Python While Loop
Repeating the execution of a block of code is called iteration. Python can do this with two loop options:
The while loop executes code as long as a condition is true. When the condition equals false, we exit the loop. We check the condition each time we do another iteration. A while loop is useful when you don’t know beforehand how many loop iterations you need. In this lesson, I’ll show you how to use the while loop in Python.
While Loop
Here is a basic example:
counter = 0
while counter < 3:
    counter += 1
    print("Counter value is %s" % counter)
Will show this output:
Counter value is 1
Counter value is 2
Counter value is 3
The while loop will run as long as the variable "counter" is below 3. We print a message, then increase the value of our variable by 1. Once the counter equals 3, the loop condition equals false and we exit the loop.
Break
With the break statement, we can exit the while loop even though the while condition equals true. Here's an example:
counter = 0
while counter < 3:
    if counter == 2:
        break
    counter += 1
print("Finished loop")
Counter value is 0
Counter value is 1
Counter value is 2
Finished loop
When the value of the variable "counter" equals 2, we break out of the while loop.
Continue Statement
The continue statement stops the current iteration and continues with the next one. Here is our code:
counter = 0
while counter < 3:
    counter += 1
    if counter == 2:
        continue
        print("this is never executed")
Counter value is 1
Counter value is 3
Our code skips value 2, because of the continue statement. The loop continues until the while condition equals false.
Else Statement
The else statement runs some code when the condition of the while loop no longer equals true. Here's how to do it:
  1. Avatar for neetikachhetri neetikachhetri says:
    counter = 0
    while counter < 3:
    counter += 1
    if counter == 2:
    continue
    print("This is never executed")
    Should not it print “This is never executed” when counter values is 2 during the incrementing counter value loop?
    Hello Rupak
    The continue statement is used to stop the current iteration and continue with the next one. This means that:
    when the counter is equal to 2, the continue statement is executed.
    the loop stops there and goes back to the beginning without executing the next statements
    Therefore, the print("This is never executed") statement is never executed.
