How to configure OSPF Virtual Link
If you studied Cisco’s CCNA you have learned that when you use OSPF all the areas have to be directly connected to the backbone area. Is this really true? Areas have to be connected to the backbone area but if they aren’t we can fix it with a virtual link.
Let me show you an example:
ospf discontinuous area
Look at my picture above. We have three areas and on the left side is area 0. Area 2 is behind area 1. Normally this is not going to work since area 2 has to be directly connected to area 0. We can make this work by using a virtual link. By using a virtual link we can extend area 0 through area 1 so area 2 will be “directly connected” to area 0. Let’s take a look at how a virtual link can solve this problem:
ospf virtual link
This is basically how a virtual link works. It’s like a tunnel through area 1 to reach area 2. This way area 2 will be directly connected. Now let me show you how to configure a virtual link:
ospf virtual link topology
In the example above area 2 is not directly connected to area 0 so we’ll have to use a virtual link between routers R1 and R2, here’s how we do it:
R1(config)#router ospf 1
R1(config-router)#network 1.1.1.0 0.0.0.255 area 0
R1(config-router)#network 192.168.12.0 0.0.0.255 area 1
R2(config)#router ospf 1
R2(config-router)#network 192.168.12.0 0.0.0.255 area 1
R2(config-router)#network 192.168.23.0 0.0.0.255 area 2
R3(config)#router ospf 1
R3(config-router)#network 192.168.23.0 0.0.0.255 area 2
I’ll start with a default OSPF configuration.
R1(config-router)#area 1 virtual-link 192.168.23.2
R2(config-router)#area 1 virtual-link 1.1.1.1
We configure the virtual link between ABRs and we use the area virtual-link command. First, you need to specify the area where we need the virtual link which is area 1 in my example. The second step is to configure the OSPF router ID of the other ABR. Keep this in mind…you need to configure the OSPF router ID and NOT the IP address of the ABR. If everything is OK area 2 will be directly connected to area 0 through our virtual link.
R1# %OSPF-5-ADJCHG  Process 1, Nbr 192.168.23.2 on OSPF_VL0 from LOADING to FULL, Loading Done
R2# %OSPF-5-ADJCHG: Process 1, Nbr 1.1.1.1 on OSPF_VL0 from LOADING to FULL, Loading Done
You will see the message above that tells us the virtual link is established.
R1#show ip ospf virtual-links
Virtual Link OSPF_VL0 to router 192.168.23.2 is up
  Run as demand circuit
  DoNotAge LSA allowed.
  Transit area 1, via interface FastEthernet0/0, Cost of using 1
  Transmit Delay is 1 sec, State POINT_TO_POINT,
    Hello due in 00:00:06
    Adjacency State FULL (Hello suppressed)
    Index 1/2, retransmission queue length 0, number of retransmission 0
    First 0x0(0)/0x0(0) Next 0x0(0)/0x0(0)
    Last retransmission scan length is 0, maximum is 0
    Last retransmission scan time is 0 msec, maximum is 0 msec
R2#show ip ospf virtual-links
Virtual Link OSPF_VL0 to router 1.1.1.1 is up
    Hello due in 00:00:05
    Index 1/3, retransmission queue length 0, number of retransmission 0
You can use the show ip ospf virtual-links command to check if your virtual link is working.
R1#show ip ospf database
            OSPF Router with ID (1.1.1.1) (Process ID 1)
		Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.1.1.1         1.1.1.1         189         0x80000004 0x00E333 2
192.168.23.2    192.168.23.2    1     (DNA) 0x80000002 0x009816 1
R2#show ip ospf database
            OSPF Router with ID (192.168.23.2) (Process ID 1)
1.1.1.1         1.1.1.1         1     (DNA) 0x80000004 0x00E333 2
192.168.23.2    192.168.23.2    159         0x80000002 0x009816 1
If you look at the LSDB you will see that the virtual link shows up as a type 1 router LSA. You can also see DNA which means do not age.
R2
hostname R2
interface FastEthernet1/0
router ospf 1
R1
hostname R1
router ospf 1
R3
hostname R3
router ospf 1
Any other situation where we need a virtual link? What about a discontinuous backbone area? Let me show you an example:
877 Sign Ups in the last 30 days
satisfaction-guaranteed
100% Satisfaction Guaranteed!
No Questions Asked!
  1. Rene ! this is really grt !
  2. Hi, thank you very much for this very easy to understand explanation. Great job rene.
  3. Is it possible to build a virtual link over frame-relay link ? for example in the diagram above if the router in between was a frame-relay switch
  4. Hi Jurati,
    Yes this is possible, when your OSPF neighbor adjacency is working over the frame relay link you should be able to configure a virtual link.
88 more replies! Ask a question or join the discussion by visiting our Community Forum
