OSPF Multi-Area Configuration
In my introduction on OSPF I explained why we sometimes use multiple areas for OSPF and in our configuration example, I showed you how to configure OSPF for a single area. This time, we’ll take a look how you can configure multi area OSPF.
We will use the following topology:
ospf two areas multi area
Above we have R1 and R2 in area 0, the backbone area. Between R1 and R3, we will use area 1 and between R2/R4 we will use area 2. R3 and R4 have a loopback interface with an IP address that we will advertise in their area.
Let’s start with all network commands to get OSPF up and running. The network command defines to which area each interface will belong.First, we will configure R1 and R2 for the backbone area:
R1(config)#router ospf 1
R2(config)#router ospf 1
Let’s configure R1 and R3 for area 1:
R1(config-router)#network 192.168.13.0 0.0.0.255 area 1
R3(config)#router ospf 1
R3(config-router)#network 192.168.13.0 0.0.0.255 area 1
R3(config-router)#network 3.3.3.3 0.0.0.0 area 1
And last but not least, R2 and R4 for area 2:
R2(config-router)#network 192.168.24.0 0.0.0.255 area 2
R4(config)#router ospf 1
R4(config-router)#network 192.168.24.0 0.0.0.255 area 2
R4(config-router)#network 4.4.4.4 0.0.0.0 area 2
Those are all the network commands we need.
Verification
Let’s verify our work. First, let’s make sure we have OSPF neighbors:
R1#show ip ospf neighbor
192.168.24.2      1   FULL/DR         00:00:36    192.168.12.2    GigabitEthernet0/1
3.3.3.3           1   FULL/BDR        00:00:34    192.168.13.3    GigabitEthernet0/2
R1 has formed a neighbor adjacency with R2 and R3. Let’s check R2:
R2#show ip ospf neighbor
192.168.13.1      1   FULL/BDR        00:00:34    192.168.13.1    GigabitEthernet0/1
4.4.4.4           1   FULL/BDR        00:00:30    192.168.24.4    GigabitEthernet0/2
R2 has formed neighbor adjacencies with R1 and R4. The show ip ospf neighbor command, however, doesn’t tell me anything about the areas that are used. If you want to see this, you could add the detail parameter like this:
R2#show ip ospf neighbor detail
 Neighbor 192.168.13.1, interface address 192.168.12.1
    In the area 0 via interface GigabitEthernet0/1
    Neighbor priority is 1, State is FULL, 6 state changes
    DR is 192.168.12.2 BDR is 192.168.12.1
    Options is 0x12 in Hello (E-bit, L-bit)
    Options is 0x52 in DBD (E-bit, L-bit, O-bit)
    LLS Options is 0x1 (LR)
    Dead timer due in 00:00:33
    Neighbor is up for 00:17:30
    Index 1/1/1, retransmission queue length 0, number of retransmission 0
    First 0x0(0)/0x0(0)/0x0(0) Next 0x0(0)/0x0(0)/0x0(0)
    Last retransmission scan length is 0, maximum is 0
    Last retransmission scan time is 0 msec, maximum is 0 msec
 Neighbor 4.4.4.4, interface address 192.168.24.4
    In the area 2 via interface GigabitEthernet0/2
    DR is 192.168.24.2 BDR is 192.168.24.4
    Dead timer due in 00:00:31
    Neighbor is up for 00:15:57
    Index 1/1/2, retransmission queue length 0, number of retransmission 0
Above you can see that interface GigabitEthernet0/1 is in area 0 and interface GigabitEthernet0/2 is in area 2. Another good command to find area information is show ip protocols:
R2#show ip protocols
Routing Protocol is "application"
  Sending updates every 0 seconds
  Invalid after 0 seconds, hold down 0, flushed after 0
  Maximum path: 32
  Routing for Networks:
  Routing Information Sources:
  Distance: (default is 4)
Routing Protocol is "ospf 1"
  Router ID 192.168.24.2
  It is an area border router
  Number of areas in this router is 2. 2 normal 0 stub 0 nssa
  Maximum path: 4
    4.4.4.4              110      00:16:04
    192.168.13.1         110      00:16:53
  Distance: (default is 110)
Above you can see which networks belong to which area:
  • Network 192.168.12.0 in area 0.
  • Network 192.168.24.0 in area 2.
Let’s check our routing tables. Let’s start with R1:
R1#show ip route ospf
       a - application route
O        3.3.3.3 [110/2] via 192.168.13.3, 00:01:47, GigabitEthernet0/2
O IA     4.4.4.4 [110/3] via 192.168.12.2, 00:00:54, GigabitEthernet0/1
O IA  192.168.24.0/24 [110/2] via 192.168.12.2, 00:01:44, GigabitEthernet0/1
Above we see three OSPF entries. The first one is for 3.3.3.3/32, the loopback interface of R3. It shows up with an O since this is an intra-area route. R1 has also learned about 4.4.4.4/32 and 192.168.24.0/24. These two entries show up as O IA since they are inter-area routes.
R2 has a similar output:
R2#show ip route ospf
O IA     3.3.3.3 [110/3] via 192.168.12.1, 00:02:19, GigabitEthernet0/1
O        4.4.4.4 [110/2] via 192.168.24.4, 00:01:29, GigabitEthernet0/2
O IA  192.168.13.0/24 [110/2] via 192.168.12.1, 00:02:24, GigabitEthernet0/1
Above we see that R2 has learned about 3.3.3.3/32 and 192.168.13.0/24 which are inter-area routes. 4.4.4.4/32 is an intra-area route.
Let’s check R3:
R3#show ip route ospf
O IA     4.4.4.4 [110/4] via 192.168.13.1, 00:01:57, GigabitEthernet0/1
O IA  192.168.12.0/24 [110/2] via 192.168.13.1, 00:02:50, GigabitEthernet0/1
O IA  192.168.24.0/24 [110/3] via 192.168.13.1, 00:02:47, GigabitEthernet0/1
Everything that R3 has learned is from another area, that’s why we only see inter-area routes here. The same thing applies to R4:
R4#show ip route ospf
O IA     3.3.3.3 [110/4] via 192.168.24.2, 00:02:13, GigabitEthernet0/1
O IA  192.168.12.0/24 [110/2] via 192.168.24.2, 00:02:13, GigabitEthernet0/1
O IA  192.168.13.0/24 [110/3] via 192.168.24.2, 00:02:13, GigabitEthernet0/1
Just to be sure, let’s try a quick ping between R3 and R4 to prove that our multi-area OSPF configuration is working:
R3#ping 4.4.4.4 source 3.3.3.3
Sending 5, 100-byte ICMP Echos to 4.4.4.4, timeout is 2 seconds:
Packet sent with a source address of 3.3.3.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/11/13 ms
Our ping is successful. That will be all for now.
  1. Avatar for Zaman.rubd Zaman.rubd says:
    Hope you are doing well :slight_smile: My question is, In ospf database/Topology table we find type-1 LSA,on that it shows Link ID and ADV. Router ID both are same why ??
    br//zaman
  2. Avatar for Zaman.rubd Zaman.rubd says:
    I want to know how OSPF Prevent Inter-Area Loop at ABR and ASBR end ?? How its works if two ABR /ASBR Scenario ? How ABR do function ? I think a details write up needed regarding looping prevention issue in your clear text . Appreciate your write up on it .Thx
    br//zaman
    Hello Mohammad
    The ADV Router ID heading shows the router ID of the advertising router, that is the router from which this LSA was received.
    Now the Link State ID heading is a little more tricky. According to the OSPF RFC, when a router is packaging all of its local, Type-1 Router LSAs into a single OSPF packet, and adds an LSA Header to the front of those LSAs, the “Link State ID” field in that header is always the Router-id of that router. Now…within each, individual LSA there is another field called the “Link ID” field. For each Router LSA it is THIS fie
    Hello Mohammad
    I’ll let @ReneMolenaar respond to this one. I’ll let him know and he can tell us if/when inter-area loop prevention for OSPF will be included in a future lesson.
  5. Avatar for Zaman.rubd Zaman.rubd says:
    Thanks for your valuable reply on complex issue as always :slight_smile: Could you please reply on Looping issue for the intermediate time ?? It will very much helpful to keep my study continue .Many thanks
    br//zaman
55 more replies! Ask a question or join the discussion by visiting our Community Forum
