling.
We have multiple lines in this file.
Python is able to read, write, append, and delete files.
We create a main file:
text_file = open("demo.txt")
print(text_file.read())
When we execute main.py it shows this:
In our code, we didn’t specify whether we wanted to read, write, or append to the file. We also didn’t specify whether we wanted to open it in text or binary mode. We don’t have to because the default options are “r” (read) and “t” (text). If you do want to specify your options, it looks like this. I’ll create a text file named “demo.txt” with the following contents:
text_file = open("demo.txt", "rt")
So far, so good. We have the contents of our file. However, Python returned it as a string. Wouldn’t it be easier if each line was a separate string? We can do this with the readlines() function. I’ll create a text file named “demo.txt” with the following contents:
print(text_file.readlines())
['This is a text file to test Python file handling.\n', 'We have multiple lines in this file.\n', 'Python is able to read, write, append, and delete files.']
Run the code above, and it shows each line as a string within a list.
Close File
In the example above, we opened a file but we never closed it. Closing files is important, especially when you write files.  Some changes in files won’t show up until you close them. In Microsoft Windows, open files are locked which prevents other programs from opening or writing to your files. Here’s an example of how to close your file. I’ll create a text file named “demo.txt” with the following contents:
text_file.close()
First, we open the file, then we do something with it, and finally, we close the file.
With Open
Instead of using the separate open() and close() function, we can also use the with block. You put everything you want to do with the file under the with block, and afterward, Python automatically closes the file. Here is an example. I’ll create a text file named “demo.txt” with the following contents:
with open("demo.txt") as text_file:
    lines = text_file.readlines()
print(lines)
I personally prefer this way. The indentation makes it easier to recognize what you do with the file in your code and you don’t have to worry about not closing the file.
Write File
When you write to a file, you overwrite its contents. When the file doesn’t exist, Python creates the file. To write to the file, we need to add the “w” parameter to the open() function. Here is our code:
with open("demo2.txt", "w") as text_file:
    text_file.write("Writing content to this file")
with open("demo2.txt") as text_file:
print(lines)
['Writing content to this file']
The code above writes a string to the “demo2.txt” file. We could use a text editor to check the contents of the file but since we are using Python, we’ll open it in Python as well.
If you run this code multiple times, it always shows a single line. That’s because the write parameter overwrites the content of our file.
Append File
Instead of overwriting the content of our file, we can append to the file. To do this, you have to use the “a” parameter in the open() function. For the output below, I deleted “demo2.txt” first, so we start with an empty file:
with open("demo2.txt", "a") as text_file:
print(lines)
Will show this output:
When we run the above code multiple times, you’ll see that Python appends the string to our file. There is one problem though. Python appends the string to the same line.
New Line
If you want to append to a new line, you have to use the \n new line symbol in your string. I deleted “demo2.txt” again first, so we start with an empty file. Here’s our code:
    text_file.write("\nWriting content to this file")
print(lines)
['\n', 'Writing content to this file']
In the code above, I added the \n new line symbol before my string. Each line we append is now saved in a new line of our file.
  1. Avatar for stlourenco stlourenco says:
    Hello, Rene, Nice lession"
    What if I want remove some string or text within the file, without delete the file itself ? Is it possible?
    Hello Stefanio
    Yes it is possible to delete a particular line within a file. Specifically, you must call file.readlines() to get a list of all the lines in that file. You can then use list indexing to edit a specific line. You can do it like so:
    Let’s say you have a text file called my_text.txt that contains the following lines:
    Line1
    Change This Line
    Line3
    Use the following code:
    a_file = open("my_text.txt", "r")
    list_of_lines = a_file.readlines()
    list_of_lines[1] = "Line2\n"
    a_file = open("my_text.txt", "w")
    a_file.writelines(list_of_lines)
  3. Avatar for rips.naik1990 rips.naik1990 says:
    Let’s say my file has show interface status command output of the switch. If I only want to display the ports that are connected, is there a function or functions I can use to filter only connected ports in the file ?
    Hello Ripal
    I believe the easiest way to achieve this is to use Cisco’s CLI output modifiers. You can use the show interface status | include connected command to limit the output to only the connected ports. You can create different Python functions to call different CLI commands according to the kind of output you want.
    Creating a Python script to filter out the connected interfaces is possible, but it is definitely more complicated. If you want to achieve it via Python, there are many ways to do it. Some are found at the following link:
